Old 07-22-2012, 03:37 PM   #166
Justgastanks OP
Oddometer: 137
Wicked
Originally Posted by TransalperNZ View Post
I just experienced the same or a similar problem and managed to fix it myself.
It could be that you issue was worse than mine but here's what I did....
Mine stock pump hit the little Mikuni vacuum pump so it sat angled so much I couldn't get the screws to start but if I leaned on it a bit it was quite close but then of course I didn't want to have to do that so....
Our Fix was to remove the Mikuni pump, cover all it's pipes with tape to stop metal fillings getting in and cut the top un-used mounting bracket off it.
I also filed a rounded edge on the pump for extra clearance.
Re-install the Mikuni pump and now my pump fits perfectly, no more rubbing, screws go straight in by hand. yay !
So anyone else having this problem could have a look and see if doing that might give you enough clearance to make it work for you too.
Having no idea how bad your issue was I guess it is possible that this may not be enough for your tanks, but though I'd post as I found this thread while searching to see if anyone else had posted of the problem.
Cheers
TransalperNZ
Thank you for this info!
We have 8-10 perfect WR250R shells(minus the pump area molded a bit deep) here at the shop! Contact us if you are interested. We will make you a deal.
These do not come with any mikuni pump but we do sell these.
Just Gas Tanks.com
The Enduro Shop
5% off code: Advrider
Justgastanks is offline   Reply With Quote
Old 07-22-2012, 03:41 PM   #167
Justgastanks OP
Oddometer: 137
Originally Posted by ThumperStorm View Post
I would love to have a larger tank for my 1983 Yamaha XT550 but no one makes one (anymore). Is there any way to tell if a different tank could be modified to fit? One from a xt600 maybe?
The only way would be to try one on here. I would assume you could get a XT600 or 650L on there. Something that would not take any air scoops/shrouds.
Ben
Just Gas Tanks.com
The Enduro Shop
Old 07-26-2012, 09:36 AM   #168
njjisu
njjisu's Avatar
Oddometer: 44
Does anyone know if the stock vacuum petcock on a DR650 tank will work on the 5.3 gallon Acerbis tank?
http://justgastanks.com/product_info...oducts_id=2716
njjisu is offline   Reply With Quote
Old 07-30-2012, 10:04 PM   #169
Justgastanks OP
Oddometer: 137
I do not believe it will as these have a one hole petcock mount. Not 100% sure though...
JGT
Just Gas Tanks.com
The Enduro Shop
Old 08-06-2012, 09:52 PM   #170
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,814
Showing off my two Safari tanks from Just Gas Tanks!
You guys rock!
drrags is offline   Reply With Quote
Old 08-07-2012, 01:18 PM   #171
Justgastanks OP
Oddometer: 137
Thanks for your business!
Just Gas Tanks.com
The Enduro Shop
Old 09-03-2012, 12:25 AM   #172
error cooled
anything but asphalt
error cooled's Avatar
Oddometer: 1,174
Originally Posted by NCMX1 View Post
The Acerbis 5.8g tank is the same tank for the XR250/400/600/650L. It is just that the 250/400, 600, and 650L all use different mounting hardware. We should have the correct hardware to install these on the 600 pretty soon.
I see the 5.8 XR600R tank is back in stock in White. Any chance of selling me a red 5.8 XR650L with the XR600R mounting hardware? Please let me know.
David
Honda XR600R
The Blue Ridge Trail - Virginia via gravel, dirt, two track and backroads.
USFS Motorized Access in Virginia - Protect your dual sporting access in the commonwealth.
error cooled is offline   Reply With Quote
Old 09-04-2012, 04:58 PM   #173
Justgastanks OP
Oddometer: 137
David
David
Shouldn't be problem...
Give us a call.
Just Gas Tanks.com
The Enduro Shop
Old 09-05-2012, 01:59 PM   #174
Mongo357
Mongo357's Avatar
Oddometer: 150
TW200 mystery tank
Hey,
Any chance you guys can ID the tank and shroud on this TW200? Pretty sure they were adapted for the TW, not built specifically for it.
http://reno.craigslist.org/mcy/3135806784.html
Mongo357 is offline   Reply With Quote
Old 09-05-2012, 05:05 PM   #175
Justgastanks OP
Oddometer: 137
We do not know what this is off of...
It almost looks like the shrouds off of a chinese brand bike that I have seen running around.
JGT
Just Gas Tanks.com
The Enduro Shop
Old 09-05-2012, 05:14 PM   #176
MotorCade
Rugby whore
Oddometer: 457
How about a bigger tank for a klx 110?
MotorCade is offline   Reply With Quote
Old 09-05-2012, 10:27 PM   #177
Justgastanks OP
Oddometer: 137
Nothing yet..
JGT
Just Gas Tanks.com
The Enduro Shop
Old 09-06-2012, 06:43 AM   #178
gmtech
Oddometer: 64
how long have you been waiting for the parts kit for the wr250r safari tanks?
thanks
gmtech is offline   Reply With Quote
Old 09-06-2012, 02:51 PM   #179
Justgastanks OP
Oddometer: 137
thanks
We are hoping to get them sent to us before our next shipment comes. Worse case it will be 6-8 weeks.
Just Gas Tanks.com
The Enduro Shop
Old 09-06-2012, 05:49 PM   #180
MotorCade
Rugby whore
Oddometer: 457
What about either OE replica or Azzalin tanks for the Elefant? Both were originally manufactured by Acerbis. Think they still have a mold around somewhere?
Times are GMT -7.   It's 06:22 AM.
