Go Back   ADVrider > Riding > Regional forums > Pacific Northwet - Where it's green. And wet.
Old 08-23-2011, 06:10 PM   #1
linkweewee OP
tantum quantum
linkweewee's Avatar
Oddometer: 14,109
VStrom Transmission Repair in Eugene/Springfield?
Just bring it to Cycle Parts/Louis or is there someone who can do it cheaper in the area?
Life is hard. It's harder if you're stupid.
-John Wayne
linkweewee is offline   Reply With Quote
Old 08-23-2011, 06:35 PM   #2
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,397
You might call Power Sport Dynamic, over in Springfield
Robert Wahl is the owner/mechanic and he has or had a V-Storm for his personal bike. His Number is (541) 741-1800. He's who I'd go to for anything I wouldn't want to do myself.
Mike M.
Creswell, Oregon
'14 KLR 650
Ride what makes you giggle in your helmet
oremike is online now   Reply With Quote
Old 08-23-2011, 07:09 PM   #3
Capo Rick
Please understand...
Capo Rick's Avatar
Oddometer: 1,470
Please let us know what it is ( or isn't ) doing?
shift lever locked? ........makes bad metal grinding noises?
"Nobody ever sells their bikes at Guzzi rallies........ But the upside is that you may get into a good fight and have the opportunity to have sex with some-being of a different species."-Pete Roper
Capo Rick is offline   Reply With Quote
Old 08-23-2011, 07:45 PM   #4
peterman
cop magnet
peterman's Avatar
Oddometer: 13,610
Yep, he is honest and reputable and does good work. What did the bike do,,jam in 2 gears at once?
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 08-23-2011, 09:21 PM   #5
linkweewee OP
tantum quantum
linkweewee's Avatar
Oddometer: 14,109
I have zero shift lever engagement from 7 oclock to 11 oclock and the problem is not external
-John Wayne
Old 08-23-2011, 09:25 PM   #6
oremike
Motorcyclest
oremike's Avatar
Oddometer: 2,397
I've not heard of the transmissions being a point of failure for V-Stroms, though anything is possible. There is some sort of issue with the clutch baskets on some, mine would chatter if I slipped it too long so I'd just dump the clutch and go.
Mike M.
Creswell, Oregon
'14 KLR 650
Old 08-23-2011, 10:39 PM   #7
peterman
cop magnet
peterman's Avatar
Oddometer: 13,610
broken shifter shaft,,
pin is gone on a shifting fork, that's my guess, and I'm sticking to it,,shifting fork failure.or some other shifty thing,,no doubt about it!
Or,,the shifter shaft is sheared off where the ratshit transition happens.pick yer own failure prone opinion.
In the late 70's, BMW had a batch of third gear gears that were not heat treated properly and some failed, causing a recall. Same holds true for all kinds of small shafts,gears,and spinning stuff,, one scratch or sharp line in the manufacturing process can cause a fail point, especially after hardening and heat treating.
It'll be interesting to see what caused the failure, because parts are made in huge batches, so more would be exhibiting the same result if it were due to a flaw in a mfg process.
biggest bummer is it happened when you had the ride planned with your blood brothers,,sorry man! that sucks!
wish they could be here for wetfester!
peterman
Old 08-24-2011, 11:13 AM   #8
linkweewee OP
tantum quantum
linkweewee's Avatar
Oddometer: 14,109
Set up an appointment for Tuesday with Robert-thanks for the info. If anybody has a ramp I could pick up on Monday I would appreciate the help-thanks.
-John Wayne
Times are GMT -7.   It's 05:36 PM.
