Old 11-27-2011, 07:05 PM   #226
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
Originally Posted by jungleplant View Post
thanks biggie
it would be nice to see the different angles without all the stuff on it
what does big Texas think bout the frame thing , biggie you have a shop, can ya look at it
OK , Jungle , Spud , Tech , get to drawing on the drawing board.
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 11-27-2011, 07:07 PM   #227
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
Marko
Old 11-27-2011, 07:18 PM   #228
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
Marko
Old 11-27-2011, 07:22 PM   #229
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
sorry , my detail man accidentally got in this 1
Marko
Old 11-27-2011, 07:32 PM   #230
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
Last set
Marko
Old 11-27-2011, 07:57 PM   #231
jungleplant OP
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,844
thanks Biggie
Thats all you got big man
don't be holding any of those pics back on us now can you toss in a few pairs of titties
www.manracks.com
jungleplant is offline   Reply With Quote
Old 11-27-2011, 08:05 PM   #232
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
No boobage ,
but can you give me an appraisal on this setup , its my brothers and he wants to sell it , prolly gonna list it in the flea market when I find out a value whatcha think Mike , how much
Marko
Old 11-27-2011, 08:15 PM   #233
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,493
Ok Ok Ok
Marko
Old 11-27-2011, 08:38 PM   #234
jungleplant OP
Motorcyle Stuff
Oddometer: 1,844
Id say 7 for the green and 2 for the red ones
www.manracks.com
Old 11-28-2011, 02:16 AM   #235
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
Thanks for supplying the photographs of the XR650L frame, Marko. Here are my ideas for modified Spud Struts.
This is Marko's photograph of the frame from the 7 o'clock position.
Here is my idea for a modified Spud Strut for the right side of the frame.
The front mounting point for my current Spud Strut is bolted through a tab on the bottom of the airbox into a gusset which supports the front mounting point of the muffler, as shown below.
I propose we cut away the plastic tab on the bottom of the airbox, and weld an extension onto the right side of the Spud Strut, so it mounts directly to the gusset. This modification would reduce shear forces on the front mounting bolt.
I propose we keep the rear mounting point for my Spud Strut, which is the bolt hole for the fender subframe. However, I suggest we weld an additional arm onto the Spud Strut which will extend to the bolt hole for the right, rear turn signal.
This is Marko's photograph of the frame from the 5 o'clock position.
Here is my idea for a modified Spud Strut for the left side of the frame.
I propose we keep the front mounting point for my current Spud Strut which is the bolt holder for the front of the battery box.
However, I suggest we change the rear mounting point of my current Spud Strut to the bolt hole for the fender subframe. This mounting point is less likely to interfere with the battery box. I suggest we weld an additional arm onto the Spud Strut which will extend to the bolt hole for the left, rear turn signal.
This design should be very strong, and inexpensive to manufacture. In addition, this design should accommodate all aftermarket mufflers, and the stock battery box as well.
Spud
Old 11-28-2011, 08:28 AM   #236
jungleplant OP
Motorcyle Stuff
Oddometer: 1,844
OK Spud I Agree totally
when can you have a prototype ready to send me
OK wrong hole , my x used to say that i never could figure what she meant by that
it would be better for production to be made this way but
then we could add these for xtra strength if and when needed , could even weld bungie loops on there
will this work spud
additionally this way we could get more parts out of a sheet and the shipping would be cheaper
www.manracks.com
jungleplant screwed with this post 11-28-2011 at 09:27 AM
Old 11-28-2011, 11:49 AM   #237
Spud Rider
Spud Rider's Avatar
Oddometer: 3,771
I like your idea, Mike. Making the Spud Stuts a dogleg shape, instead of a Y shape, adds additional, longitudinal strength to the small, weak cantilever at the end of the bike's frame. However, I still believe this weak cantilever needs additional, triangular bracing. Therefore, I propose you add an extra, straight piece of 1/4-inch steel bar which can be bolted to the rear blinker holes and the downward legs on each Spud Strut. These extra, separate bars are colored green in the following photograph.
It would cost very little to ship these two extra pieces, and they would add greatly to the strength of the modified Spud Struts. Of course, you could also weld these extra bars to the Spud Strut doglegs.
You might also consider attaching the front mount of the right Spud Strut to the upper, foot peg bolt, as TT has done. Since the Spud Struts are mounted to the fender subframe bolt, the angle of the right Spud Strut is more vertical than the TT brace. Therefore, you might be able to mount outside the frame to the foot peg bolt, and still accommodate all the aftermarket mufflers.
Spud
Spud Rider screwed with this post 11-28-2011 at 12:12 PM
Old 11-28-2011, 12:49 PM   #238
jungleplant OP
Motorcyle Stuff
Oddometer: 1,844
Ok Spud we can do this
www.manracks.com
Old 11-28-2011, 07:09 PM   #239
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,306
2 piece design,,,,,,,,bracket at swingarm bolt wraps arround the vertical tube,,and has 2 bolts welded to it.........
The support bolts on there and runs up to the footpeg mount a bolts and bolts there,this strengthens that tube alot.......then it goes up and bolts where the seat bolts on..then bolts at the very rear......all stress relays down to the strongest part of the bike,,,the swingarm mount..
make it so
I`m no designer,,and can barely draw...but bracing off where the passenger pegs mount is just going to break that tube..you need a stronger tube to brace off of..
B
techforlife is offline   Reply With Quote
Old 11-28-2011, 07:16 PM   #240
techforlife
CDI REPAIR
Oddometer: 4,306
Look at the large tubes used arround the engine and steering head......and suspension.................now look at the pissy little tubes from there to the back.....this bike was NOT meant to carry anything but a rider and very light passenger...bracing off any of these tubes is a waste of time...
Now,,back to my regular scheduled drinking....
don`t be interupting me neither
B
Times are GMT -7.   It's 07:51 PM.
