Old 11-29-2011, 08:27 PM   #256
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,484
Originally Posted by jungleplant View Post
Hi mike
how are thing over there. good i hope , have you seen the new superduty rack for the xt225 ?
I think what spud has so far is a gusset sorta just a longer funnier shaped one , and with no welding , no cracking, BINGO
i looked into alum billet clamp on with a bolt sticking out but there 20 bucks each OUCH !!!
I see the problem with the supports from TT , but the riders need a few choices here between cost and quality and of course functionality and the spud strut is better IMO, question i have a xr250L coming over for a rack mount this weekend and is the frame the same as the XR650L, i know the racks are the same , just wandering bout the bat box and muffler and all that stuff,,,,,,,,,,,,,,,, or is it close enough so i can do the prototype here in the shop,
thanks for stopping by with your input ,,,,,,,,,,,, mike
Doing very well, thank you. Was pretty busy for a month which surprised me. I did see the rack for the XT and it looks good. I would mention it over at XT225.com but I got banned from there when I refused to place an ad there for centerstands.
I was just thinking out loud and trying to help out. My biggest concern with the strut design was the length of the arms. Once they start to bend there will be a loss of strength. A gusset that is an inch or two high that runs along the bottom of the horizontal tube would stiffen it up. A strut somewhere near the mid point of the gusset would provide the additional strength. I don't believe the gusset would need to be more than 1/8" thick. If made from steel there are plenty of inexpensive clamps that could be welded to the plate to clamp to the frame if needed. Like I said, just thinking out loud.
Good luck with the design.
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 11-29-2011, 08:42 PM   #257
jungleplant OP
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,858
Mike
thanks mike
we are gonna use the brake press to put a stiffener in the middle of the long run down so it wont bow
have to wait and see how much most likely 20 degrees to start , it will make that stainless damn hard to bend
i hope the polisher take the scratches out , stay tuned thanks mike
www.manracks.com
jungleplant is offline   Reply With Quote
Old 11-29-2011, 09:10 PM   #258
michael.brat
michael.brat's Avatar
Oddometer: 496
Sweet mike! Good to hear you'll be jumping into it so soon. Thanks for doing the dirty work for us
I'm glad to test them I like the idea of adding the stiffener in the middle.
Mike B
michael.brat is offline   Reply With Quote
Old 11-30-2011, 09:36 AM   #259
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,484
thanks mike
Mike,
Looking good. I could try out a set of the scratched ones to save you time.
Mike
Old 11-30-2011, 05:53 PM   #260
jungleplant OP
Motorcyle Stuff
Oddometer: 1,858
Mike,
Mike
Ok mike you got it
everybody PM spud and get him going
we need those spud struts out there Frames are cracking beer is being spilled
www.manracks.com
Old 11-30-2011, 06:24 PM   #261
Spud Rider
Spud Rider's Avatar
Oddometer: 3,809
I recently made the following post in the XRL Owners Sign In thread.
Originally Posted by rallyeman View Post
Hi Guys,
I have to confirm that the subfram of the XR650L is solid with the Twisted Throttle reinforcement! I rode 8000 km of african punishment with 200 lbs of luggage!
I did not ride easy as well, jumped, wheelies, etc
Originally Posted by Spud Rider View Post
Thanks for reporting in, Patrick! I hope you are continuing to recover well from your collison in Africa.
You have certainly proven the Twisted Throttle braces give added support to the bike's subframe. The stock subframe would have certainly failed under those loads and riding conditions.
Spud
Attaching a subframe brace to the swingarm would undoubtedly be strongest. However, I believe Patrick Trahan has proven the TT braces greatly strengthen the subframe of the XR650L. Others have reported the CycleRacks rack alone will support large weights without damaging the subframe, and it attaches to the same points as the TT braces.
Personally, I much prefer my ManRacks RotoPax rack to the overly large CycleRacks rack. I also think Mike's modified Spud Struts will greatly reinforce the bike's subframe, yet will be lighter, and probably less expensive than the TT braces. In any event, it's always nice to have choices. Therefore, as soon as I complete the top end rebuild on my engine, I am going to help Mike develop a prototype for a modified Spud Strut.
Spud
Old 11-30-2011, 06:38 PM   #262
jungleplant OP
Motorcyle Stuff
Oddometer: 1,858
Mike B
should help bunches, just in case
http://youtu.be/pBU5e2HqcrA
www.manracks.com
Old 12-01-2011, 04:29 AM   #263
cyclewizard
cyclewizard's Avatar
Oddometer: 4,814
Originally Posted by Lonestar2112 View Post
I do electrical sh*t, not this mechanical stuff. I have a tough time remembering lefty loosy, right tighty.
Isn't it easy peasy, just three pieces of aluminum, drill some holes. Sheesh you mechanical types. I mean its not like its an electrical problem, now those are tough.
C-dub......
Powered by CW-Pistons/cams
Wizard manufacturing....
cyclewizard is offline   Reply With Quote
Old 12-01-2011, 04:36 AM   #264
cyclewizard
Oddometer: 4,814
thanks mike
These braces are down right awesome JP....I wouldn't worry about the minor inperfections on the stainless they look good the way they are, I like the looks of em..
I'll take a bunch at dealers cost..
C-dub......
Old 12-01-2011, 04:40 AM   #265
cyclewizard
Oddometer: 4,814
Thats all you got big man
don't be holding any of those pics back on us now can you toss in a few pairs of titties
No shit lets see em gawd damnit..
C-dub......
Old 12-01-2011, 04:34 PM   #266
techforlife
CDI REPAIR
techforlife's Avatar
Oddometer: 4,330
Almost as bad as witholding camshaft porn pics eh CW.......
I need some cam porn,,,so spit some out gawd damnit...or i`ll get you barred from Tim Hortons till you do......
F........you are a bigger tease than my wife,,,
B
techforlife is offline   Reply With Quote
Old 12-01-2011, 07:02 PM   #267
jungleplant OP
Motorcyle Stuff
Oddometer: 1,858
SPUD is on the case
we just had a 5 way linkup with the other top Ruler's of the world and they all agree that the SPUDster is the MAN
and he will come through in our time of need , lucky we had a camera man there to capture spud at work
www.manracks.com
jungleplant screwed with this post 12-01-2011 at 07:08 PM
Old 12-01-2011, 07:14 PM   #268
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,515
If Spuds is Him , Than I am Nicoli , Ok Trivia Peeps , who is Nicoli ?
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 12-01-2011, 07:25 PM   #269
jungleplant OP
Motorcyle Stuff
Oddometer: 1,858
www.manracks.com
Old 12-01-2011, 07:31 PM   #270
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,515
Uh Uh Uh ,
Marko
Times are GMT -7.   It's 07:13 AM.
