Old 04-13-2012, 08:27 PM   #646
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,029
Mike, I will be PMing you for a center stand next week. It would be a nice addition to my L
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 04-13-2012, 08:59 PM   #647
Cigar Mike
Too Old and Too Slow
Cigar Mike's Avatar
Oddometer: 1,461
Be patient, I am about three weeks behind. I have been sick this last week, which hasn't sped things up any. I have been working on my bikes when I feel good enough to go out. I haven't looked at a centerstand in a week unless it was on one of our bikes.
Mike
When in doubt, give it Gas!
Cigar Mike is offline   Reply With Quote
Old 04-13-2012, 09:16 PM   #648
Lonestar2112
scatology expert
Oddometer: 7,029
Mike
Mike, not in a real hurry, just want to be on the list before you quit making them.
F*CK CANCER
Old 04-14-2012, 07:55 AM   #649
jungleplant OP
Motorcyle Stuff
jungleplant's Avatar
Oddometer: 1,843
Mike is mad at me. He gives me this great stuff and then wants me to take pictures instead of
He are the best/finest accesories you will ever buy for your L. How do you mount your Giant Loop?
Here you go!
A little hard to see, yes, it is nicely hidden in plain sight.
On the other side......
Again up close and personal.....
I have found these to be a solid point to secure any number of things. Bungies, pull straps etc.
Sorry for the delay Mike. I am off to WAPRED I'll have a and a for you.
If you look closely, you can see that the L is in the back of my truck. I did a fit check for DRZ400 and for the XR400 both fit, no pictures. I will post those up next week.
thanks for the pic lonsestar have ya got any actualy working or like doing there job with a strap in there
www.manracks.com
jungleplant is offline   Reply With Quote
Old 04-14-2012, 01:53 PM   #650
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,461
I hope this is OK.
They do work on other models also.
Mike
Old 04-14-2012, 02:09 PM   #651
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
I hope this is OK.
Mike
those are great pics but do you guys use ZOOM lenses at all
www.manracks.com
Old 04-14-2012, 03:33 PM   #652
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,461
Of course we I do. I couldn't get the centerstands in the picture if I did that.
Mike
Old 04-14-2012, 08:24 PM   #653
Spud Rider
Spud Rider's Avatar
Oddometer: 3,758
Mike
Duh!
Spud
Old 04-14-2012, 09:14 PM   #654
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
www.manracks.com
Old 04-15-2012, 03:37 PM   #655
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,461
I think this will work
Here is what I came up with.
I was thinking it might be a good idea to pick the seat bolt up also. I believe it would make the strut a lot stronger.
It is not a problem just slipping into place and making up the bolts. I believe that this design would allow the strut to be used with most if not all aftermarket pipes.
The left side works as designed. It appears that the left could be a mirror image of the right and would bolt on very easily. I would prefer this if I had a choice.
I did not slot the bolt hole for the mounting at the foot peg but it would be a good idea so that the strut where it crosses the frame can make contact there to remove flex from the strut.
I was also thinking that if a connection was attached at the seat bolt so that tension could be added there. You would be able to preload the strut so when it did start to flex under weight it would actually be returning to the resting position which would reduce metal fatigue. I am not an engineer so that might be a bunch of crap. I have an idea for a simple design if it is a good idea.
I welded the pieces together but Mike has better fabrication equipment and will be able to make the pieces without welding anything together if he chooses to.
Cheers,
Mike
Cigar Mike screwed with this post 04-15-2012 at 04:40 PM
Old 04-15-2012, 07:08 PM   #656
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,461
Not acceptable
I just got done talking with jungleplant and I was informed that it was a beautiful design. He said it would be perfect after I completely redesign it to specifications I was unaware of. No worries, I have the technology. After being a steamfitter for 40 years. I have done so much for for long with so little I am now qualified to do anything with nothing.
Seriously, I think we are pretty close now that I have received some clarification.
Cheers,
Mike
Old 04-15-2012, 07:23 PM   #657
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
Cheers,
Mike
Actually Cigar did call me , and interrupted my BBQ, and Giants game , he then proceeded to email me to no end
with this great idea , he thought he stumbled upon
,,,,,,,,OH SHIT had to put my beer down, my god he gets it , wont be long now guys
the cigarman is on the case Thanks mike
www.manracks.com
Old 04-15-2012, 07:42 PM   #658
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,429
9 - 11 rita s deee-p
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is offline   Reply With Quote
Old 04-15-2012, 07:51 PM   #659
jungleplant OP
Motorcyle Stuff
Oddometer: 1,843
biggie did ya finally get out of jail, where ya been
www.manracks.com
Old 04-15-2012, 08:10 PM   #660
Cigar Mike
Cigar Mike's Avatar
Oddometer: 1,461
The first liar doesn't have a chance.
Mike
Times are GMT -7.   It's 03:44 PM.
