Old 08-28-2011, 07:20 PM   #1
walstibsf OP
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
New ADV 990 OVERHEATING
Hi, gang. Really concerned here. My second day out on the NEW 990. Took pavement home yesterday from the dealer and took it easy on the bike whilst varying the load and gears...etc. At about 150 miles on the odo, today, I decided to take an easy forest road back home. Uphill, twisty, but not tight: 10-20-30 mph. 90 degrees ambient temp. 3/4 the way to the crest(10 miles in or so) the temp light comes on. Coolant level OK. Fan(s) on What to do? so I stop in the shade and point her into the breeze and let her idle for a few minutes. Light off, So I continue. Just shy of the top, light comes on again, so I head for the down hill(100 yds away). As soon as I get some speed on the downhill, temp light off, and stayed off.
Got home and looked in the owner's manual. It don't say crapola about what to do if you experience the temp light. It just says its there.
1. have any of you had this?
2. what is best to do if this happens on the trail?
3. Could this new bike still be just tight and not ready for a mountain?
Thanks and laters....
Bobby
W A L S T I B........ S F......................
what a long strange trip it's been......SO FAR......
walstibsf is offline   Reply With Quote
Old 08-28-2011, 07:23 PM   #2
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Outside of a major problem that you should have a Dealer work with, here is the link for the Burping Process...you may have an airpocket in your cooling system:
http://www.advrider.com/forums/showt...4#post13432304
Hope this works for you...
AdvGa is offline   Reply With Quote
Old 08-28-2011, 07:48 PM   #3
slowinfastout
Just Ridin' By....
slowinfastout's Avatar
Oddometer: 1,762
Agree, probably some air in the system. I've noticed on my 2011 990 a number of questionable factory build items on the bike, including a number of finger-tight fasteners.
I did put the second fan on my bike, and its never gone over 6 bars since...
slowinfastout is offline   Reply With Quote
Old 08-28-2011, 07:53 PM   #4
walstibsf OP
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
Slowin, was the xtra fan mod extensive? Thread here somewhere?
Thx 4 your reply...
Old 08-28-2011, 08:11 PM   #5
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here's the link to the Dual Fan setup:
http://www.advmachines.com/category_s/93.htm
http://www.advrider.com/forums/showt...=465977&page=6
Old 08-28-2011, 08:19 PM   #6
slowinfastout
Just Ridin' By....
Oddometer: 1,762
Easy mod, about an hour to do. Around $ 100 for the kit, well worth it for the bracket. Prior poster has the link.
Duane
Old 08-29-2011, 12:15 AM   #7
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
Duane
+1
I have it too. very happy with the mod
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 08-29-2011, 01:53 AM   #8
Deviant666
Present
Deviant666's Avatar
Oddometer: 534
Thx 4 your reply...
I have a 2009 990 and live in Greece (quite a hot place, especially these days..) and never seen the temperature light. I ride the hell out of it in heavy traffic too and have just one fan (factory) set up. The temp always gets up high when it idles but never overheats (no light nor the two last temp bars on the instrument panel). Imho you first need to break-in your bike (again imho do it aggressively from the start) and after first service see if it still overheats. Hopefully it won't. About the second fan, it's great (from what I hear) but in your case it'll mask an existing situation, I'd rather short that out first before any mods....
Deviant666 is offline   Reply With Quote
Old 08-29-2011, 06:51 AM   #9
walstibsf OP
ADVENTURE-HOLIC
walstibsf's Avatar
Oddometer: 212
So, from what I understand, if the cooling system has air in it, it is not moving coolant and the pump is cavatating sometimes, alot of the time, or all the time? One symptom is the level in the remote coolant reservoir has never changed.
Old 08-29-2011, 09:51 AM   #10
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Agree on both the burp and the second fan. Worked for me!
I also have noted a number of finger-tight (or looser!) fasteners off the showroom floor and HIGHLY recommend you spend some time with the tanks off checking the important ones....
As much as I love Wretched, she sure ain't a Honda! Check everything, multiple times, often.
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 08-29-2011, 12:31 PM   #11
kelly duke 2000
Closed, Gone Riding
kelly duke 2000's Avatar
Oddometer: 479
I have an 06 and ride sand in the summer in fl and never had the overheat light come on. Single fan and run engine ice premix, but I'd definitely try what the other guys said about burping the system.
Something is wrong there.
SAND... It's whats for breakfast.
kelly duke 2000 is offline   Reply With Quote
Old 08-29-2011, 01:15 PM   #12
Tirespin
Tirespin's Avatar
Oddometer: 233
In the conditions you describe the bike should not have overheated. Something is wrong, I suspect the cooling system needs burping. If it's new you should go to the dealer and have them fix it. A second fan is a bandaid for your actual problem, and would only be needed for higher temps, slower speeds, and steeper hills. Get the root problem fixed first.
Skip 2010 KTM 990 Adventure R Fuel and Maint Log
Tirespin is offline   Reply With Quote
Old 08-29-2011, 02:00 PM   #13
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Wicked Burp' it then blow on it
your owners manual shows how high one must lift the front end to get the air out... about 25"! If you don't know about http://www.ktm950.info/ which is the best of Orange Crush distilled essentially then you need to get over there now... many many tips & how-to's...
Seeing as how you live in Arizona (TOO Hot) I'd be buying a 2nd fan kit, and perhaps more importantly, the fan switch that turns the fans on at a lower temp. I did both at the same time on my 950 & it changed everything related to temps riding slow(er) in the single-track & tight stuff you find here in West Virginia. The 2nd fan comes one with the first and doesn't run as long as one does to bring the temp down.
Ken is the guy to go to at Adventure Machines on this, though you could search our forum & find ways to do it yourself. I like his bracket so I didn't do it myself this time... looks good, fits well and left me time to ride
Our engines live in a sea of plastic and need air movement to cool, the combo of these two (plus your system being free of air pockets) will be your long-term solution.
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician screwed with this post 08-30-2011 at 04:53 PM
geometrician is offline   Reply With Quote
Old 08-29-2011, 03:09 PM   #14
Schannulleke
Oddometer: 208
Originally Posted by tirespin View Post
in the conditions you describe the bike should not have overheated. Something is wrong, i suspect the cooling system needs burping. If it's new you should go to the dealer and have them fix it. A second fan is a bandaid for your actual problem, and would only be needed for higher temps, slower speeds, and steeper hills. Get the root problem fixed first.
+1
Schannulleke is offline   Reply With Quote
Old 08-29-2011, 03:39 PM   #15
Orange Toaster
Orange Toaster's Avatar
Oddometer: 113
Warranty
If it is brand new then it's covered by warranty. Stop worrying and call the dealer, it should be his worry.
Good luck
OT
'03 KTM 950 Adventure
Orange Toaster is offline   Reply With Quote
Times are GMT -7.   It's 06:15 AM.
