Old 08-29-2011, 01:20 PM   #1
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,095
Hodakaguy's "Twist-A-Plate" - Rotate your Dual Sport Plate
The Twist-A-Plate is designed to allow you to run your plate in the Vertical position when off road and in the Horizontal position when on the road to remain legal, now you can be Legal when you need to be! The plate is pre-drilled and ready to mount onto all KTM's with the Euro LED tail light assy, should also work great on the Husabergs with the same Euro Tail light setup. (Can be used as a universal setup on other bikes as well if you drill the corresponding 3 mounting holes onto your existing plate bracket) Each Twist-A-Plate comes with stainless steel mounting hardware and detailed mounting instructions, mounts up in just minutes!
The Twist-a-plate is made from high impact UV stable ABS plastic that is very strong and durable. To rotate the plate you just pull the quick release pin, rotate the plate and re-install the pin....it's that simple.
This is my second generation Twist-A-Plate. My first test unit used embedded magnets to hold the plate, while it worked great it was less secure than the current version. The 2nd generation unit has a larger/stronger pivot assy as well as the quick release pin that adds extra security.
The Twist-A-Plate is $37 + $5 Shipping.
Here's a few shots of the assy mounted on my KTM 530XCW as well as a short video demo of the unit.
Here's a couple shots of the unit mounted on the bike
And within seconds your in the legal horizontal position.
From this
To This...in seconds.
And a short video demo of the Twist-A-Plate.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy screwed with this post 04-14-2012 at 11:46 AM
Hodakaguy is online now   Reply With Quote
Old 08-30-2011, 09:38 AM   #2
killurtv
free range moron
killurtv's Avatar
Oddometer: 640
Nice work!!! I am in for one for my 990A, I could use one before my plate disintegrates. Gravel has a way of chewing plates to little bits.
one day I will learn, until that day... fuck it.
2001 HONDA XR650R
killurtv is offline   Reply With Quote
Old 08-30-2011, 12:59 PM   #3
EdGear
Edventurer
EdGear's Avatar
Oddometer: 543
I could use a few of them.
Ed
2010 KTM 690 Enduro R
2006 KTM 950 Adventure S
2002 KTM 400/453 EXC
EdGear is offline   Reply With Quote
Old 08-30-2011, 07:40 PM   #4
Rootkiller
Rootkiller's Avatar
Oddometer: 372
Great idea!
Rootkiller is offline   Reply With Quote
Old 08-30-2011, 08:10 PM   #5
herrhelmet
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
How much?
Does the plate just lock into position with the magnets? The swivel obviously has some kind of an anchor bolt or pin?
If it's priced relatively cheap you'll sell a bunch.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 08-30-2011, 08:38 PM   #6
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,276
man that is slick as all hell!
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 08-31-2011, 07:54 PM   #7
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,095
Thanks for the comments. Not sure on pricing yet but I'm going to do my best to keep them affordable. I'm going to make a second version soon with a stronger rotating pin setup... I'll post up here with updates as they happen.
Hodakaguy
Old 09-01-2011, 01:52 PM   #8
grandpa_ken
grandpa_ken's Avatar
Oddometer: 225
One please! Great idea.
2009 BMW F800GS
2007 KTM 450EXC
grandpa_ken is offline   Reply With Quote
Old 04-14-2012, 11:48 AM   #9
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,095
I just finished the updated Twist-A-Plate design and now have them available for sale. I updated the original post at the top of this thread with current pics, pricing etc.
Hodakaguy
Hodakaguy screwed with this post 04-14-2012 at 11:56 AM
Old 04-14-2012, 11:51 AM   #10
BrainBender
Bounty Hunter
BrainBender's Avatar
Oddometer: 429
Question
Hodakaguy
Well, info please.
LESS SOUND EQUALS MORE GROUND!
2012 Ural Forest Fog Gear Up
2004 KTM 450 EXC
1997 Honda Gold Wing SE
plus a few other dirt bikes and quads
BrainBender is offline   Reply With Quote
Old 04-14-2012, 11:55 AM   #11
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,095
Originally Posted by BrainBender View Post
Well, info please.
Sorry I should have mentioned that I updated the original post at the top of the thread with the current info, pics etc.
Hodakaguy
Old 04-14-2012, 12:03 PM   #12
BrainBender
Bounty Hunter
Oddometer: 429
Thumb
Must have been doing it as i typed. I read the first post and it wasn't there,. Looks good, thanks.
2004 KTM 450 EXC
Old 04-15-2012, 08:27 AM   #13
BackCountryCruizer
Gnarled Adventurer
BackCountryCruizer's Avatar
Oddometer: 450
I'll take one
PM sent.
Four wheels move the body
Two wheels move the soul!
http://www.youtube.com/user/650tom
BackCountryCruizer is offline   Reply With Quote
Old 04-15-2012, 08:45 AM   #14
EdGear
Edventurer
EdGear's Avatar
Oddometer: 543
PM Sent
Old 04-15-2012, 05:35 PM   #15
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
sweet looking mount..
Can you provide a photo of the mounting plate and associated mounting holes for fitting on another enduro bike?
I would like to know if it will fit my TE630 ..
Also the dimensions or distance apart of the mounting holes and over=all dimension of the entire assembly?
14 Husqvarna FE 501 10 Yamaha FJR 1300 11 Husqvarna SM630
Fast1 is offline   Reply With Quote
Times are GMT -7.   It's 05:56 PM.
