Old 10-19-2011, 02:26 PM   #136
jake28
Riding to the horizon.
jake28's Avatar
Oddometer: 391
Ladies and Gentlemen,
I don't know Cosman Chris but I've learned a great deal from this thread. I just donated five dollars to the cause of building something original. Please donate what you can, even a small amount. The thread has over 16,000 views. Imagine if each view was an individual and over half of them could be motivated to move their right pointed finger and hit donate: crankshafts, ECUs and complete bikes would be raining down from the heavens, and we would all be here to see it happen.
Folks, help Chris out and learn from him (and one another) in the process.
2004 YZ250F Dirt/Motard 1982 XLFTCR500 Street Tracker 1997 XR600R POS
jake28 is offline   Reply With Quote
Old 10-19-2011, 04:35 PM   #137
Flanny
Flanny-it-up!
Flanny's Avatar
Location: Ottawa, Ontario, Canada, the World, the Universe
Oddometer: 2,738
In - donation made (not much, but as the previous post said, it will add up fast if many chip in).
Flanny is offline   Reply With Quote
Old 10-19-2011, 05:54 PM   #138
Ratski
Ratski's Avatar
Oddometer: 757
I have a quick question, is this design much different than the BMW front end (whatever it's called) and if so, how? Sorry if I'm missing something obvious. By the way, You are doing something many of us, including me, can only dream of. Keep up the good work. As soon as my budget allows there will be a donation from me coming your way. Thank you for explaining what and how you are doing in terms we can all understand.
edit: Now that I asked that question and Googled Telelever, I see the differences, sorry for asking a dumb question.
Ratski is offline   Reply With Quote
Old 10-19-2011, 06:51 PM   #139
scmopar
scmopar's Avatar
Oddometer: 245
made ny brain itch but thanks fer educating me.Do you have a top or front view, I'm tryin to wrap my noggin around it thanks
It was no time for supineness and lamentation - every energy of the soul had to be exercised, -Tarleton Brown
scmopar is offline   Reply With Quote
Old 10-19-2011, 08:36 PM   #140
CosentinoEngineering OP
Oddometer: 183
geode, be careful, i still have my BP 2hp machine but look at how deep i'm in now!
Chris
moto2-usa.blogspot.com
Check out my products 10% off for ADV rider members
CosentinoEngineering is offline   Reply With Quote
Old 10-19-2011, 08:44 PM   #141
Oddometer: 183
ratski,
BMW's telelever is one of their older front ends that is a copy of work done by Saxon-Motodd in the 80s and 90s. You can see a lot of various designs at http://www.tonyfoale.com/gallery/FrontEnd/index.htm.
Their newer front end on the K1200R is called, appropriately enough, the Duolever and is a variation of the Hossack style front end. It is a lot closer to Norman's original design than mine, especially with the scissor-style steering linkage. BMW got some static from the builder community by not acknowledging that their design was nearly an exact copy of the original Hossack. They have since relented and even had him as a guest to their GP tent at the 2007 Laguna GP. I met him there an we talked bike design for a while. He felt that BMW was on the cusp of entering and dominating racing. He made great front ends but I guess you can't hit them all.
Chris
http://moto2-usa.blogspot.com/
Chip in and help!
Chris
Old 10-19-2011, 09:29 PM   #142
KZJohn
KZJohn's Avatar
Oddometer: 336
First I would like to echo some of the other members by saying thank you for sharing this whole process with us. I find it is waking up parts of my brain that have been dulled by my fold tab A into slot B job.
Now some questions;
1. Are the upper and lower control arms equal length and will the rake/trail stay consistant through full articulation?
2. Are the braking forces separated from the suspension movement?
3. If the front suspension is very rigid and the frame is just as rigid, what kind of side loading will the front tire be subjected to while turning? ( Would it cause a "hop" or "chattering" while exiting a corner under hard acceleration?)
4. If you connected one side of the lower control arm to a torsion bar and relocated the hydro damper to the lower frame rail below the control arm,(in extension), would there be a noticeable drop in weight, center of gravity?
5. Would radiant heat adversly affect said damper in that location?
Just some thoughts.
1976 KZ900A4
1985 CR250R
2006 CRF450X(Baja ready baby!!)
Team Hammernutrition/T&S Motorsports
KZJohn is offline   Reply With Quote
Old 10-19-2011, 09:33 PM   #143
RecycledRS
Along for the ride
RecycledRS's Avatar
Oddometer: 1,039
donation
I'm in.
_____________________________________
"There's a fine line between a shearing and a skinning"
RecycledRS is offline   Reply With Quote
Old 10-20-2011, 01:00 AM   #144
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,472
I'm in for $50 to get the t-shirt. When my ship comes in I want my name on the cases!
Gregor
PS Chris has started a thread for technical questions about general fabrication and building so check that out and spread the word: Some Advice Required?
sakurama is online now   Reply With Quote
Old 10-20-2011, 10:22 AM   #145
Oddometer: 183
scmopar, there's more images on the blog and at the website: http://www.cosentinoengineering.com/moto2/index.htm
Chris
Chip in and help!
Chris
Old 10-20-2011, 10:34 AM   #146
Oddometer: 183
KZjohn,
No problem, it's nice to have an audience!
To answer your questions:
1. They are unequal length and trail changes slightly. I don't care about rake angle as that is not a main controlling factor for handling, trail is what I am concerned with.
2. I do have some dive but not as much as telescopics. So no, they are not completely separated. Having a FFE does not automatically mean anti-dive. I could set it up to have more dive than teles if I wanted to.
3. The chassis is rigid and the upright legs are stiff in the braking direction but I never said anything about lateral leg stiffness. There is definitely a need for lateral wheel compliance for absorbing bumps when leaned over but I feel using the frame for that is not the best way to go about it. With my front end arrangement I can have less lateral than longitudinal stiffness by having non-round upright legs, which I do.
4. Yes, switching to a torsion bar in the lower arm and relocating the damper lower would result in a lower C of G but not likely a decrease in overall weight. However a low C of G is not necessarily a good thing. It would also require a stronger control arm as it would now be loaded in bending, not just compression.
5. Hard to say if heat would be an issue. A small air gap and a cooling air stream go a long way. Ducati's 999 and later models have the rear shock right next to the exhaust pipes and seem to suffer no shock overheating issues.
Chris
Chip in and help!
Chris
Old 10-20-2011, 11:42 PM   #147
Wheedle
I love inflatable fun!
Wheedle's Avatar
Location: Villa Rica, GA otherwise known as Ala-damn-bammer
Oddometer: 3,772
Originally Posted by thecosman View Post
KZjohn,
Honda tried the lower CoG thing with the 84 NSR500 GP bike, which had an upside down chassis. Fuel down low, expansion chambers sweeping up over the engine. IT was disastrous...
Where's Wheedle?
Life is short, Enjoy the ride!
- Todd Phillips
Ride in peace brother.....
Wheedle is offline   Reply With Quote
Old 10-21-2011, 12:14 AM   #148
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,788
Really depends on the bike though. I helped build a bike with a belly tank, and high exhaust, and airbox. It works wonderfully (wins every race)
Old 10-21-2011, 07:53 AM   #149
KZJohn
KZJohn's Avatar
Oddometer: 336
Forgive my uneducated musings, but some more thoughts/opinions;
The CG needs to be above the axles for a bike to act like a bike. There needs to be a certain amount of polar moment of inertia. I see it in my head this way, when a bike tips into a corner, the wheels are trying to run under the bike to keep it uprite much like a toddler will run to keep it's body under it's big head.
My thoughts about relocating the front spring/damper lower were more about centering the mass than just lowering the CG. From a rider's stand point,(where I have most of my experience), if you can lower and center the mass it will make the rider's job easyer to go faster with more confidence. I race dirt bikes over long distances and conserving my energy is a high priority. If I can keep the weight lower on the bike it takes less effort to transition from side to side. You can build the most advanced, kick ass bike ever to roll a wheel on planet earth, if the rider is uncomfortable or unconfident on it, it will finish last every time.
1976 KZ900A4
1985 CR250R
Old 10-21-2011, 09:32 AM   #150
z@ch
Turn it up to eleven
z@ch's Avatar
Oddometer: 4,738
Surely you jest!!
z@ch is offline   Reply With Quote
Times are GMT -7.   It's 01:08 AM.
