Old 11-23-2012, 11:22 PM   #76
BillMoore
BillMoore's Avatar
Oddometer: 63
Here's my setup. Hauling just the bikes:
Hauling 2 ATVs, 2 kayaks and 2 bikes:
Love the quality of the trailer. Light weight, and yet well built. Trailers very nicely behind the Nissan Frontier, even with the heavier load.
2010 KLX250S - FMF Q4, KDX 200 snorkle, Dynojet stage 2, Tubliss Tire System, Pro Taper Contour bars (Carmichael) with Pillow Top Lite grips, Burkhart 1.5" lowering links, Nomadic rack, IMS 3 gallon gas tank, Moose Racing handguards, MotoCentric Sport Tail bag and TCI windscreen.
BillMoore screwed with this post 11-23-2012 at 11:27 PM
BillMoore is offline   Reply With Quote
Old 11-24-2012, 03:23 PM   #77
mikesova
mikesova's Avatar
Oddometer: 1,378
After the trailer came home, I took some time to mock up the rack. It's a little short for the bikes to be under it, unless the handlebars could be pointing out the back of the trailer...out from under the rack. I need to research other strapping techniques.
2009 Kawasaki KLX250S
2001 Yamaha TTR125 (Wife's bike)
2005 Yamaha FZ6
mikesova is offline   Reply With Quote
Old 11-25-2012, 06:16 AM   #78
KHJPHOTO
Old Man and the Road
KHJPHOTO's Avatar
Oddometer: 465
Custom built out of "marine aluminum" to fit the rig.
KHJPHOTO
BMWMOA
BMWRA
IBA #27356
BMW Mileage Award 300,000 and adding to it
www.khjphotography.com
KHJPHOTO is offline   Reply With Quote
Old 11-27-2012, 10:42 AM   #79
mikesova
mikesova's Avatar
Oddometer: 1,378
The trailer deck is made of newer treated lumber. I pulled the screws out of it and where the screws were contacting the wood, they are rusting. So to protect my trailer from the treated lumber, I decided to paint the top/bottom/sides. I think I'm going to go get some counter sunk stainless screws to screw down the decking. No sense in letting the steel ones rust and break at some inopportune moment when trailering some precious cargo.
2005 Yamaha FZ6
Old 11-28-2012, 08:56 AM   #80
sierraoffroad
sierraoffroad's Avatar
Oddometer: 855
your screws may be rusting due to the chemicals used in the marine or pressure treated wood. spend the money and use galvanized, or stainless steel carriage bolts if you have the space to reach under the deck.
It's a Jungle out there.
2007 Blue Weestrom
2004 Yamaha Wr250f
sierraoffroad is offline   Reply With Quote
Old 12-24-2012, 12:14 PM   #81
HBL
Oddometer: 119
Hey BM, it looks like you have the bikes secured with some sort of fixed mounts? What is the product name and are they sufficient or do you supplement with straps? Thanks!
HBL is offline   Reply With Quote
Old 12-24-2012, 09:03 PM   #82
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,097
Originally Posted by Steverino View Post
Just redecked ours with left over bleacher aluminum planking. Added the box on the front and some motorcycle chocks from Harbor Freight.
Blast from the past, but I've been looking everywhere for aluminum bleacher planks but an coming up snake eyes. Ebay? Craigslist?
Where did you find this decking? New? Used? Spendy? PM me please if you don't want to get into too much detail, but I just removed the pressure treated 2x8x10' boards....all 240 lbs worth. There's gotta be a lighter way.
Good looking trailer!
Dirty
No, really, the mustache means I love you.
'09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167
dirty_sanchez is offline   Reply With Quote
Old 12-26-2012, 03:29 PM   #83
BillMoore
BillMoore's Avatar
Oddometer: 63
I'm using the moto-cinch (motocinch.com) setup. No straps, secures the bikes by the foot pegs. Also has a Velcro strap to hold the front brake on. Takes less than 5 minutes to load the trailer. I am very happy with the system.
Old 12-26-2012, 03:50 PM   #84
HBL
Oddometer: 119
Great, thank you for the response. This may be the key to getting the KLR650 and two KLR 250's on the dual Kendon with optional 3rd rail - no strap angles to worry abbout. Been searching everywhere for a pic of a similar setup but no luck so far - Thnaks again!
Old 12-26-2012, 05:30 PM   #85
BillMoore
BillMoore's Avatar
Oddometer: 63
Yeah, they are great for being able to stack bikes closer together. They use the same track as the airline l-track, so if you run a couple 4 ft strips of that, it gives you lots of loading options. If you order a set, check the height of your pegs and make sure you order the correct size. The first set I got were to long and I had to return them and get the smaller ones.
Old 12-26-2012, 05:51 PM   #86
Jnich77
Jnich77's Avatar
Oddometer: 303
El-cheapo harbor freight trailer, welded instead of bolted. Diamond tread deck and LED lights. Towed it all over the south east and out to New Mexico and never had a problem, not even a flat tire.
(truck has different rims now...lol)
Jnich77 screwed with this post 12-27-2012 at 12:22 PM
Jnich77 is offline   Reply With Quote
Old 12-27-2012, 03:07 AM   #87
nimrod
Pog Mo Thoin
nimrod's Avatar
Oddometer: 563
Tell me about those "tie downs" please.
In my dream, the angel shrugged and said if we fail this time it will be a failure of imagination
and then she placed the world gently in the palm of my hand.
B. Andreas
"Betweem two evils, I always pick the one I never tried before" -Mae West
nimrod is offline   Reply With Quote
Old 12-27-2012, 01:49 PM   #88
BillMoore
BillMoore's Avatar
Oddometer: 63
motocinch.com See the discussion a few posts above on this page for more info...
Old 12-28-2012, 07:27 AM   #89
mikesova
mikesova's Avatar
Oddometer: 1,378
I became bored in the garage, so I turned my tilt trailer/overhead rack into a convertible shelter last month:
2005 Yamaha FZ6
Old 12-28-2012, 08:32 AM   #90
sierraoffroad
Oddometer: 855
what is the yellow material you used to cover it?
2007 Blue Weestrom
2004 Yamaha Wr250f
Times are GMT -7.   It's 10:01 PM.
