Old 02-12-2014, 05:38 PM   #106
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 2,051
Picked up a 71 Monday and just started to look for build threads. Like what you're doing. Keep it coming.
John
Endeavor to suck less--Gaspipe
I would rather be riding an imperfect bike than waiting around for perfection. --JDowns
Sourjon is offline   Reply With Quote
Old 09-07-2014, 05:41 PM   #107
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Hillbilly Primary Shaft Slide Hammer
Back at it lately. To extract the primary shaft from a CB500 crankcase use the rear engine mount plus a 36mm socket. Place a washer on the nut to protect it. Replaces the official Honda primary shaft slide hammer removal tool. Problem solved.
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 09-07-2014, 10:43 PM   #108
PJay
Any bike, anywhere
Oddometer: 648
Here's my K0, first road registered in New Zealand late February 1971; I restored it in about 1996, IIRC.
It was a really good road bike, so I removed the lights and stands, put a 4-1 and a braided front brake line on it, did a bit of lockwiring, and took it to Phillip Island January 2003 when I was racing some real historic racers as well.
It was hilarious; WFO the whole time, did 2:10s, backing it into MG and buzzing down Doohan Straight with my left hand holding the fork leg....
Pete
Honda XL1000V, Suzuki DR650, Adventure Royal Enfield, OSSA Explorer, first model XL250, 9 other offroad, road, and roadrace bikes
PJay is offline   Reply With Quote
Old 09-19-2014, 07:03 PM   #109
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Great seeing the old bikes on the track pjay!
All clearances and specs are good, crankshaft bearings, ball and roller bearings, starter clutch, rods, transmission, shift forks, all well within specifications. No apparent significant wear on anything.
All transmission dogs and engagement slots show no wear or rounding. Amazing for an engine with about 31,000 miles, according to odometer, and unknown history, likely involving some hillbillies along the way.
Bottom end is now going back together with new OEM Honda seals, primary chain and cam chain, and then to be slung into the frame, the rest will be built on from there.
- Werner Heisenburg
Old 10-14-2014, 07:57 PM   #110
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Closeup of transmission.
Crankcase halves assembled.
Torqueing the bolts.
One bolt went in normally, finger tight, put the wrench on it, and it snapped before even starting to get tight. Must have fractured on removal and was ready to break.
Oh well, new bolt ordered, and back apart the crankcase halves come.
- Werner Heisenburg
Old 10-14-2014, 09:30 PM   #111
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,579
Good to see you back in the game, we're watching.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 01-03-2015, 04:30 PM   #112
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Back at it. That broken crankcase bolt was extracted and replaced, crankcase halves are now back together, again. Starter motor dissassembled, cleaned, inspected, continuity checked.
It was filthy.
New brushes and brush springs installed.
- Werner Heisenburg
Skowinski screwed with this post 01-03-2015 at 05:03 PM
Old 01-03-2015, 04:31 PM   #113
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Oil pump dissassembled, clearances checked, all ok. Reassembled with new oil pressure switch, 0-rings, and screws.
- Werner Heisenburg
Old 01-03-2015, 04:35 PM   #114
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Triple clamp assembly with new tapered roller bearings, greased.
Rebuilt forks with new Forking by Frank (Franks Maintenance and Engineering) chrome inner tubes installed.
Rebuilding the wheels is next up.
- Werner Heisenburg
Old 01-03-2015, 04:43 PM   #115
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Almost forgot, of course when the new drain bolt and washer (original bolt was butchered) was installed and torqued it stripped out the threads in the oil pan. I couldn't count the times I've ran across this problem with used bikes. It seems most that venture so far as to change their own oil feel it's necessary to reinstall the drain bolt like a gorilla would. Repaired the threads with a heli-coil insert and mounted the pan with a new 0-ring.
- Werner Heisenburg
Skowinski screwed with this post 01-03-2015 at 05:09 PM
Old 01-03-2015, 05:07 PM   #116
McJamie
STROMINATOR
McJamie's Avatar
Oddometer: 1,380
Or you are actually from Krypton, and just didn't know it.
If you get far enough away, you'll be on your way home.
Piss off, I'm in my Happy place.
McJamie is offline   Reply With Quote
Old 01-04-2015, 05:14 PM   #117
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Original front wheel on the bike.
Cleaned up hub and new spoke/nipple set.
- Werner Heisenburg
Old 01-04-2015, 05:19 PM   #118
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
Starting to lace up the hub to a cleaned up rim. Since this was a first time lacing up wheels, the order was a bit off and had to take some back out and start again.
Done.
Truing it up. Still working on that, it's a bit tedious for a beginner.
- Werner Heisenburg
Old 01-09-2015, 12:28 PM   #119
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
The rear wheel, sprocket removed and cleanup started. The old tire is from Sears, I'm sure that dates back a few years, and it appears to be made of hard plastic now. The spokes are toast, heavily corroded.
- Werner Heisenburg
Old 01-10-2015, 03:35 PM   #120
Skowinski OP
Deuterostome
Skowinski's Avatar
Oddometer: 5,636
The rear sprocket carrier is held on by the reverse-threaded stainless steel retainer ring with 4 holes in it. Honda used to make a special tool, of course. I went to Lowes, bought some stuff, and fabricated a tool, it got bent up getting the ring off, but worked.
For anyone else planning this, be aware that the damn thing is staked to prevent it from unscrewing... the only problem is the staking was done through the holes, and I couldn't see it. Didn't read about it anywhere either. I had no idea until it finally came off, so I basically was a gorilla on this one. The threads seem ok though.
- Werner Heisenburg
Times are GMT -7.   It's 05:59 PM.
