Old 09-16-2011, 07:03 AM   #31
arcanum
Oddometer: 317
Originally Posted by electroken View Post
That's a pretty standard centrifugal oil filer design for the early Honda twins.
Once the snap ring is out, you can thread a long M6 screw into the inner half of the centrifugal filter to help pull it out. A 40 year old o-ring will be fighting you the whole way. Coming up with the special four-fingered tool to remove the filter nut from the crank will be the hard part. There should be a locking washer staked in place under the nut that will have to be flattened before the nut will come off.
Well,the 4 fingered tool thingy is pretty easy. I took a 12 point socket of a suitable diameter,and simply ground away material away until the four points appeared. A 12 point works great simply because it is divisible by three,and that yields the 4 points that you are after...... MacGuyver lives!. The best way to describe what the special tool looks like is a castle nut with 4 points instead of six.
arcanum is offline   Reply With Quote
Old 09-16-2011, 07:07 AM   #32
arcanum
Oddometer: 317
Make sure that you use a thin cutting wheel on a 4 inch mini grinder. It can be a little risky, grinding into the end of a socket,so be careful
Old 09-16-2011, 10:13 AM   #33
rtw02
Oddometer: 324
Are you mad at me yet?
You better slow down or you will be done before Christmas...
rtw02 is offline   Reply With Quote
Old 09-17-2011, 09:53 PM   #34
anonny OP
What could go wrong?
anonny's Avatar
Oddometer: 5,736
Mad... hell no, you just keep finding treasures from my youth
This may be the last of it for a few weeks as work beckons.
Took the frame in for powder coat because my oven isn't big enough, meanwhile did some cleaning and coating at home.
cleaned up and ready to shoot
powder applied, ready for the oven
1st batch
2nd batch
Is the side stand supposed to have this curve in it? I kinda doubt it and should straighten before coating.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 09-18-2011, 07:46 PM   #35
anonny OP
anonny's Avatar
Oddometer: 5,736
Another couple of batches today, will be nice to get the cleaning behind me.
Got the new axle back for the centerstand/ rear brake lever, Lou did a nice job and made it out of stainless steel for me, not exactly stock but I don't mind improvements and I doubt many people will know.
Now I am stuck on the color for these, they came with the bottoms being black and the tops oxidized aluminum. Anyone know what color they should be?
Old 09-18-2011, 09:48 PM   #36
killfile
49/50
killfile's Avatar
Oddometer: 353
Hard to say, the 350s came with bare aluminum top triples and bare aluminum top and bottom bar clamps. From the picture I posted earlier, it looks like the 71 CL450 might have had black on the top triple, and top and bottom bar clamps?
No definitive answers here, I tend to do whatever I think looks best...
Looking good so far!
killfile is offline   Reply With Quote
Old 09-19-2011, 11:06 AM   #37
rgears
Oddometer: 44
Sorry it took so long, the building owners have been working on the entrance and I haven't been able to get into my shop for some time, but I was able to measure the headlight bucket last night. The OD is right at 7 1/8" on my 450.
By the by, Nice powder coating! I really should have looked into that before I went after it with the rattle cans...
rgears is offline   Reply With Quote
Old 09-19-2011, 02:22 PM   #38
Bobblehead
Bobblehead's Avatar
Oddometer: 99
Ummm fork soup, couldn't believe all the water that gushed out of the fork legs followed by the gooey mess
Thats about the end of the teardown with the exception of a few sub assemblies, now it's time to get to the real work!
Yeah, that's pretty standard. One bike I drained had water on one side, and what looked like unicorn blood from Harry Potter on the other--some sort of silvery oil, probably oil, water, and some metal mixed in.
Keep up the good work and keep posting pics, looks nice!
1970 CL350 * 1970 CT90 * 1984 CB700s Nighthawk
Bobblehead is offline   Reply With Quote
Old 09-19-2011, 07:59 PM   #39
anonny OP
anonny's Avatar
Oddometer: 5,736
Just for fun I changed out to a chrome powder, as you see it's more like polished aluminum but may be just the ticket for a guy who hates to polish.
I threw the uncoated sidestand spring in the pic so you can see the difference.
First finished parts
This is in the stripper pail as there are some flecks of schmotz that just won't do but if I can lay down a clean coat it just may do.
Old 09-20-2011, 01:38 AM   #40
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,249
Another outstanding job!
Old 09-21-2011, 08:21 PM   #41
anonny OP
anonny's Avatar
Oddometer: 5,736
Thanks bud
Another sub assembly out of the way
and getting close to obsessive compulsive
You have seen this brake plate before but it took 3 reshoots until I was satisfied, a whole lot of outgassing!
Old 09-26-2011, 08:55 PM   #42
anonny OP
anonny's Avatar
Oddometer: 5,736
Just incase you haven't seen enough powder coating
Watch this piece, we will see if it drives me outta my ever lovin
Front fork springs, brake lever and front axle.... done
Heres that cover again, still more to come
Most of the stuff above and the rear brake plate took 3 reshoots.... frustrating
and this is the defects I kept getting, it's like the aluminum is full of impurities despite my cleaning efforts.
Old 09-27-2011, 01:24 PM   #43
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,199
Nice work! How do you do powder coating at home?
"The atoms or elementary particles themselves are not real; they form a world of potentialities or possibilities rather than one of things or facts."
- Werner Heisenburg
Skowinski is offline   Reply With Quote
Old 09-28-2011, 09:15 AM   #44
Brad Felmey
Brad Felmey's Avatar
Oddometer: 5,002
By buying a powder-coating gun, powder, and pissing off the missus by using the kitchen stove.
In my case, I bought a used stove off CraigsList for $75.
Brad Felmey is offline   Reply With Quote
Old 09-28-2011, 09:25 AM   #45
anonny OP
anonny's Avatar
Oddometer: 5,736
It's a pretty simple set up and when I get time I will post some pics of my setup but basically I have a large(ish) metal cabinet as the spray booth where the hook the parts hand on is grounded to some ground rods.
The work piece hangs off the hook and i shoot with powder, when done I pop it into an old kitchen oveb I keep in the garagre for curing.
Times are GMT -7.   It's 09:49 AM.
