Old 04-06-2014, 09:18 PM   #15181
chrislitt
B-KTM-W
chrislitt's Avatar
Oddometer: 94
Great idea!!!
Originally Posted by BigDogAdventures View Post
I mounted my mondo moto LED's here----just had a straight piece of aluminum laying around. Works great.
I'ts mounted to the black bracket the turn signals are mounted too. Took me 5 minutes to make them.
BigDog
So much for my statement about it being hard to find a spot to mount the lights. I like that a lot. Thanks
Are these the lights you have?
MondoMotos MM10 Bullet LED Auxiliary Light Kit (V2)
They are affordable!
thanks again
Donate to your causes 'cause your enemies are outspending you! 2011 R1200GS Adventure,2009 KTM 300XCW, 2009 KTM 690R, Rotarian, Member of AMA / D36, NRA, CRPA, BRC, BMW MOA 174799. Happy to still be working though it interferes with riding!
chrislitt is offline   Reply With Quote
Old 04-06-2014, 11:07 PM   #15182
fluff34567
fluff34567's Avatar
Oddometer: 1,063
BigDog
And for those that dont have the mini R display and metal support ?
fluff34567 is offline   Reply With Quote
Old 04-06-2014, 11:48 PM   #15183
ktmmitch
Oddometer: 595
Originally Posted by Nowwhat View Post
Where is the locking ring for the preload adjuster?......
There is a locking screw in the adjuster ring, so no need for a separate ring.
ktmmitch is offline   Reply With Quote
Old 04-07-2014, 12:58 AM   #15184
palmstatecrawler
palmstatecrawler's Avatar
Oddometer: 485
That looks like a great mounting spot for the 2014s! Previous years flashers are not mounted with said bracket.
'13 KTM 690 Enduro R w/ full akrapovic exhaust, Evo1 lid, uni filter, Renazco seat, hard parts windshield and footpad, scotts damper with BRP submount, hammerhead shifter, flatlands skidplate, lost dog centerstand, Touratech engine guards, r&g front and rear axle and exhaust sliders, piaa 1100's, Doubletake mirrors, G2cam system,
'07 Kawasaki KLX250, '86 Yamaha BW80
palmstatecrawler is offline   Reply With Quote
Old 04-07-2014, 03:05 AM   #15185
gen
gen's Avatar
Oddometer: 800
A few photos of the Unifilter Australia air filter for the 690E. Does not have metal form inside and should be easier to clean? I trust the Aussies to make a good air filter as that country is dusty!
I am going to go with a Wings but not yet sure what I want to do about the airbox.
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 04-07-2014, 03:26 AM   #15186
Dotbond
Africa, Africa
Dotbond's Avatar
Oddometer: 765
Get it out the bag and show us some other photos of the inside of it....
2012 KTM 690 R
2010 KTM 990 R (Sold)
2008 N.Z.Yamaha Safari: http://www.advrider.com/forums/showthread.php?t=306905
2007 N.Z.Adventures Safari: http://www.advrider.com/forums/showthread.php?t=201557
Dotbond is offline   Reply With Quote
Old 04-07-2014, 04:18 AM   #15187
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 266
Originally Posted by MrHix View Post
Do they modify the stock cover for the auto clutch to have room? How much are they asking for it?
Thanks,
MrHix
As it was the first 690 they've done it was a bit of a test and trial with my bike, so they supplied me with a 1/16" clutch cover gasket and the new clutch cover cap for free, but I to machine the hole in the old clutch cover to allow for the cap. They were quoting $650 to do any bike, but that may change now if they are supplying a cap, screws and gasket.
I'll get me coat..............
Harty is offline   Reply With Quote
Old 04-07-2014, 04:53 AM   #15188
BigDogAdventures
Fart Letter
BigDogAdventures's Avatar
Oddometer: 4,964
thanks again
Yes-------that's the lites----MM10---very affordable and make daylight out of dark.
More about the bracket I made-----the bottom part of the bracket where it bolts behind the turn signal-------I cut a slot instead of just drilling a hole---that way you can just loosen the turn signal nut and slide the new bracket in there---------if you drill a hole you'd have to disconnect the turn signal wire to get it thru the hole------or cut the wires---this was much easier.
How I wired them in and everything else I've done to my 2014 is on my webpage here:
http://www.bigdogadventures.com/1KTM690.htm
BigDog
2008 Yamaha WR250R---by far my main bike.
2006 KTM 450EXC
2014 KTM690 Enduro--we'll see how good it is after 70,000 miles.
2013 Husky 650 TR650 Terra
I'm good--but I ain't no Dingweeds
BigDogAdventures is offline   Reply With Quote
Old 04-07-2014, 05:35 AM   #15189
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,669
Originally Posted by scholz View Post
As long as your posting videos it'd be hella appreciated if you could run though the RR manual cam chain tensioner install!
Ok. Next time I install one for someone I'll film it :P
Actually.. There's a guy I met in Chain Mai with a 2014 and he just got the cam chain tensioner in the mail... Let me send some emails. No promises though.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 04-07-2014, 06:13 AM   #15190
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,914
Do these bikes really need a manual cam chain tensioner? Have there been any reported stock tensioner failures on these bikes we know of?
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 04-07-2014, 06:56 AM   #15191
Bonerov
Damned dirty ape
Bonerov's Avatar
Oddometer: 434
Dirty
No clue how common it is, but mine just failed last week with about 8500 miles.
Bonerov is offline   Reply With Quote
Old 04-07-2014, 07:50 AM   #15192
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 266
I'm trying to bleed the clutch as per:
1) Remove clutch master cylinder cover.
2) Put small hose over slave bleeder valve and other end into empty jar.
3) Open slave bleeder valve and sqeeze clutch lever until it hits handle bar.
4) Close slave bleeder valve.
5) Release clutch lever.
6) Repeat steps 4 ~ 6 about 15 times until clutch lever feels good.
Where's the friggin slave bleeder located????
Old 04-07-2014, 08:01 AM   #15193
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,546
BigDog
I went with a set up like this: http://advrider.com/forums/showthrea...24319&page=207
See post 3101.
CanadianX is offline   Reply With Quote
Old 04-07-2014, 08:10 AM   #15194
BigDogAdventures
Fart Letter
Oddometer: 4,964
See post 3101.
Holy smokes--now those are going to light up the night.
BigDog
2006 KTM 450EXC
Old 04-07-2014, 08:15 AM   #15195
Sethro303
Master of Disaster
Sethro303's Avatar
Oddometer: 334
Who makes an auxiliary light mount that is held by the lower triple clamp bolts? Finding a spot for extra lights on the front of the 690 is not easy. I don't need the extra light as much as I am in the camp that more than one light in the front makes you more noticeable. Regardless, can someone point me in the right direction please?
Thanks!!
Happy trails makes the brackets that bolt to the lower triple clamp.
08 KTM 690 Enduro
http://www.urbandictionary.com/
Sethro303 is offline   Reply With Quote
Times are GMT -7.   It's 04:23 AM.
