Old 02-21-2012, 04:31 AM   #1786
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,730
the small extra bulb in the headlight housing is referred to as a city light. the purpose is to illuminate the headlight and make the car/bike a little more noticeable. the bulb will typically come on with the parking lights and the headlight. Its also nice to have in a car when the main bulb burns out because it keeps the car looking like a car instead of a strange motorcycle (at night). usually a 5 watt bulb.
I think they were an early version of a daytime running light before they were mandatory in some places at which time they just turned on the whole low beam.
Seth S
Seth S is offline   Reply With Quote
Old 02-21-2012, 07:21 AM   #1787
ram350
Oddometer: 19
in tank filter for 690
can someone give me a part number for an aftermarket in tank filter for the 690E. I think in the past there was a NAPA number posted.
ram350 is offline   Reply With Quote
Old 02-21-2012, 08:42 AM   #1788
Seth S
Seth S's Avatar
Oddometer: 4,730
You could eliminate the in tank filter and remove the quick disconnect fitting. In place of the quick disconnect install the inline napa filter. I have a couple at home...they were about $2 each....have to look for the part number
Seth S
Old 02-21-2012, 09:36 AM   #1789
bayarearider
Oddometer: 139
Originally Posted by bayarearider View Post
When riding back home from trails, I suddenly realized I lost my entire shift lever. I was on the freeway in 6th gear riding at 75 miles/hr when I realized this. I was able to make it home without having to stop. Can anyone tell me what other parts I need other than the shift lever ? I looked at the parts manual and this is what I found at least
KTM# 7623403100 - Shift lever
KTM# 75034032000 - shifting lever spring
KTM#54634031050 - bolt 6x25 for shift lever
Am I missing anything else ? Can I buy the hammerhead design lever above instead of the OEM one? Hammerheard doesn't list the same part number.
Can any one any help me with my question above? Basically the entire shift lever fell off and I am trying to gather all the part numbers for mounting it back . I have a dual sport ride scheduled this weekend and I dont want to miss on it.
bayarearider is offline   Reply With Quote
Old 02-21-2012, 09:59 AM   #1790
Scout_WY
Pirate
Scout_WY's Avatar
Oddometer: 118
can someone give me a part number for an aftermarket in tank filter for the 690e. I think in the past there was a napa number posted.
napa 3095
'08 690 Enduro
NRA life
Scout_WY is offline   Reply With Quote
Old 02-21-2012, 10:04 AM   #1791
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Pictures as promised for the Cyclops wiring.
I switched the wires to Ged's diagram and the low beam came to life. Thanks again Ged.
This is how it's wired now.
I also installed an Advmonster helmet light to the outside ring.
Here's the Led and high beam at the same time. The LED is running on the 8.something volt rechargeable battery pack in the photo. I'll have it wired directly to 12v soon and get some night photos if anyone wants to see them. Nice little light.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 02-21-2012, 10:34 AM   #1792
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Originally Posted by Mudguts View Post
I took mine off does not fit to my standards has to be mounted pointing too far down and the toe piece sat right on my toe nail after a days riding I could no longer change gears due to the pain , do plan to get some fastway adv pegs and put them on the low setting this may fix my issue with the hammerhead lever
Above is a review of the Hammerhead lever. I don't know If I want one now.
Here's the link for the lever. http://www.hdmoto.com/ProductDetails...uctCode=KTM1SL Hammerhead sells the bolt as well if you're in a hurry.
Here's the fiche for what you need OEM. Looks like #13-19 would cover you. http://partsfinder.onlinemicrofiche....=13&A=459&B=38
Old 02-21-2012, 11:41 AM   #1793
dguevin
Always ginger cravin
dguevin's Avatar
Oddometer: 19
Originally Posted by Scout_WY View Post
napa 3095
Just drove by Napa here in Canada !! they have dozen of them in stock !!! Bought one for 3.52$ and installed it where the quick disconnect was installed. Mine is solid(gold) casing. You guys have a clear casing on it ??? Kinda nice when it's clear but I guess I'll just replace it every 2-3 months considering the price
Dan
dguevin is offline   Reply With Quote
Old 02-21-2012, 11:48 AM   #1794
Mac
Mac's Avatar
Oddometer: 2,153
And while you're at it, check the side of that smaller hose for chaffing. Mine was worn about 1/3 through, where it rubs on the left upper tank bolt.
Mac
R1200GSA | 690E | 300XCW
RMAR President - Website FaceBook
Member: NRA, AMA, TPA, MSF RC
Mac is offline   Reply With Quote
Old 02-21-2012, 12:44 PM   #1795
Scout_WY
Pirate
Scout_WY's Avatar
Oddometer: 118
They make the same filter in the cleat plastic but I don't have that number with me right now.
'08 690 Enduro
NRA life
Old 02-21-2012, 02:33 PM   #1796
motoged
motoged's Avatar
Oddometer: 908
Barman,
Thanks for the wiring pic:
I have decided to forgo the 80/100 watt bulb for my Rally Light for the following reasons:
1) The ceramic pigtail plug I want needs to be ordered from the USA (2-3 week delivery);
2) Parts guy said , as have others, that I would also want to use heavier wiring and a relay....(My eyes glaze over when people start talking "electrospeak" ) and that can be a real hassle (ie. how far back in the wiring loom do I have to go?);
3) Parts guy says, "Why not just use one of these bulbs.....? I have them and they are fabulous..."
Wattage 60/55W = 110/100W ......(which I said was snake oil numbers, but I will try it...)
H4 Xtreme White Plus ANTI-VIBRATION
4) So I said....okay....as the installation will be MUCH simpler.....and it might be enough candlepower to shut me up....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 02-21-2012, 02:39 PM   #1797
motoged
motoged's Avatar
Oddometer: 908
Just drove by Napa here in Canada !! they have dozen of them in stock !!! Bought one for 3.52$ ...
$6.95 in BC...... tabernac, eh !?
Ged Schwartz
Kamloops , BC
Old 02-21-2012, 03:22 PM   #1798
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,209
I may have had bad luck and hope your experience with these bulbs is lengthier than mine.
2 of 3 popped within a year. Maybe 7k on f8gs and 2k on 690e. 3rd is in a less used street bike.
I did like the light while it was lit but be sure to keep a less $$ back up in your kit.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 02-21-2012, 03:45 PM   #1799
Seth S
Seth S's Avatar
Oddometer: 4,730
give the IPF Superclear bulbs a shot. Last about a year in my car and I have the headlights on all the time. Cost about $80 a set.
This bulb is an improvement to IPF’s existing Fatboy bulb by incorporating the latest in lighting technology that results in a brighter, but more efficient low and high beam. The Fatboy II Bulb uses an exotic high-pressure gas mix, coupled with a massive bulb envelope to create to unrivalled brilliance. The unconventional bulb shape provides less loss of light from the filament. A stabilizer rod within the bulb extends the life of the filament even in the harshest of conditions.There are two different color options available, Super Clear and Max White and both are available in pairs or as a single unit.
Seth S
Old 02-21-2012, 06:26 PM   #1800
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 770
Good idea to slide some PVC electrical flexy conduit over the fuel line where it rubs ( and also where it might)
Oz-Strom is online now   Reply With Quote
Times are GMT -7.   It's 07:38 PM.
