Old 04-06-2012, 12:29 AM   #2536
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Originally Posted by bayarearider View Post
I have a 2010 690 R version and wondering if there is any trip master switch available ? If not are there any alternatives available to install a trip meter ( other than the ICO trip meter) and a handlebar switch.
There is a tripmaster switch available.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 04-06-2012, 05:33 AM   #2537
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 259
But it is useless for rally purposes because you cannot adjust it while driving.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 04-06-2012, 08:49 AM   #2538
ghostridergary
Oddometer: 10
Oil screens - which way round?
Just servicing my 2008 690E and cleaned the oil screens... but on starting to put them back I just realised that the bore is wider at one end than the other... but didn't note which end was in the cap and which was facing into the engine when I removed them.
Anyone remember? Its not obvious from the manual or parts list.
It feels like wider bore end should be inserted into engine and narrower bore end into the cap/bolt
Gary
ghostridergary is offline   Reply With Quote
Old 04-06-2012, 11:21 AM   #2539
jonb
Montana Adventurer
jonb's Avatar
Oddometer: 284
2012 690 E Test Ride
The 2012s are here and I am considering one.
I wanted to see how it felt going down the road on asphalt at its cruising speed.
My impression is that with stock gearing and the MT21s that you would be working it pretty hard cruising over 70mph for hours.
They seemed to forget about the gear ratios. First may be little high and 6th a little low for me. At 70 you're sitting high on dirt bike getting blown around.
I am concerned about making this my go everywhere bike. The seat is an improvement but in true KTM fashion you are sitting on top of a heavy dirt bike holding on to a bike at 6200 rpms going down the highway.
Are most of you sticking to stock gearing?
What RPM are you comfortable cruising going down the slab for an hour lets say?
Appreciate your experience with the gearing input.
JB
jonb is offline   Reply With Quote
Old 04-06-2012, 11:44 AM   #2540
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,877
My initial impression was similar to yours. Felt like the engine was spinning a little fast at 75. I tried going one tooth bigger in front. Big mistake! It made first gear unmanageable. Being able to short shift, while spinning the clutch a little, from first to second in the rough stuff is very important. Higher gearing just doesn't work. Put it back to stock and have never looked back. Once I got my head dialed into cruising at a little higher rev, it doesn't bother me a bit. Highway speed all day is just fine. Another thought, if your test bike was new, the motor may not be broken in well enough to smooth out at higher revs. Just a thought.
690 is by far the best ever, go everywhere, do everything well bike I've ever owned. Wouldn't trade it for any other motorcycle.
R-dubb is offline   Reply With Quote
Old 04-06-2012, 11:58 AM   #2541
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,734
FYI. I was about to pull the trigger on this...
http://www.earthxmotorsports.com/pro...products_id/27
Turns out that the stock battery has 190 CCA, this one only has 120 CCA. Since I ice ride with the 690, it won't work well if at all.
They also have this, 240 CCA, I was ready to pull the trigger on it too...
http://www.earthxmotorsports.com/pro...roducts_id/182
It would work, except that it is 20mm taller than the stock battery, and I can't see how there would be room for it.
The guy on the phone told be that they have another design/ size with similar power, but an appropriate size for the 690, coming out in May. I gave him my email, and hopefully I'll hear from them when it's ready.
BK.RD.RNR is offline   Reply With Quote
Old 04-06-2012, 11:59 AM   #2542
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I went +1 on the rear and I can cruise 70-75 comfortably. I did install a set of MT90's and they look like a taller tire which pretty much negates the +1 rear... Anyway, the engine is fairly comfortable slabbing.
Most of us don't have tachs. Gearing Commander shows my setup at 72mph the engine is turning 5250rpm. You've got another 3000+ till redline.
Old 04-06-2012, 12:01 PM   #2543
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
If you're in a pinch I've got the stock battery just sitting here. Only used it for a few months.
Old 04-06-2012, 12:09 PM   #2544
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,734
Thanks. I'm OK for now, but either mine is starting to lose it's luster, or the shop that did my head gasket last time failed to install the decompressor properly. I could not find a loose ground/ connection, but she hesitates usually when starting, then the FI and Battery light come on briefly and go out after it starts. It never happened until I got it back from the dealer. That was last summer, it's still working, although I did have to jumpstart the bike last January in NH at an ice ride.
Old 04-06-2012, 12:35 PM   #2545
wiswoodsguy
Kmart shopper
wiswoodsguy's Avatar
Oddometer: 2,102
OK I need some help or some insight at least
I have about 200 miles(thats 200 total miles) on my new to me 2009 690R. Its been updated/modded as it should, Leo Exhaust, 3 different FI maps to choose from, stock gearing as far as I can tell (PO blinged out the rear cog) and a few other eyeball goodies. I havent dug into the depths of the bike to get all the facts - but this is what I can tell from the exterior inspection. Bike came to me with 79 miles on the clock and varnished up fuel from a year of sitting (PO died doing what he loved - desert riding)
Anywho - my question is ??: Will I notice considerable gains once this motor is further broken in ?? I hear fantasy stories of owners not being able to keep the front end on the tarmac - mine struggles to loft over a puddle in 1st or 2nd. It feels like it has power - but has issues putting it to Earth.
I have the bike set up fairly stiff for my 205lb 6' frame - suspenders are stock with all the settings clicked out to 12 all the way around (my baseline so far - stock was 15 clicks on everything) Sag is a little stiff at 360mm, prob dropping down to the recommended 320ish (3") - but want to see how it reacts with passenger aboard ( skinnywife)
Im coming off a 520 EXC with monster torque and can hardly keep the front end on the floor in 4th. I assumed the 690R would share some of these characteristics - just not seeing them yet.
Clue me in kids - make me love this bike more
wiswoodsguy is online now   Reply With Quote
Old 04-06-2012, 03:48 PM   #2546
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 996
KTM part #54814073000 "Tripmaster Switch EXC 2005" works with the 2009 (no tach) 690r speedo, but I cannot verify if it is the same for the 2010.
The Letter J is offline   Reply With Quote
Old 04-06-2012, 03:58 PM   #2547
Uller
Uller's Avatar
Oddometer: 1,678
I'm getting this weird start issue too. I can't figure out what the issue is. My 690 hasn't ever failed to start though, which is a plus.
Uller is offline   Reply With Quote
Old 04-06-2012, 04:00 PM   #2548
Uller
Uller's Avatar
Oddometer: 1,678
I think anyone considering a LiFeP04 Battery should read this thread (especially if it is a Shorai).
http://advrider.com/forums/showthread.php?t=770364
Uller screwed with this post 04-06-2012 at 04:08 PM
Old 04-06-2012, 04:17 PM   #2549
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,648
Make sure you have the ignition map switch set on 2
Old 04-06-2012, 04:53 PM   #2550
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 910
what gearing do you run?
clean filter?
dont expect it spin up as fast as your 525. longer stroke i bet
i have a 550 berg and dont try to compare the two.
that said the 690 is very fast, pulls good everywhere and has given me many smiles in 8k miles
I raced it at last years KOTW and it was a handful is some parts but just right for a lot
if you were varnished up might want to ck the injector. a perfect spray pattern is critical. once the fuel issues are sorted out you may want to play with tune ecu or i hear the vortex works great with no thought process. they did all that for you
mine will let me see jesus anytimne i dial the right hand
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
