04-19-2012, 08:58 PM
#2716 | |
Safari Scramble!!!!!
Oddometer: 3,193
also...fuel can shuttle back and forth between the tanks. you might double check that fuel is flowing smoothly from the adapter on the bottom of your stock tank
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
04-20-2012, 02:47 AM
#2717 |
"Racin Mason"# 4
Oddometer: 1,392
Anyone else have trouble with battery operated gps , works fine on my other bikes but the vibes on the 690 must shut it down- also speed wobble coming onto a motorway on ramp at about a 100k's under power I have had to install a scotts damper and today had to turn the dial up as it slightly happened again
thanks |
04-20-2012, 03:18 AM
#2718 | |
Oddometer: 4,900
Try sticking some foam ear plugs between cover and battery to lock it in place.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
04-20-2012, 04:28 AM
#2719 |
"Racin Mason"# 4
Oddometer: 1,392
Thanks - great idea
04-20-2012, 06:59 AM
#2720 |
Got Out
Oddometer: 607
Battery question.
When I hit the starter It turns over one chug, delays a half second, then cranks and starts. This seems like a recent developement. I think it does it when warm and cold. voltage test 12.7 after sitting over night, 14 at idle. Is my battery weak? Is my starter weak?
KTM 690 Enduro R BMW 1200 GSA OhBoy screwed with this post 04-20-2012 at 07:10 AM Reason: voltage test |
04-20-2012, 07:06 AM
#2721 |
Oddometer: 200
clean the connections and see if it goes away. Could be a weak battery or failing cell - but you have to rule out the possibles with the easiest one first.
04-20-2012, 07:35 AM
#2722 | |
Got Out
Oddometer: 607
"I had the same problem with my 2009 model. It ended up that the compression release spring was not attached to the compression release. It was many trips before the dealer determined this issue, even though I suggested that the compression release might be the issue from the start (I'm not a mechanic). The kek kek sound I heard was the starter going out because it was not designed to turn over the engine under full compression." Could it be a compression release spring? Just found this at the other site Originally Posted by (editied out) I have a starting issue and wanted to know if you guys have experienced it. When the bike is warmed up or cold, it will (sometimes) barely turn over, like the battery is dead. Then always on the second try, it fires up, like nothing was ever wrong. I took it too the dealer which btw are the best I have ever worked with (Commonwealth Motorcycles located in Louisville, KY). They changed the battery, ran multiple tests and phoned KTM and nothing, the bike is perfect from that perspective. They did get it to happen 5 times while it was in the shop. However about every 3rd to 4th time I try to start it, it will just barely turn over. Once again, it ALWAYS starts on the second try, like nothing is wrong. Commonwealth thinks the bike is at top dead center when this happens which does not open the compression release. It does sound possible to me. They phoned two of their customers with the 690 SM (basically same motor/transmission) and they said the motor sometimes did not start on the first attempt with them either but I could not pin down if were talking about the same thing. Has anybody experienced this or should I ask for a new starter? Many, many thanks for any answers you can give me on this. Outside of this one issue, this is the most fun bike I have ever ridden. Deals Gap hear I come. Anyone here have similar experience? My 2010 is not the only one.
KTM 690 Enduro R BMW 1200 GSA OhBoy screwed with this post 04-20-2012 at 07:48 AM Reason: more info |
04-20-2012, 08:06 AM
#2723 | |
Way Offline
Oddometer: 1,162
![]() I'm doing a street ride today. I'll exhibit some control and see what happens.
I am at one with my duality. |
04-20-2012, 08:50 AM
#2724 |
Rookie
Oddometer: 265
The stock 950 speedo for an SE and the trip master switch that fits (same as for EXC bikes) makes you increase and decrease the trip2 values with tenths. Unfortunatly you can't do the reset from the switch. That must be done by stretching forward to the speedo itself. All other things not possible with the switch. I used this setup for two years.
04-20-2012, 09:00 AM
#2725 |
Oddometer: 166
WTB ** Wanted **
Hey Guys, I'm thinking I really need to add a 690 to the stable. I'm hoping the 690 will be a modern day XR650R.
If you know anyone selling one, please let me know. I also put an add in the classified: http://www.advrider.com/forums/showthread.php?t=782737 Thanks again ADV
2007 Super Enduro...Finally got another one & 2008 Kawi KLX 450 - Plated 2010 KTM 690R - Sold 2006 BMW R1200GSA - SOLD...Thank Goodness...I hated that thing. 2007 KTM Super Enduro - Sold - HUGE Mistake letting it go 2006 KTM Adventure S - Sold / 2007 KTM 950 Supermoto - Sold |
04-20-2012, 09:01 AM
#2726 | |
Torque Stick
Oddometer: 3,853
04-20-2012, 11:44 AM
#2727 | |
Oddometer: 558
You better not sell this one (once you find it.) The 950 is still doin' good. I'm almost done with its second down-to-frame recreation. |
04-20-2012, 01:29 PM
#2728 |
Way Offline
Oddometer: 1,162
Mine has been doing it since brand new. The engine just needs to bump past tdc sometimes so my impression is that it's a positioning issue and not a fault of the spring. I'll know in 2000 more miles when I do the valve adjust.
04-20-2012, 02:00 PM
#2729 | |
Torque Stick
Oddometer: 3,853
Mine NEVER did it in the first 23k ish miles.
04-20-2012, 02:11 PM
#2730 | |
Guns are for pussies
Oddometer: 13,783
The Vortex rocks the house compared to the stock abortion.It's like going from a CV carb to an FCR carb. Will you be doing the Ravena ride this year?
Just say'IN |
