05-02-2012, 04:29 AM
#2911 | |
Don't want a pickle
Oddometer: 125
It's good enough for me, the position is freely adjustable and it seems to stick there pretty well. And since the dock is small there's not too much clutter when you're not using the Zumo. Of course if you're mainly riding around an MX track you might need a stronger mount. ![]() The bar width is 1 1/8". I'm using 2" ROX Risers and had no trouble with cable length. The clutch side is tight-ish so I cut the original cable ties and did some re-arranging just to be on the safe side. I also rotated the throttle grip first but then realized there's no need for it, there's plenty of slack even in the original position. I'm 190 cm (6'3") and with 2" ROX Risers the riding position is OK for me. As for the exhaust...I have a titanium Wings waiting for installation so can't comment on performance yet. The quality of workmanship seems first-class as usual. |
05-02-2012, 05:32 AM
#2912 |
Kool Aid poisoner
Oddometer: 4,809
05-02-2012, 06:35 AM
#2913 | |
Oh!? That is deep.
Oddometer: 751
Oldbear, that's great info - thank you! Do you have a picture of the Zumo mounted up on your bike? I'll be running trails, not so much the MX track given my limited skill at soaring with the eagles though I suspect 'up' is easy but coming back down might be a bit messy
05-02-2012, 06:47 AM
#2914 | |
Torque Stick
Oddometer: 3,853
I like my solid Tusk risers from Rockymtnatv. Some have said the Rox risers will twist up in a light get off. I have had no worries with mine.
05-02-2012, 07:34 AM
#2915 | ||
Don't want a pickle
Oddometer: 125
![]() It's says BMW Navigator but it's the same as Zumo 660. Quote:
05-02-2012, 07:36 AM
#2916 |
Oddometer: 104
2012 KTM 990 Adventure R 2010 KTM 530 EXC |
05-02-2012, 07:39 AM
#2917 |
Way Offline
Oddometer: 1,162
Mefo Super Explorer
http://www.twistedthrottle.com/trade/productview/4808/
I am at one with my duality. |
05-02-2012, 07:51 AM
#2918 |
Don't want a pickle
Oddometer: 125
Here's the non-oval version of the Wings muffler (with a carbon fibre end-cap).
![]() Seems to weigh exactly 2 kilograms (4,4 lbs) with the large db-killer.
05-02-2012, 11:45 AM
#2919 | |
SE Asia adventure tours
Oddometer: 567
That sounds painful! I had some bars break on a mountain bike landing a pretty big jump. And on that note, my neighbor put some of those cheap chinese footpegs on his bike and one of them snapped off leaving a razor sharp edge that cut just above the achilles tendon and tore right up to the bottom of the calf. My wife had to rush them to the hospital - I actually didn't see it till it was all bandaged up. Not that absolutely proves the $150 Faast pegs are better but it just makes me FEEL better
05-02-2012, 12:16 PM
#2920 | |
Oddometer: 591
05-02-2012, 12:47 PM
#2921 |
Safari Scramble!!!!!
Oddometer: 3,193
I suggest you send the forks out for a respring and revalve and have them lowered in the process. Spend the money to set the suspension up correctly and get it the shorter height at the same time. Just swapping in a shorter set I think you will find they are too stiff for a smaller rider. Having a redone set of 690 suspension I can say its far better than either the stock E or R.
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
05-02-2012, 01:52 PM
#2922 |
Oddometer: 328
Handlebar rise
Does anyone know how much rise I can get before I need to start replacing cables and brake/clutch lines? I have a 2009 690r.
05-02-2012, 02:05 PM
#2923 | |
Oddometer: 3,193
2.5 to 3 inches is about how much you can get away with. You just have to flip your throttle over so the cable run out the bottom instead of the top.
05-02-2012, 02:10 PM
#2924 |
Dream Rider
Oddometer: 23
Bazza
Anyone had any experiance with the bazzaz ECU that has poped up on ebay ?
05-02-2012, 02:23 PM
#2925 |
Oddometer: 328
