Old 05-13-2012, 07:27 PM   #3256
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Originally Posted by bobzilla View Post
im not usually a quitter but it took almost 3 years to kick my ass
I almost threw in the towel until I decided to give it another go. It's running well at the moment
Just say'IN
crankshaft is offline   Reply With Quote
Old 05-13-2012, 07:38 PM   #3257
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I'm really liking my 690. Just a fun bike to ride and even though it does stall very occasionally I don't mind. Eventually I'll sort that out too. It's my lot in life I guess, the last two Yamahas I owned both were stallers.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 05-13-2012, 08:30 PM   #3258
andykeck
Oddometer: 106
Originally Posted by Velociraptor View Post
My bike usually starts on the 2nd or 3rd try with the Vortex. I emailed them about it and they said they were working on it. I might send it back to get reflashed one of these days.
Originally Posted by crankshaft View Post
Ah, that's good to know. I know it's the priming pulse for the cold start enrichment. I turn the key on, just stab the start button real quick. I do that 3 or 4 times and it fires right up. Basically like the old days when you gave the gas pedal three pumps before starting the car I'll call the Vortex folks and see whats up. thx for the heads up!
Hey, please post back if you hear anything about a new flash from Richard.
I had been having difficult starting back mid-winter, temps in the upper 30s or low 40s. It would take several presses of the button before it caught. Now with warmer weather, it always catches on the second press, but never ever the first press. I did a little experimentation with the injector in a bucket and found that the Vortex seems to only spray fuel once per ignition attempt. So if you don't fire on that first compression stroke, my guess is you're not gonna given that there's not going to be any more fuel sprays that start attempt.
I also found that after the fuel pump primes, pressure spikes at the correct mid-50 psi value, but then bleeds off over a few seconds (is this right?). This could also cause a start problem with the Vortex, if you only get one spray of fuel, and it comes after the pressure has bled down, you could end up without enough fuel to do anything good.
Disclaimer: I pulled this all out of my ass. The bleed off of fuel pressure may or may not be correct behavior, so my experience could be completely different.
andykeck is offline   Reply With Quote
Old 05-13-2012, 10:18 PM   #3259
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
anybody got a wiring diagram? im getting 12 vdc at the coil when you turn the key on but it goes away once the fuel pump cycles.
relay maybe? interlock? it would sure help to have a wiring diagram
good news is my berg is back together and makes me smile. i think the 690 is going bye bye when i get it fixed and ill build something to do the long dirt tours with no electronics and oil cooled, strong subframe to carry luggage with top of the line suspension
Have a look here
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 05-14-2012, 05:09 AM   #3260
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Keep it simple...... the amount of fuel squirted into the intake at cold start is adjusted by changing the duration of time the injector is open or pulsed.
That time is usually adjusted by the coolant temperature. Pretty simple eh
Just say'IN
Old 05-14-2012, 07:04 AM   #3261
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
Originally Posted by blakrj View Post
Have a look here
THANKS
now i just need to figger it out
screw it im just going to put 12 vdc to the coil
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is online now   Reply With Quote
Old 05-14-2012, 09:52 AM   #3262
andykeck
Oddometer: 106
Well, that's why I'm wondering if my regulator is not acting the way it should. If I let the fuel pump prime, then screw with my gloves or something for a few second, fuel pressure in the line is down to 20 psi or less. Might make that first squirt weaker than desired if the ECU is expecting 55 psi.
Old 05-14-2012, 12:20 PM   #3263
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,605
Fuel regulators can certainely fail and usually fail in the form of dumping too much pressure.
Seth S
Seth S is offline   Reply With Quote
Old 05-14-2012, 12:57 PM   #3264
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
I hate giving up Would be nice to actually turn the 690 into a bomb proof platform, just to shove it up KTM's ass
Maybe your right Aaron, the 690 with a carb could be my perfect beast
anybody remember who did the carb conversion?
Ride the DEZ
76 CB750
Old 05-14-2012, 01:10 PM   #3265
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Can't be that difficult, just need to adapt a FCR39 to the throat of the head and then clamp a pod filter to the other end. You'll need a vacuum pump of course, but they're well known for reliability.
Just say'IN
Old 05-14-2012, 01:11 PM   #3266
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Or your injector is leaking...
Just say'IN
Old 05-14-2012, 01:38 PM   #3267
andykeck
Oddometer: 106
Nope, not leaking at the injector. If it's leaking anywhere at all, it would have to be at one of the fittings inside the tank, but I strongly doubt that's what's happening. I'm nearly certain that the regulator bleeds off the pressure when the pump's not running. I can't find anyone to confirm or deny if that's the expected behavior or not.
Old 05-14-2012, 01:52 PM   #3268
Seth S
Seth S's Avatar
Oddometer: 4,605
In a car you have a fuel pressure regulator and a fuel check valve. The pressure regulator should limit the max pressure while the bike is running and should not bleed off pressure when it is not running. The check valve on the car is there to prevent fuel from running back to the tank which reduces the cranking time the next time you start the car. I do not know if the 690 has a check valve.
Seth S
Old 05-14-2012, 02:31 PM   #3269
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
got the adapter part figgured. i got a lathe
i used the pod filter in the past and the area on the 690 it sits in is VERY dirty. I mean every day the filter is clogged out here in the dust even if you are in front. i would rather try and route it back into the stock box or if not at least to the very front of the compartment where you are talking of putting the small battery
vacum pump very relliable
i think i need a different ignation probably from an exc
why the fcr 39 and not the 41
i could probably loose 3/4 of the wire loom too
that could be the ticket
Ride the DEZ
76 CB750
Old 05-14-2012, 02:52 PM   #3270
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
http://173.74.246.25/munnracing/cata...TORY%20REPLICA
Warm up that credit card Bob.
Times are GMT -7.   It's 07:01 AM.
