Old 06-06-2012, 04:29 AM   #3721
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 915
Originally Posted by Barman View Post
I did the "barb" repair myself.
A piece of plastic fixed on the nipple with Loctite fuel resistant superglue then shaped with sandpaper.
I am here: http://tapatalk.com/map.php?ce2bda
Nice work .
Brute is offline   Reply With Quote
Old 06-06-2012, 04:44 AM   #3722
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
Originally Posted by Brute View Post
Nice work .
Thanks.
I'd like to say that it's some sort of a ferrule machined to spec for NASA that I fitted to the pump but it's a section cut off of an ink pen. I believe the pen was advertising Prozac.
I cut some threads on the pieces before I glued it just in case Loctite exaggerated on the spec sheet. Either way it's not coming apart.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 06-06-2012, 11:04 AM   #3723
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 584
Question for the experts or not so experts who know.
Your stuck on the side of the road, your battery has been disconnected to make a repair and ontop of that the temp switch for the fan has failed.
So now you cant do the 15 minute run up without over heating, but your FI supposedly needs it.
How much damage are you gonna do if you just ride the bike back out?
tattewell is offline   Reply With Quote
Old 06-06-2012, 11:08 AM   #3724
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Pull the wires off the temp sensor, hold them together and let the fan run for 15 minutes.
Just say'IN
crankshaft is offline   Reply With Quote
Old 06-06-2012, 11:09 AM   #3725
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,539
as far as I know the 15mn is only when you remap the ECU. disconnecting the battery shouldn't need any 15mn reset.
Yamaha Majesty '08
KTM 690 Enduro '10
christian is online now   Reply With Quote
Old 06-06-2012, 11:13 AM   #3726
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
I never even knew about the 15 minute idle reset till about a month after I had mine and apparently neither did the dealer. So it wasn't done for a while. It may run a little crappy due to the O2 being off a bit but damage?? I doubt it. Just don't allow it to overheat with the failed fan switch.
Old 06-06-2012, 11:16 AM   #3727
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 584
I think this is the winner... I'll do that. Thanks guys
Old 06-07-2012, 07:10 AM   #3728
ramjet
ramjet's Avatar
Oddometer: 1,672
Akra Ti and header install-2012 690R
I checked around and found the combo header and slip on is backordered everywhere. I was wondering who has installed just the slipon vs can+header. And differences? Did you install after break in or put the system on first? Do you know of anyplace that has complete system in stock?
Qui Desiderant Pacem Preparate Bellum
ramjet is offline   Reply With Quote
Old 06-07-2012, 10:36 AM   #3729
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 172
Akra can on since day one and 0 miles on the odo and stock odo with Akra map. No problems thus far aside from those caused by myself.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 06-07-2012, 11:45 AM   #3730
rickypanecatyl
SE Asia adventure tours
Oddometer: 588
Originally Posted by BK.RD.RNR View Post
My seat pan got a smackdown right where they put that extra support. The rubber stopper was pushed up into the cusion, and the fiberglass was disintegrated... Although I will admit there were extenuating circumstances that were caused by operator error.
That can't be good for your nuts....
rickypanecatyl is online now   Reply With Quote
Old 06-07-2012, 02:01 PM   #3731
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,434
Idling your 690 for 15 minutes will do nothing but heat it up unless the ecu has been instructed (via tune ecu or the XC-4 tool) to reset adaptations.
Bruno T . is offline   Reply With Quote
Old 06-07-2012, 02:46 PM   #3732
Noyah
poser
Noyah's Avatar
Oddometer: 259
rtfm?
KTM 690 Enduro R
--> My Movies <--
Noyah is online now   Reply With Quote
Old 06-07-2012, 03:34 PM   #3733
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,294
tuneboy does it too. Once i went for a ride and forgot the snorkle ontop of the filter, bike was ok for 45 minutes but then it went ultra schitzo and it would run a few hundred yards then stall. Anyway the only way to get it running right was reset adaptive settings to get the parameters back in line.
MookieBlaylock is offline   Reply With Quote
Old 06-07-2012, 03:42 PM   #3734
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,080
Dahmit...
I have a question about the fan switch. In the previous mega thread, there was mention of using a DRz thermostat switch which turns on the fan at a lower temperature.
So, I ordered one, and it doesn't fit my '08 -- neither the thread or the electrical are compatible. Is the '08 different than other years in this regard?
In other news, I ordered some EBC front brake pads, and they must have shrunk in the mail because they're too small. I seem to recall some information about the correct pad to order from EBC. In the mean time I've just replaced them at great expense with stock pads. Does anyone have handy the correct EBC part number?
At the same time, I ordered clutch plates & springs. The plates fit, but the springs came in a package of 6 and were smaller.
So, is the '08 just different than later models, or are EBC part numbers just farked up?
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is offline   Reply With Quote
Old 06-07-2012, 05:50 PM   #3735
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
EBC part number is wrong, I emailed them 10 times about that, they never bothered to correct it. It seems EBC's part for the 690 SMC is what it should be for the 690E or R.
Meanwhile:
Front brake: KTM Part No 60013030100, DP Brakes Part No (www.dp-brakes.com): DP623 and RDP623
Rear brake: Brembo Part No: SBS-S-40GF, DP Brakes Part No DP622 and SDP622
As for EBC, their web site is an ORGY, totaly disorganised. Its impossible to find relevant info in there. Wonder what king of nuthead came up with such a mess.
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 06-07-2012 at 06:07 PM
Gros Buck is offline   Reply With Quote
Times are GMT -7.   It's 03:28 PM.
