Old 06-11-2012, 03:32 PM   #3811
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Originally Posted by B2 View Post
I meant like the touratech setup part of there speel is the bar that goes from left to right side across near number plate to stop twisting they say, was trying to work out if wether i need to rigup something myself but by the sounds of what you said "sturdy setup "i probably dont have to
I don't think any more support would be needed with soft bags. Take a look when you get them mounted. Very little flex.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 06-11-2012, 03:34 PM   #3812
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,763
Beer'o'clock Baz is offline   Reply With Quote
Old 06-11-2012, 04:15 PM   #3813
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,223
I am new to my '12 690 Enduro, but I already feel the wobbles at the 70 mph zone (no windscreen & stock tires, w/stock suspension @ 2 clicks softer than stock on compression f/r).
My bike also feels loose on rocky two track. Could be where I sit on the bike as I am 3/4 to the rear of the seat most times (yes I stand where needed). I like to feel roomy although sitting back doesn't help cornering.
I'm gonna pay attention to where I sit and of course squeeze the tank and see if I feel any difference.
This is one of the few bikes I've owned that make me want to have a steering damper. Most times I am a anti steering damper guy.
My FMF Q4 & RR air filter make for a badass honk!!!
Fun bike.
Maxacceleration screwed with this post 06-11-2012 at 05:35 PM
Maxacceleration is offline   Reply With Quote
Old 06-11-2012, 05:18 PM   #3814
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Originally Posted by Pate View Post
Can it is meaningful remove 2 or 4 release springs for stronger clip,
what do you think?
If you want a STRONGER clutch, i believe you need stronger springs. Removing them would have the adverse effect. EBC springs are definetly stronger. But 2011 690 have stronger springs too. The part number changed in KTM part lists.
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 06-11-2012, 08:28 PM   #3815
Heptad
Heptad's Avatar
Oddometer: 102
690 noob
I have had a new to me 08 690 for almost a month. Love it so far. One problem. The fan will not come on. The bike just over heats and dies. I pulled the fan off the bike and wired it directly to the battery and it turns on and runs fine. I have read about the different thermo switch but I don't know if that is the problem if the fan never cuts on at all. Or is it? I even thought about hard wiring and mounting a switch somewhere to turn the fan on. Advice please.
Heptad is offline   Reply With Quote
Old 06-11-2012, 10:05 PM   #3816
Pate
Pate's Avatar
Oddometer: 264
Originally Posted by Bruno T . View Post
Huh ? You want to remove springs from the pressure plate for added clutch pressure ?
That would result in less pressure, not more.
No, I suggested to remove release springs:
75032033000 CLUTCH RELEASE SPRING
Sakhalin http://www.advrider.com/forums/showt...9#post11817489
Russian north, enduro ride
http://www.advrider.com/forums/showthread.php?t=432431
Russian Off-Road Challenge 2010 http://www.advrider.com/forums/showthread.php?t=579487
BMW F800GS KTM 300EXC KTM 690 R +RRP
Pate is offline   Reply With Quote
Old 06-12-2012, 12:30 AM   #3817
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
It sounds like your thermostat isn't working or you are not getting power to it. Check if you are getting power to the thermostat switch (left side of the radiator). If you have power there, your switch might be bad.
Lots of people have had great luck with this:
http://www.ktmtwins.com/ktm-690-part...rmostat-switch
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 06-12-2012, 12:38 AM   #3818
Beer'o'clock Baz
Oddometer: 1,763
Fun bike.
I had to get the damper dangerous but as you get used to the bike you will turn it down and know when to turn it up. Sit up front like a dirt bike theres no tank up there so take its place and ride it hard it will repay you
Old 06-12-2012, 01:00 AM   #3819
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 786
I think your switch is bad. Interestingly, mine just went tits up two weeks ago on my 09.
tattewell is offline   Reply With Quote
Old 06-12-2012, 01:55 AM   #3820
Pate
Pate's Avatar
Oddometer: 264
May RRP cockpit "Adventurization":)
Here it is convenient to store a rope
Old 06-12-2012, 02:01 AM   #3821
Pate
Pate's Avatar
Oddometer: 264
the low fender from 990 is better than from 950,
it has more points of fastening. It isn't unsteady during ride.
Besides it is the only option of black matte design which well approaches to 690.
Pate screwed with this post 06-12-2012 at 02:25 AM
Old 06-12-2012, 02:12 AM   #3822
Pate
Pate's Avatar
Oddometer: 264
For RRP cockpit of a all wire it is convenient to lay behind forward:
Here on the right you see Sckott Oiler,
this good place for it. Always it is visible how many in it oils, it is convenient to fill it.
Hoses of ventilation of all tanks are deduced in the most top point, in a cockpit.
On the right main tank, at the left RRP tanks.
ventilation
Pate screwed with this post 06-12-2012 at 03:11 AM
Old 06-12-2012, 03:10 AM   #3823
Pate
Pate's Avatar
Oddometer: 264
On big dirty travel it is very convenient to have such protection:
On the first travel my luggage was damaged by exhaust gases.
Mount the exaust tube of "Wings" so,
it will save up your luggage:
Who can that ask "Wings" to make the second thread in a tube! :)
Pate screwed with this post 06-12-2012 at 05:27 AM
Old 06-12-2012, 03:16 AM   #3824
Pate
Pate's Avatar
Oddometer: 264
It is desirable to fix support of a license plate on a luggage carrier:
Plastic elastic support protects a license plate from vibrations and blows.
I established thick rubber laying between the engine and protection.
It already helped to protect the engine twice:
Pate screwed with this post 06-12-2012 at 04:04 AM
Old 06-12-2012, 03:30 AM   #3825
Pate
Pate's Avatar
Oddometer: 264
After installation external "right" the fuel filter
problem with an injector ours stopped on all 5 690s.
It is the Hyundai Accent filter.
The original filter was removed.
Pate screwed with this post 06-12-2012 at 08:46 AM
Times are GMT -7.   It's 05:09 PM.
