Old 06-12-2012, 03:57 AM   #3826
Pate
Pate's Avatar
Oddometer: 264
to Magadan...
Sakhalin http://www.advrider.com/forums/showt...9#post11817489
Russian north, enduro ride
http://www.advrider.com/forums/showthread.php?t=432431
Russian Off-Road Challenge 2010 http://www.advrider.com/forums/showthread.php?t=579487
BMW F800GS KTM 300EXC KTM 690 R +RRP
Pate is offline   Reply With Quote
Old 06-12-2012, 04:10 AM   #3827
Pate
Pate's Avatar
Oddometer: 264
KTM luggage support several times broke,
TT support is much stronger:
Old 06-12-2012, 04:31 AM   #3828
Heptad
Heptad's Avatar
Oddometer: 104
Originally Posted by tattewell View Post
I think your switch is bad. Interestingly, mine just went tits up two weeks ago on my 09.
Thanks I will check today when I get home for work.
Heptad is offline   Reply With Quote
Old 06-12-2012, 04:58 AM   #3829
Pate
Pate's Avatar
Oddometer: 264
Luggage bags and their fastening:
Bags have the size allowing
to carry on the right bag a tire 21" on left 18"
here so:
Old 06-12-2012, 06:07 AM   #3830
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 782
I pulled the plug out of the switch and jumped it with a piece of wire (its only 2 prongs). If the fan goes on the switch is toast.
Also, somebody mentioned a suzuki/kawi part number that will go in and actually comes on at a lower temp, which may be beneficial to you.
tattewell is offline   Reply With Quote
Old 06-12-2012, 06:43 AM   #3831
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
The switch offered by KTM Twins is also 88 degree on like the Suzuki switch. I grabbed the Suzuki switch over the winter when the KTM Twins switch was backordered and the Suzuki switch was cheaper. Suzuki must have caught on because it isn't cheaper anymore.
http://www.ktmtwins.com/ktm-690-part...rmostat-switch
I am at one with my duality.
Barman is offline   Reply With Quote
Old 06-12-2012, 06:53 AM   #3832
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,961
Originally Posted by Pate View Post
No, I suggested to remove release springs:
Oh, my bad. Release springs for the slipper, no idea what effect that would have.
Bruno T . is offline   Reply With Quote
Old 06-12-2012, 08:36 AM   #3833
Heptad
Heptad's Avatar
Oddometer: 104
Fan problem
So I unplugged the thermo switch and used a test light to see if power is going to the thermo switch. Test light would not light up on either prong. Should there be power there? Or dose it only get power when the bike over heats. I traced the wires back and one goes to the fan and the other to the harness. I also checked all the fuses.
https://picasaweb.google.com/j.kjfre...M2blOXo2d74aA#
Old 06-12-2012, 08:40 AM   #3834
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
it is probably switching the ground . i know that is the case on the 640
you want to get continuity across the contacts when the thermostat is working.
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 06-12-2012, 08:58 AM   #3835
goosecreek
a desk prop
Oddometer: 2,480
fan problems
You could use a jumper wire to see if the fan cuts on if so then you know it is in the switch and not the wiring.
goosecreek is offline   Reply With Quote
Old 06-12-2012, 09:01 AM   #3836
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Damnit Bobzilla. Quit being right all the time!
I just looked at the schematic. The thermal switch is on the ground lead not the hot. A jumper across the 2 prongs while the bike is turned on should turn on the fan. If it does, your thermo switch is bad. If not, you have a wiring problem. In which case you could pick up a ground basically anywhere.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 06-12-2012, 09:49 AM   #3837
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
Ride the DEZ
76 CB750
Old 06-12-2012, 10:57 AM   #3838
tonykof
tonykof's Avatar
Oddometer: 154
Stalling....
Stalling issues sucks...Thought it was just me...nope...Idling or close to it in first gear...kind of embarrassing if you are in a slow slight turn & someone is watching and you have to jab a foot down to keep from falling when it stalls out of nowhere...
I did put on a fmf powercore...waiting to get a foam filter on before hauling/riding 300-350 miles to dealer for reset and or map...
it did this some while bone stock too...but seems to be more relevant now..
BMW R1150GS
KTM 640 Adventure
KTM 525 EXC
KTM 350 XCF
tonykof is offline   Reply With Quote
Old 06-12-2012, 11:09 AM   #3839
Heptad
Heptad's Avatar
Oddometer: 104
Fan problem
Ok tried it and fan comes on. I have a new 88 degree thermo switch ordered. I forgot about the wires that go to the fan and didn't think about one of them could be the hot. It makes since now. I really appreciate all the help.
Old 06-12-2012, 11:27 AM   #3840
rudyunknown
rudyunknown's Avatar
Oddometer: 713
Giant loop and KTM690
I went to this epic Roaming Rally in Canada...we needed to carry our stuff with us for the whole ride....i chose the giant loop which did a great job being stuck on to the bike through all the tech stuff...
but my biggest problem/complain was with the gaint loop taking up most of the space on the rear seat, i couldnt sit as far as i would like and my toes which are usually on the rear brake was shifted towards more of the rear part of the feet...so every time i had to get on the rear brake i would lock it up because i never could get the feel of it with the heel of the boot....
any suggestion to move the giant loop further back...or some other luggage system that would remove this problem
Indian among Americans
Husky 250 "hit that tree"
Adventure bike KTM 690e
Vstrom 1000 For everything else
rudyunknown is offline   Reply With Quote
Times are GMT -7.   It's 04:42 AM.
