Old 06-17-2012, 08:13 AM   #3991
nibby
Oddometer: 105
Just took delivery of a new 690 and am now starting to think of places to put a toolkit, spare tube, pump and levers for any repairs when out.
I dont normally carry a backpack or waistpack (would be easier and cheaper) but I like the spares on the bike.
Was thinking of a Kriega 5L tail pack to go on the back (maybe with the new Kriega rack loops and cam straps which look like they allow anything from a 5l to 20l drypack to be attached) Anyone else done this and does it fit with the grab handles in place? (need to fit the grab handles as they dont come pre-installed for some reason?)
Also looking at a GL Coyote for weekend and longer trips if needed.
Also interested if anyone know if the tank bolts on the 2012 model need replacing or have KTM learned a lesson from previous failures and made these things stronger?
nibby is offline   Reply With Quote
Old 06-17-2012, 08:24 AM   #3992
Pate
Pate's Avatar
Oddometer: 264
Replacement of an old brake pedal (765.13.050.000)
on a new pedal with ball-bearings (765.13.050.200)
on model till 2010 incl.
Or
76513050044 FOOT BR. LVR + STEP PLATE and 7651305014401S FOOT BR. LEVER + STEP PLATE
to
7651305024401 FOOT BRAKE LEVER CPL. 11
For installation of the new pedal it is necessary to make a special axis,
it has 2 threads, the left M10x1.5 and the right M8X1.25:
Still 1-2 nuts and one washer of M8 are necessary.
It is necessary to install the thread of M10X1.5 on strong Locktite (red).
Sakhalin http://www.advrider.com/forums/showt...9#post11817489
Russian north, enduro ride
http://www.advrider.com/forums/showthread.php?t=432431
Russian Off-Road Challenge 2010 http://www.advrider.com/forums/showthread.php?t=579487
BMW F800GS KTM 300EXC KTM 690 R +RRP
Pate screwed with this post 06-25-2012 at 01:26 AM
Pate is offline   Reply With Quote
Old 06-17-2012, 08:34 AM   #3993
ramjet
ramjet's Avatar
Oddometer: 2,211
I've found the Kriega US 20 the most useful size. I also, have the 10L that stack nicely on top of the 20. While I carried this on the XR650R on a ProMoto Billet rack, for the 690 I would consider either:
http://www.bboffroad.com.au/ktm__6902.htm or,
http://shop.sw-motech.com/cgi-bin/cosmoshop/lshop.cgi?action=showdetail&wkid=133994700617625&ls=en&nc=1339947070-18526&rubnum=products.1252674507.1256051975.1256052012&artnum=GPT.04.439.100/B&id=95&gesamt_zeilen=50Tshowrub--products.1252674507.1256051975.1256052012&typid=66724540
I'd probably use the Kriega for short trips and Giant Loop for campout/longer trips.
Can't decide between the SW-Motech or the bboffroad- sombody help me out here................
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 06-17-2012, 08:55 AM   #3994
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I had the SW Motech rack and will vouch for its durability. It's also versatile with many adapters and plates for mounting luggage or strapping on bags. Also looks easier than the other rack to get a grip on for yanking the bike around.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 06-17-2012, 09:06 AM   #3995
Uller
Uller's Avatar
Oddometer: 1,676
Used the SW Motech for about 4 years now. Love it. Still haven't seen another I would rather use in its place...
Rugged, durable and does its job.
Uller is offline   Reply With Quote
Old 06-17-2012, 09:47 AM   #3996
nibby
Oddometer: 105
Like the look of the SW Mototech ones but thinking of going this route with Kriega
http://www.adventure-spec.com/defaul...-hardware.html
Looks pretty secure for day rides when I only need to carry tools, although the Mototech one looks like it would allow a few more options.
Old 06-17-2012, 09:56 AM   #3997
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Eventually you may want moe options than that Kriega system affords. Looks simple till you need to gas up. And where are the grab handles? Can they be used with that setup? Handles are important.
Other than that looks like a simple, light setup. Depends on your needs.
Old 06-17-2012, 10:48 AM   #3998
Uller
Uller's Avatar
Oddometer: 1,676
I've just purchased a US-5 and US-20 to use with my SW Motech. I've used the incorporated grab handles on the rack on many occasions and they also provide another, further forward lashing location for bags and other gear (I also use a Giant Loop Great Basin for longer trips).
One of the best things about this rack for me is that it is narrow. I trail ride and push it while riding. When I fall, the leading edge of the rack doesn't dig into the ground and rip off or get damaged because it is inside the lines of the bike. It also isn't putting any strain on the embedded fasteners of the gas tank during a fall. If you loop out low side, the back rear corner of the rack would be one of the first things to contact the ground. This would cause a pulling force on the rack/inserts. It doesn't happen with the SW Motech again because it is inside the lines of the bike.
Just my .02
Old 06-17-2012, 11:13 AM   #3999
ramjet
ramjet's Avatar
Oddometer: 2,211
Yes. Barman and Uller nail it. One of the things useful about a dedicated rack under the Kriega is being able to mount one of the Rotopax 1or2 gal on top when you need to haul gas to a mate in need. I fabbed an aluminum plate that was a quick bolt on to the ProMoto rack that I had on the XR for the Rotopax. It was a great accessory to have. Not permanent. Quick on and off. I had a couple different tail bags but they never got used once I got the Kriegas. A quality product.
Old 06-17-2012, 12:14 PM   #4000
nibby
Oddometer: 105
Uller, yes good points, i do lots of falling so it's important things dont get compromised. I also like the built in grab handles.
Dont suppose you have any pics of the us 5 mounted? also the us20 and the giant loop?
Just my .02
Old 06-17-2012, 12:26 PM   #4001
Uller
Uller's Avatar
Oddometer: 1,676
I just ordered the Kriega bags. Haven't used them yet. Excited to though.....
Pics of Giant Loop, Waterproof Duffel with Tent and camp chair, and waterproof stuff sack with sleeping bag all on top of the SW Motech Rack are in the rack thread. I run some cam buckle webing straps for rafting under the motech rack in a cross pattern over the tent and bag. Works very well. No missing items ever and no shifting even in bad whoops.
http://advrider.com/forums/showpost....&postcount=933
Old 06-17-2012, 12:40 PM   #4002
nibby
Oddometer: 105
Great stuff, thanks. I didnt know there was a 690 luggage thread until now
I know what I'm doing for the rest of the night
Old 06-17-2012, 01:19 PM   #4003
Michelangelo
2 wheel rider...anytime..
Michelangelo's Avatar
Oddometer: 1,702
Originally Posted by B2 View Post
Mine are arriving from RR on tuesday {top and bottom} are there any tricks i should know for installation ?
Is the top or bottom bolts more prone to breakage? I thought it was just the top ones?
Dirt and offroad motorcycle tours...
ALL MOTO ADVENTURE,LLC.
www.AllMotoAdventure.com
Michelangelo is offline   Reply With Quote
Old 06-17-2012, 01:33 PM   #4004
Jimbobshere
Oddometer: 8
KTM rear rack
Happy Trail is making a rear carrier plate that is a dual layer with the top layer that will tilt to provide easy access to the fuel fill. It will bolt to the 4 bolts on the tank along with their aluminum box carrier brackets. Looks pretty nice. Have one on order but not recevied yet.
Jimbobshere is offline   Reply With Quote
Old 06-17-2012, 01:36 PM   #4005
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,758
Dont know just ordered them all in case
Beer'o'clock Baz is offline   Reply With Quote
Times are GMT -7.   It's 03:43 PM.
