Old 06-18-2012, 06:13 PM   #4036
ramjet
ramjet's Avatar
Oddometer: 2,168
That's nice, Barman. Must feel good on the tushy. Looks like it raises rider position about 1-1/2"?? Can he make it add less height but maintain comfort?
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 06-18-2012, 06:16 PM   #4037
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Ok
I need handle bar risers.
Its time for your suggestions. I wish to raise it around 4 inches. What are your recommendations. Recommendation for hydraulic hoses as well. I already routed he throttle cable under he handle bar.
I have already eliminated Rox and Toratech risers.
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 06-18-2012 at 07:01 PM
Gros Buck is offline   Reply With Quote
Old 06-18-2012, 06:31 PM   #4038
Pundy
Oddometer: 339
Originally Posted by Barman View Post
Got my Renazco Ergo seat today.
Great work.
Uploaded with ImageShack.us
Barman, if that's your garage, I want to see pics of your house. Beautiful stuff!!
Pundy is offline   Reply With Quote
Old 06-18-2012, 06:33 PM   #4039
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
They can design it to order for your specs. I have a 37" inseam that's why it's a bit taller. Also had them modify the center with a softer foam to cushion my old tail injury. Very accomodating folks.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 06-18-2012, 06:40 PM   #4040
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
The house belongs to a friend that bought it 7-8 years ago. He didn't even realize there was an apartment above the garage when he bought it. I immediately jumped on that bit of info and made an offer to move in. What a great little place. The 690 and my F150 add character to the neighborhood. I'm always wrenching on something in the garage.
Old 06-18-2012, 07:25 PM   #4041
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,549
Originally Posted by Gros Buck View Post
Sorry. I was busy trying go get it extinguish.
Ok. Story short.
The battery went dont. I boosted the bike. Started, but the bike stopped immediately. Tried to start it again, but I had to keep the throttle 1/4, otherwise the bike would stall. At each attempt, the power cycle would engage, but then the ECU would shut down. What was happening is, because the battery was down, the ECU was also down. And everytime I was attemting to start it, it would throw a shot or two of gas into the injection, then shut itself down because it was detecting a low voltage. The bike exhaust filled up slowly with gas, and the catalytic converter started a loop downward to hell turning itself into a color without name. The catalytic converter became so warm the orange plastic melted down - drop by drop - onto the catalytic converter itself igniting and fueling a fire. Then, the gas tank itself ignited. They were then two fueling drop by drop the fire. I have never been so happy to be within 10 feet of a garden hose. I am never close to a garden hose. Imagine Bob in the Dez ...
All of this story happen within a minute and a half. Its very quick to reach that point. Moral: If your battery goes down, boost it, but keep your friend's bike or batterry booster connected to as long as it is necessary to keep the ECU ON. In other words, 10 minutes or more, before you start your bike. You realy need a minimum voltage.
Regards
Paul Jr
Daaaammmmn, bad luck that. See if they will cover the melted bits under warranty . Is your bike a loss of repairable? Nice choice in bikes BTW, have the same set in my garage.
CanadianX is offline   Reply With Quote
Old 06-18-2012, 07:27 PM   #4042
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,621
Great work.
Just curious if you extended the rear contact point on the TT rack to touch the fender, or left it as is?
Have you put any weight on it yet?
BK.RD.RNR is offline   Reply With Quote
Old 06-18-2012, 07:32 PM   #4043
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,621
Ok
Paul Jr
I would be interested to hear your impressions after raising them that much. I have Tusk billet aluminum 30mm? risers on my bike, and it's been a big help, but I've always wanted more...
Old 06-18-2012, 07:34 PM   #4044
Gros Buck
Gros Buck's Avatar
Oddometer: 847
Originally Posted by CanadianX View Post
Daaaammmmn, bad luck that. See if they will cover the melted bits under warranty. Is your bike a loss of repairable? Nice choice in bikes BTW, have the same set in my garage.
Melted bits were replaced under warranty.
The 1200GS and thos 2008 690E are gone. I own a 690R 2011 now.
By the way, this happen to other fellows on ADVRider ...
My problems originate from my physical characteristics. I have only 26" inseem. 5'-4". Still, I'm well above 200 lbs. Varies from 210 to 230. I'm also a little wide ... First, that forced me to "thicken" my boots' sole by 30 mm. It does affect significantly my position with the handle bar. I need my bars much higher enad closer to me.
I actualy already have 30 mm of risers. I need a minimum of 50 mm more. I wonder what will happen with the clutch hose ..
Paul Jr
KTM690r 2011
Gros Buck screwed with this post 06-18-2012 at 07:48 PM
Old 06-18-2012, 07:42 PM   #4045
Pundy
Oddometer: 339
Air filter
Anyone gone back to the stock air filter setup due to the RR Uni being so damn loud? If so, did you miss the power/throttle response?
Old 06-18-2012, 07:48 PM   #4046
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
I haven't loaded it yet but gave it my own stress test and it holds more weight than I'll ever load on it. And I did pick up another bolt and spaced out the bumper and the rack till it contacted the fender.
Barman screwed with this post 06-18-2012 at 11:49 PM Reason: add photo
Old 06-18-2012, 08:01 PM   #4047
Gros Buck
Gros Buck's Avatar
Oddometer: 847
Go with the UniFilter option ... Do not ever re-install paper filters ...
Paul Jr
KTM690r 2011
Old 06-18-2012, 09:53 PM   #4048
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 759
I have gone back to the Unifilter foam + snorkel. I have used the RR airfilter that fits on top replacing the internal filter and snorkel. Certainly makes it run more sharp, but maybe too touchy for me. Plus as others have said, it is noisy. I have reverted to the internal foam filter and snorkel, with a few holes drilled in the snorkel end to increase air flow, and I think, for me, it is a good compromise. I also find that the internal filter seems to be getting dirty at a slower rate, probably because it is less exposed.
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 06-18-2012, 10:29 PM   #4049
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,474
Paul Jr
heads up...you can by the twin foam unit through parts unlimited for about $40. it is black foam.
Seth S
Seth S is offline   Reply With Quote
Old 06-19-2012, 01:21 AM   #4050
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,756
Originally Posted by B2 View Post
Mine are arriving from RR on tuesday {top and bottom} are there any tricks i should know for installation ?
Just finished installing top and bottom tank bolts very good quality stuff fitted fine did have to grind a mm or 2 of the bottom sleeve but ended up very snugly, racks on 2moro woohoo
Beer'o'clock Baz is offline   Reply With Quote
Times are GMT -7.   It's 12:30 AM.
