07-05-2012, 12:34 AM
#4351 |
Oddometer: 542
Brad,
Great idea....hope it is solidly in there... ![]() Riders, Uller LOVES his Dremel and will use any excuse at all to whittle away at something with it... ![]() BobZ, So....keeping the 690 now that it might be easier to change the injector....or whatever else hangs out down there that gives you grief??? Brad will be up here in a few weeks to do three of the days planned for next summer. Ulterior motive: he knows what to do if I have issues with the bike ....and parts I could scavenge ![]()
Ged Schwartz Kamloops , BC '96 GS 1100 '04 450 EXC '09 690 EXC Baja '05 Baja 06/07 Baja 08/09 BC Alpine Single Track |
07-05-2012, 01:57 AM
#4352 | |
Oddometer: 38
07-05-2012, 04:09 AM
#4353 |
Melbourne , outer east .
Oddometer: 923
Nice work Uller , I think it`ll sit at the front ok . I`ve run mine with out the right front airbox mount bolt for a long time to make it easier to get off in a hurry . Think I`ll go with your mods , drowned mine a couple of times with the Safari tank & it`s a pain . Now to find an easier way to get the spark plug out with the Safari tank on .
07-05-2012, 04:59 AM
#4354 | |
Red Sox Nation
Oddometer: 8,922
An inmate here emailed me to try the throttle reset procedure to see if it helped the stalling. I did it and so far so good. I rode a fuel load yesterday with no stalling, plus I think my idle is up a little at around 1700rpm.
The procedure is simply turn on the key and slowly turn the throttle to the stop and back. Can anybody tell me were this trick and the '15 minute idle' trick comes from? It's not in my manual. Thanks Quote:
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
07-05-2012, 05:14 AM
#4355 | |
Safari Scramble!!!!!
Oddometer: 3,226
So in summary I have a guess and it could be completely incorrect
Seth S My intuition nearly makes up for my lack of good judgement. Just installed my new trolling motorHusaberg tank for sale: HERE |
07-05-2012, 06:34 AM
#4356 | |
KTiM
Oddometer: 456
~Tim "04625 SXC '04 625 SMC 76,xxx mi. '97 CR500 Sold
07-05-2012, 07:16 AM
#4357 |
Oddometer: 7
Map settings
Hi all. I have a 2012 690 and want to start playing with the various mappings! I ride quite a bit of rocky terrain and I find the standard setting a tad to aggresive
My switch under the seat has no reference marking by which I can try and set it, so I'm stumped on that front. I read on another forum that some time back I Leo Vince brought out a switch that replaces the switch under your seat and the control gets attached to the bars with 3 settings. The guy that posted indicated that he got the part on KTMTwins. I searched for this part but cannot find it there! I love my bike but would really love it should I be able to switch between mappings on the fly and without having to take the seat off! ![]() Any advise would be appreciated!
07-05-2012, 07:28 AM
#4358 |
690er
Oddometer: 135
The "trick" is called "Initialization run", and it is due anytime the ecu is flashed; it has become a general habit to do the procedure if something related to intake or exhaust has been modified.
Page 169 of the 690 Enduro Enduro/R Repair Manual: Start the engine and perform an initialization run. Guideline Initialization run: 15 minutes
maurizio '08 LC4 690 E "Orange Duck-R" '08 FLHCTUSE3 "White Anchor" '76 CB 750 F ss "76er" Sold: '03 LC8 ADV s "Big Orange" - '05 EXC 450 F "Orangina" |
07-05-2012, 07:38 AM
#4359 | |
690er
Oddometer: 135
I think that this is one of the reasons for the choice of the underseat placement of the map switch made by KTM engineers.
07-05-2012, 07:50 AM
#4360 | |
Oddometer: 3,226
0 - shitty gas..basically dont use unless you are in the middle of Russia and can only run mud for fuel. 1 - XR400 setting. knocks about 20 hp off the engine, throttle is smooth and linear, bike is completely boring to ride. 2 and 3 - I cannot tell the difference between these two...one is normal and one is sport or aggressive...not a big difference. 4 -10 all the same...They will point to a map but I do not remember which one. As states you cannot switch between maps on the fly. You could hit the kill switch, change maps, and restart.
07-05-2012, 08:02 AM
#4361 | |
Oddometer: 1,690
On my '12
0 = poor fuel quality, use for no more than one tank (shitty gas setting 1 = soft, reduced peak performance (XR400 setting lol) 2 = advanced performance w/extremely direct responsiveness 3-9 = Standard for balanced responsiveness I am still looking for balanced response . Today (!) I get the sniffer test and I'll ask about the throttle reset procedure too...
Horsepower is a distant second to useable torque, unless cafe cruising is the reason for the purchase... Quote:
07-05-2012, 08:22 AM
#4362 | |
Oddometer: 87
If I select the performance map on my '11 and start the engine it idles at 4k rpm. I actually thought it was a feature of the map! I've remapped, relearned blah blah.
Thoughts? Quote:
07-05-2012, 08:42 AM
#4363 | |
Oddometer: 7
07-05-2012, 08:52 AM
#4364 |
N8YQ
Oddometer: 1,453
07-05-2012, 09:02 AM
#4365 | |
Oddometer: 604
I bought basically the exact same thing from another guy (roadstercycle.com) and if I were to do it again, I would buy from JHammer just to keep it in ADVRIDER. (Plus, I don't like the breaker style fuse that they supply with their kit for a dirt bike.) You can do a bunch of research on the interweb on these. I believe that they were stock on an R1 and are basically newer technology than the Shunt (see correction to this) style regulator that comes stock. The Triumph forums are a great resource as those bikes had big problems with the Shunt Style (see correction/additional info below). Here is another vendor: http://www.roadstercycle.com/ His site also has a bunch of info related to charging systems and links for the MOSFET vs. Shunt data. I am of the opinion that this is a must do for the bike, certainly if running a LiFePo4 Battery. When a shunt style regulator breaks, 19 volts is where it usually heads and this will be intermittent on most occasions so it is hard to diagnose. It causes problems with the Fuel Injection system and the computers and will fry a LiFePo4 battery in no time. Luke ended up having this problem on his Africa trip. Uller screwed with this post 07-05-2012 at 12:13 PM |
