Old 07-05-2012, 08:21 PM   #4381
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by Uller View Post
Lukas, Thanks for the correction and additional info. Much appreciated. I am still learning most of this stuff and am all when it comes to the finer technical aspects . I'm more of Cliff notes kinda guy..... (I've never bought a cliff notes book though)
Collective reading here: http://www.shindengen.co.jp/product_...o/catalog.html
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 07-05-2012, 09:13 PM   #4382
gen
gen's Avatar
Oddometer: 800
Originally Posted by tattewell View Post
I cant see this bike being tubeless, I have the KTM hardparts Behr rims on my 690 enduro, and they are not tubeless...
I'm pretty sure the 2012 SMC R rims are spoked tubeless rims.
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 07-05-2012, 09:14 PM   #4383
gen
gen's Avatar
Oddometer: 800
Originally Posted by LukasM View Post
The tubeless spoked wheels were standard on the 2010+ models, Behr Saxxess.
They all need the upgraded tank bolts.
The 2012 suspension has 25mm less travel on the front, 15mm less on the back.
Muchas gracias! I'll look for a 2010 or 2011 then.
Old 07-05-2012, 10:35 PM   #4384
Oz-Strom
Still trying
Oz-Strom's Avatar
Oddometer: 759
wiring heated grips
Is it OK to wire heated grips to the accessory wire behind the headlight cowl? I already have a pair of LEDS and an accessory power outlet wired to that wire. Or is it OK to wire the grips to the low beam power wire?
Cheers
Graham
Oz-Strom is offline   Reply With Quote
Old 07-05-2012, 10:55 PM   #4385
dirtbikeslob
Oddometer: 300
Originally Posted by Pundy View Post
Anyone out there who uses something like a Giant Loop bag have any issues with the heel guard failing while using it as a tie point for your luggage? They seem a little flimsy to me. Thoughts?
i have used my greatloop type strapped to the plastic heel guards,with out a problem,they flex outwards a bit,but seem to handle it ok.
dirtbikeslob is offline   Reply With Quote
Old 07-06-2012, 01:30 AM   #4386
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Gros Buck View Post
I used rubber condoms to plug my stuff...Paul Jr
Paul,
Have you seen a doctor about that yet ???
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 07-06-2012, 01:48 AM   #4387
motoged
motoged's Avatar
Oddometer: 908
I have used that plastic piece as a lash point for my Coyote bag for over 4,000 kms of offroad and it has shown no signs of wear or fatigue. I have a heavy duty bungee cord hook I scavenged from a Walmart bungee (that looks more like this: ... and made a loop in the webbing at the hook base and passed the Coyote strap through that....
and NOT these wimpy ones:
I noticed BobZ and his gang simply tied a small gauge bit of climbing rope through the hole in that heel piece so it was a 4" long loop ....and then used a carabiner to loop the Coyote strap through.....much simpler than my method
Ged Schwartz
Kamloops , BC
Old 07-06-2012, 05:14 AM   #4388
Gros Buck
Gros Buck's Avatar
Oddometer: 847
Originally Posted by motoged View Post
Paul, Have you seen a doctor about that yet ???
Oups. After a second reading, it sounds quite different to what I had in mind when I wrote it ...
But do you have a clue of what I really meant ??? Or should I rephrase it ???
Paul Jr 8
KTM690r 2011
Old 07-06-2012, 12:02 PM   #4389
motokeith
Oddometer: 88
I took the pegs off the passenger brackets and put the pivot pins back in the brackets. Makes for a very nice place to attach the GL lower straps.
motokeith is online now   Reply With Quote
Old 07-06-2012, 01:06 PM   #4390
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,667
I have LEDs, accessory plug (for GPS) and Heated grips installed on the SWITCHED accessory wire. It is 10 Amp fused. I wouldn't wire your grips into the low beam wire. That sounds like a bad idea.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 07-06-2012, 11:04 PM   #4391
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,989
Found the casue of my flashing error code!! Both wires going into the temp sensor snaped off right at the base of the connector . Before i attempt to pull it apart, has any one else managed to sucessfully reconnect the wires back to the connector?
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 07-06-2012, 11:26 PM   #4392
Uller
Uller's Avatar
Oddometer: 1,674
It depends on what you mean by "reconnect".
Two ways I could think to fix it. Both involve first removing the pins that are inside the connector. You could try to pry them (the tabs on the pins) back open and recrimp and solder them to freshly stripped wire. A couple times I have had success with this but, just as many times it doesn't work.
Your best bet is to find the type of connector it is and what type/size of pins it uses and purchase some new ones. Then crimp those on and reassemble the connector. Good as new.
Source of some connectors/pins: http://www.easternbeaver.com/Main/El...-MT/sm-mt.html
Uller is offline   Reply With Quote
Old 07-06-2012, 11:59 PM   #4393
Night Falcon
Adventure NZL
Oddometer: 1,989
Cheers Uller
My EXC530 Adventure
My KTM690 Adventure
Old 07-07-2012, 05:37 AM   #4394
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,046
I feel weird quoting myself...
Took a look and while it will be a challenge to pull the boot/wire off the spark plug from this angle it most definitely would be possible and the spark plug itself is definitley a 'Yes' as far as access goes.
Also, I had a light bulb go off while I was in the garage. My statement above mentions the only possible movement is in the up/down direction, I started thinking about some foam under the seat to just "snug stuff up" and .... I have a Corbin seat which has a custom seat pan. It actually has rubber bumpers which put pressure on the top of the air box already. You can see some of the round rub marks from them in some of my pics. My airbox is locked in and has all directions of movement stopped by something. I'm still going to leave my disclaimer above but, now feel really confident this is going to work very well.
Good news , thats gotta save a lotta time on the side of the track.
Brute is offline   Reply With Quote
Old 07-07-2012, 12:34 PM   #4395
Noyah
poser
Noyah's Avatar
Oddometer: 400
Both screws/bolts holding the airbox cover are no longer attached to the airbox... Not sure how to solve it, glue?
KTM 690 Enduro R
--> My Movies <--
Noyah is offline   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
