07-08-2012, 05:18 AM
#4411 |
Oddometer: 2,293
07-08-2012, 08:40 AM
#4412 |
Oddometer: 28
Bartron Partial Canisterectomy
I have performed the above procedure, including installing a Renazco billet filler neck and an in-line one way valve to the scavenge fuel hose. My problem is that I am building pressure inside the tank (fuel vapors normal expansion).
I thought the one way valve would stop the denser fuel from escaping, while allowing some air to exit to accommodate fuel vapors and ,of course, allowing air to come in to fill tank as fuel is depleted. Do I need a different valve, or should I just vent the hose to atmosphere without any valve? I would appreciate a comment from those that have performed this modification. TIA, John snakepilot screwed with this post 07-08-2012 at 08:56 AM |
07-08-2012, 11:03 AM
#4413 |
louder, louder, louder!
Oddometer: 1,071
I'm sensing a trend that Mookie is fond of RTV.
------------------------------ Suck, Squeeze, Bang, Blow ------------------------------ New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better! |
07-08-2012, 01:05 PM
#4414 | |
Way Offline
Oddometer: 1,162
I was fueling one day and when I removed the gas cap I noticed a vacuum had built in the tank. Removed the seat to see what was amiss (it's just a rubber line wtf could be the issue? ). The seat bumper that rests on top of the battery hold down was pinching the vent line. Moved the line and zip tied it out of the way.Gotta give credit to the fuel system on the 690, not even a hiccup out of the engine with a vacuum in the tank.
I am at one with my duality. |
07-08-2012, 01:13 PM
#4415 |
Oddometer: 593
Well that´s a first!
690 "DIY" thread (incl. "Rallybike build"): http://advrider.com/forums/showthread.php?t=708813 ![]() M Motoadventures
07-08-2012, 01:16 PM
#4416 |
Way Offline
Oddometer: 1,162
Gotta throw the dog a bone occasionally.
07-08-2012, 02:31 PM
#4417 |
Oddometer: 28
Barman,
I appreciate your reply. In your case, the pinched fuel line was the culprit. I do not have any "kinks" on the line, but following the procedures on Bartron's "code orange" thread to do a partial canirestomy and installing the one way valve has not worked as advertised. I know that lot's of inmates have done this modification, so my question is: have you just vented to the atmosphere as Barman did, or did you use a one way valve? If you did, how is it working out? |
07-08-2012, 09:53 PM
#4418 | |
Re-Noobified
Oddometer: 6
I've been just running the vent to the atmosphere ... been like this for more than 3 years now with zero problems. I just don't trust those 1-way valves.
------------------------------------------------ - Rick ![]() '08 KTM 690 Enduro |
07-08-2012, 11:44 PM
#4419 | |
Adventure NZL
Oddometer: 858
07-09-2012, 12:22 AM
#4420 | |
Melbourne , outer east .
Oddometer: 913
07-09-2012, 02:29 AM
#4421 | |
Oh!? That is deep.
Oddometer: 756
07-09-2012, 04:55 AM
#4422 |
Kool Aid poisoner
Oddometer: 4,823
Probably the culprit. Both times I've had one lock up it's been riding out in some serious heat. I just stopped using the things and went back to regular hose.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
07-09-2012, 08:44 PM
#4423 | |
Nippybit
Oddometer: 92
Gas Tank/Cap Venting
I have a full cannisterectomy on my 2010 R and I also have the Renazco filler neck and Acerbis cap. I am assuming here that you also have an Acerbis screw-on cap. If so the cap has a center vent recessed into it. I just use a no-slop short hose valve (about 2 1/2 inches high) which allows the tank to breathe but prevents excess fuel from escaping. The no slop valve just mounts vertically into the cap recess and onto the male vent. I have the factory vent hose, which is connected to nothing at either end, just tucked under the seat. No vacuum problems with my tank and I routinely fill it to its maximum capacity, i.e., 3.2 gallons. Hope this helps. P.S. No problems with gas tank venting in almost three years, with the bike left in the sun (in Southern Nevada summers), in the shade, etc. Got a good quality no-slop valve at Cycle Gear and it has never failed.
2010 KTM 690 R (sold 12/11/12) Previous bikes (way too many to list here and what's the point) Been riding mostly off-road since 1960--began at age 14. Watch this space as I am about to say something really prophetic! nippybit screwed with this post 07-09-2012 at 08:53 PM |
07-10-2012, 06:43 AM
#4424 |
Oddometer: 28
Thanks to all for the replies.
Nippybit, I will probably try that next, or just vent to atmosphere. I had that same setup on my previous bike on a Clark 4.2 gallon tank. Bartron's "code Orange" thread describes the method I followed for the partial "canirestomy"and so I figured others have done the same. He recommends what you did, OR the in-line valve as I did. Either method accomplishes the same as the valve is supposed to perform the same function, whether is mounted to the gas cap or in-line. BTW, the expansion has been due to just normal summer riding as I have not parked the bike in the sun for any extended periods. A friend who is a pretty good mechanic and does all the work on his own bikes ( but does not have a KTM) thinks that the amount of pressure that builds up is not sufficient to have a detrimental effect. So far, the bike runs great, but my concern is long term. snakepilot screwed with this post 07-10-2012 at 08:11 AM |
07-10-2012, 09:56 AM
#4425 |
TrackBum
Oddometer: 460
I have been using these for a couple of years with no issues.
http://www.motorcycle-superstore.com...T.ac=SLIsearch I have three of them on the bike since I am running the Rally Raid tanks. I did a week in Baja with tons of dust. Never a problem.
2009 KTM 690r Enduro in da house 2002 RC51 SOLD 2010 KTM 990 Supermoto R |
