Old 07-10-2012, 05:27 PM   #4426
Heptad
Heptad's Avatar
Oddometer: 102
Led turn signals
I need help with installing led turn signals. Anyone install these? Says to cut the purple and black wires coming from indicator light. It is part of the wire harness. Should I do this?
Heptad is offline   Reply With Quote
Old 07-10-2012, 06:34 PM   #4427
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,559
On the back, the turn signals have *very* long leads. They actually connect into the wiring harness up near the battery. The fronts are a bit more typical. Yes, cut the leads off and solder them to the new signals. I recommend staggering the splices so they can still fit through the mounting holes.
Suck, Squeeze, Bang, Blow
New Rider Training in the San Francisco Bay Area at Motorcycle University". Learn to Ride...Better!
Roadracer_Al is online now   Reply With Quote
Old 07-10-2012, 07:50 PM   #4428
Aanarchy
Aanarchy's Avatar
Oddometer: 1,083
I don't know what kind of LEDs you have, but I installed the sicass racing flush mount rear signals and sicass front signals and there was no cutting or splicing on either. It's "plug & play". A plastic quick connect plug joins wires from the signals to the harness both front and rear.
The instructions talked about cutting and splicing and all that shit, but it wasn't necessary. Front signals required buying the sicass relay to replace the stock one to make them flash properly. I'm a mechanical dweeb and an electrical retard and I figured it out.
Maybe it was Utah. - H.I. McDunnough
Aanarchy is offline   Reply With Quote
Old 07-10-2012, 07:52 PM   #4429
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Fuel Injection Cleaner May Help
Originally Posted by Hooked View Post
I have been noticing my 08 (20,000 Kms) getting harder to start when I first fire it up after sitting over night or all day. Spark plug has about 6000kms,
valves have been done recently and that was no help,
tried different brands of fuel no different
even replaced the battery with a Shorai but it still starts hard! Any one able to shed some advice on a fix?
It usually starts very easy.
Before tearing into the fuel tank for fuel filter replacement or other more complicated diagnostics and fixes try some fuel injection cleaner. Sounds simple and it may work. Another suggestion that has worked for some here is to check the tightness of the battery connections. I will let others here do the heavy lifting if neither of these suggestions help given what you have already tried.
Hope this helps.
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 07-10-2012, 09:29 PM   #4430
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
Originally Posted by Pundy View Post
Anyone out there who uses something like a Giant Loop bag have any issues with the heel guard failing while using it as a tie point for your luggage? They seem a little flimsy to me. Thoughts?
I have a set of these on my 690 and strap my GL and other things to them frequently. ~$80
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 07-10-2012, 09:31 PM   #4431
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
the plugs are available on Digikey pretty inexpensively..... I will have to dig for the PN or URL reference. otherwise clip and splice from the OEM signals
Old 07-10-2012, 10:59 PM   #4432
777
Oddometer: 90
I am watching this one, I have some storey with 10 000km on my 08, done servce, osne valves, cgecked TPS, and mapping ,checked auto decompress lever etc, running out of option, new plug , checked the gap.
777 is offline   Reply With Quote
Old 07-11-2012, 01:11 AM   #4433
wino975
wino975's Avatar
Oddometer: 49
check also the coil and the spark plug cable
wino975 is offline   Reply With Quote
Old 07-11-2012, 06:34 AM   #4434
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
my back signals were destroyed so i thought i could replace with the sicass leds but they dont blink right until i get the relay. Do i have to get new front leds also to make it work right? if so they will be $14 ebay specials
MookieBlaylock is offline   Reply With Quote
Old 07-11-2012, 06:48 AM   #4435
empedrado
Oddometer: 365
I have struggled with erratic idling, stalling and hesitation at lights. The bike runs great otherwise. Yesterday I built a little tool to clean the injector as I have exhausted everything else. Going to clean the injector today for a ride I am going on the next day. Got my fingers crossed.
empedrado is offline   Reply With Quote
Old 07-11-2012, 08:27 AM   #4436
777
Oddometer: 90
Keep us posted
Old 07-11-2012, 08:47 AM   #4437
Aanarchy
Aanarchy's Avatar
Oddometer: 1,083
My rear signals worked fine wiithout the relay. Then I added the front signals nothing would flash until I plugged in the relay. Then all was fine.
There were two relay options from sicass - $$ and $. I got the $ and it worked. Don't remember exact price, but it was minimal.
Old 07-11-2012, 08:54 AM   #4438
Aanarchy
Aanarchy's Avatar
Oddometer: 1,083
Gearing - 14 x 48?
This may be a simpleton question in a thread with so many advanced topics but I need to ask -
Stock gearing was 15 x 45. All the threads I could find on gearing said 15 x 48 was the trick. I'm running a 14 x 45 and thinking about going to a 48 on the rear with the 14 front. Any comments? Anyone have this combo?
Old 07-11-2012, 09:16 AM   #4439
RickA
Fat Old Adventurer
RickA's Avatar
Oddometer: 87
Gearing Ratios
Hi all,
Stock gearing of 15-45 gives you a 1:3.00 ratio, 14-45 gives you 1:3.21 and 14:48 gives you 1:3.43 - a lot lower ratio.
Do you need to go down that far? You are also adding 3 links therefore a new chain.
I run 14-45 and find it a good all-round compromise with std chain length being an additional bonus.
Hope that helps!
Cheers, Rick.
RickA is offline   Reply With Quote
Old 07-11-2012, 09:36 AM   #4440
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Gearing
A number of us have posted on this before but many of our old posts have been lost with the demise of the old 690 Megathread. I believe some here can provide you a link to a site, perhaps called gearing commander or something like that, which explains the increase or decrease in rpm at various speeds given the variables of increases or decreases in countershaft tooth size and rear sprocket size.
You are correct about what is stock, i.e., 15/45. I have 14/45 which is the equivalent of 15/48. As I remember it, 1 tooth down or up on the countershaft sprocket is the equivalent of going 3 teeth up or down on the rear sprocket. Countershaft sprockets are easier to change out than rear sprockets and cheaper as well which may influence your decision.
Since you already have 14/45, or the equivalent of 15/48, you know how the bike deals with slab and off-road speeds/conditions. I believe that if you go to 14/48 you will be screaming the motor at normal highway speeds and will seldom use first gear off-road given the torque of the 690. I have experimented with both on my previous KTM Enduro and believe that 14/45 or 15/48 represents the best compromise for the bike.
Worthy of note on this subject is chain tension. If you tighten your chain more than KTM recommends you can hasten the demise of the countershaft sprocket oil seal which can be a pain in the ass to fix, as some here have reported. Fortunately I have never had this problem.
Hope this helps.
Times are GMT -7.   It's 12:13 PM.
