Old 07-11-2012, 09:42 AM   #4441
Aanarchy
Aanarchy's Avatar
Oddometer: 1,120
Originally Posted by RickA View Post
Hi all,
Do you need to go down that far? You are also adding 3 links therefore a new chain.
I run 14-45 and find it a good all-round compromise with std chain length being an additional bonus.
Hope that helps!
Cheers, Rick.
Additional data, so yes it helps. Do I need it? Not sure, but I'm sure it would help getting up some of the gnarlier hills, and make it easier to loft the front wheel over ledges. It's a heavy bike.
Surprised that it would take three extra links. Stock chain is a 114 link, same as stock on my 2008 450EXC-R, which came with same stock gearing. I have 14 x 48 on the 450 with a 116 link chain. I'm moving to a 50T rear on that bike, and I think the 116 will still work, based on Hodakaguy's posts about his 530.
But you're right about the 14 x 45 being a good compromise. A little higher revving on the highway but not too much, and decent in the dirt. New sprocket = $78 and a chain $150+/-. Not insignificant.
Maybe it was Utah. - H.I. McDunnough
Aanarchy is offline   Reply With Quote
Old 07-11-2012, 09:47 AM   #4442
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Beat Me To It
Hi all,
Stock gearing of 15-45 gives you a 1:3.00 ratio, 14-45 gives you 1:3.21 and 14:48 gives you 1:3.43 - a lot lower ratio.
Hope that helps!
Cheers, Rick.
Rick, while I was composing my post with a sore right hand, read really slow typing, you got yours out. It seems as though we agree on this. Great minds think alike or something like that.
Cheers,
Tom
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 07-11-2012, 09:53 AM   #4443
Aanarchy
Aanarchy's Avatar
Oddometer: 1,120
Originally Posted by nippybit View Post
I believe some here can provide you a link to a site, perhaps called gearing commander or something like that, which explains the increase or decrease in rpm at various speeds given the variables of increases or decreases in countershaft tooth size and rear sprocket size.
You are correct about what is stock, i.e., 15/45. I have 14/45 which is the equivalent of 15/48. As I remember it, 1 tooth down or up on the countershaft sprocket is the equivalent of going 3 teeth up or down on the rear sprocket. Countershaft sprockets are easier to change out than rear sprockets and cheaper as well which may influence your decision.
Since you already have 14/45, or the equivalent of 15/48, you know how the bike deals with slab and off-road speeds/conditions. I believe that if you go to 14/48 you will be screaming the motor at normal highway speeds and will seldom use first gear off-road given the torque of the 690. I have experimented with both on my previous KTM Enduro and believe that 14/45 or 15/48 represents the best compromise for the bike.
Hope this helps.
I've looked at the gearing computation sites, and I don't remember the revs being that high at 70MPH, but it sounds like this is the answer. Thanks.
This is the gear site I used - http://gearingcommander.com/
Which I got from this thread - http://www.advrider.com/forums/showthread.php?t=549734
So I guess survey says - 14x45
Aanarchy screwed with this post 07-11-2012 at 10:02 AM
Old 07-11-2012, 10:17 AM   #4444
LukasM
Oddometer: 5,415
Nippy,
You don't exactly have to be a rocket scientist to figure out gearing, it's grade school math.
14/45=0.3111
15/48=0.3125
So 15/48 is about .5% higher than 14/45, which won't really be noticeable on a bike. Going down 1 tooth on the CS and staying with the stock rear will lower it 6.66% from stock, which is noticeable.
Now use your multiplication and division skills to figure out the rest from here, or let the Gearing Commander website do it for you...
Old 07-11-2012, 12:43 PM   #4445
GezwindeSpoed
GezwindeSpoed's Avatar
Oddometer: 230
An added bonus is when going to 14 tooth you just have to turn the adjuster block and you are almost right in tension. I change often between 14 and 15 which is really easy.
FE570; CB500X; KLE500
GezwindeSpoed is offline   Reply With Quote
Old 07-11-2012, 01:05 PM   #4446
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
Got my Vortex installed yesterday. First time I ever had a bike that wheelied in a dry river bed. I'm truly impressed.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 07-11-2012, 03:24 PM   #4447
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,201
Originally Posted by aanarchy View Post
my rear signals worked fine wiithout the relay. Then i added the front signals nothing would flash until i plugged in the relay. Then all was fine.
+1
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 07-11-2012, 03:53 PM   #4448
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Best move I made swapping the stock ECU with a Vortex. Really woke the bike up.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 07-11-2012, 05:32 PM   #4449
Pundy
Oddometer: 339
Originally Posted by Head2Wind View Post
I have a set of these on my 690 and strap my GL and other things to them frequently. ~$80
Now that is the ticket! Thanks H2M!
Pundy is offline   Reply With Quote
Old 07-11-2012, 05:35 PM   #4450
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 954
seat o' the pants gearing calculator
I alternate my gearing between 14/15/16 cs and 45/48 rear sprockets. Most of the time the bike is used offroad or for my daily 3 mile ride to work so 14/48 is rarely a problem on the highway. I've ridden several 200 mile+ days with 14/48 and I do find myself shifting for 7th on the highway, but it will still cruise at 70 with no concerns. I think that my next rear will be a 50tooth, it isn't because a lack of torque so much as a lack of rpm in the tight stuff... I want to be able to ride slower without touching the clutch.
I've only ridden the other end of the spectrum (16/45) for ~500 miles and seriously stayed in 5th for at least 10 miles everytime I got on the highway because I thought that I was already in 6th. For speeds under 80 on the highway, 16/45 is too tall for my liking. I'd probably use this gearing combo more if I wasn't concerned with my knobbies coming apart at a sustained 90+mph.
That being said, like so many others, 15/48 is my go-to gearing when I leave from the house and don't know where I'll end up. I can comfortably cruise the freeway and with minor clutch work I can still wrestle the pig through black diamond singletrack.
When school starts back up next month and my commute goes back to 70miles, I'll switch back to stock 15/45.
All of these combos are run with a chain that is 2 links longer than stock and I just might be able to run 14/50 with the same chain.
All the sprocket swaps sometimes make me wish I had just bought a TE630 like my buddy who went -1 on the CS and is good to go for anything.... that is untill I ride his bike and immediately miss the power/handling/suspension/ and yes even the close ratio tranny of the 690. I'll live with it
here's the link to http://www.gearingcommander.com/ in case nobody posted it yet, the 690 is already loaded there.
The Letter J is offline   Reply With Quote
Old 07-11-2012, 07:25 PM   #4451
motoged
motoged's Avatar
Oddometer: 908
I ride with a 15/46 (the 46 cuz that was the only Ironman sprocket my guy had at the time)...If I find myself in the triple black diamond super-macho gnarly tight switchbacks....I just pull out my 450 and rip it up
Too tight a chain also plays havoc w/ rear wheel bearings....the linkage on the 690 is less worrisome for this concern than the rest of the R bikes.
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 07-11-2012, 09:34 PM   #4452
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,667
Originally Posted by LukasM View Post
Nippy,
True story.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 07-12-2012, 01:16 AM   #4453
Kirkster
Parts Murderer
Oddometer: 296
Can you post a pic of how the install looks? What goes bu-bye and what gets added....
K
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 07-12-2012, 02:39 AM   #4454
wino975
wino975's Avatar
Oddometer: 49
do you really need more power from the 690?
wino975 is offline   Reply With Quote
Old 07-12-2012, 04:48 AM   #4455
dirtbikeslob
Oddometer: 300
i suppose you have to justify the cost
dirtbikeslob is offline   Reply With Quote
Times are GMT -7.   It's 12:34 PM.
