Old 07-19-2012, 03:56 AM   #4561
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 976
Rally Raid Steering Damper
Hi All
I received my Rally Raid Products steering damper kit yesterday (RRP 020). No instructions were included to fit the post and pin. They appear to be slow to answer e-mail requests for the instructions. Anybody here got a link to installing their stuff or got original instructions that can be shared?
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 07-19-2012, 04:58 AM   #4562
BATCAVEBUNYIP
Grin Factor
Oddometer: 5
Road tyres
Hi ya,
Can anyone recommend some sticky road tyres to fit on standard wheels?
Cheers
BATCAVEBUNYIP is offline   Reply With Quote
Old 07-19-2012, 05:57 AM   #4563
Pundy
Oddometer: 341
Grab handle bolts spinning in the gas tank
As you can see below, 2 of the bolts that hold my G-iT rack on, have backed out on their own. When I went to tighten them back in I screwed the pooch somehow and they are now spinning the inserts that they are screwed into. I HAVE to get these out. I broke off my tail light assembly which means that I need to remove this rack in order to do so. Has anyone had any experience in drilling these bolts out? I'm at a loss.
Pundy is offline   Reply With Quote
Old 07-19-2012, 06:04 AM   #4564
tertsu
Oddometer: 16
Originally Posted by Maxacceleration View Post
Anyone put on Rally Raid 9.5 twin auxiliary tanks on their '12 690 yet?
Issues of side panels fitting?
I'd like to hear from you.
$223 more for a 2012 690 kit? One that doesn't fit?
My friend has 2012 tank kit and the kit includes older modell side panels with 2012 decals.
tertsu is online now   Reply With Quote
Old 07-19-2012, 07:24 AM   #4565
Night Crawler
Night Crawler's Avatar
Oddometer: 94
Originally Posted by beaney View Post
22K resistor but I cant remember which 2 of the 3 wires it goes between.
Originally Posted by Uller View Post
Awesome, the resistor size is the hard part. I can figure out the rest....
Thanks for the shock/linkage info.
Can we get some more detail on this? Maybe post a mini tutorial, as there are more of us who would like to bypass the rollover sensor.
Night Crawler is offline   Reply With Quote
Old 07-19-2012, 07:26 AM   #4566
SKINNY
SKINNY's Avatar
Oddometer: 648
Originally Posted by Bill the Bong View Post
Hi All
See post #3082...I had the same problem
SKINNY is offline   Reply With Quote
Old 07-19-2012, 07:28 AM   #4567
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by Astatine View Post
(1) change the spark plug, (2) change the spark plug cap
pretty ez if you have the spark plug wrench from the tool kit and a torque wrench,iirc it gets tightened 18 nm. Remove 4 bolts holding airbox, plus the regulator for access to one of those bolts. Loosen rear clamp between airbox and throttle body, lift out airbox. Pull off rubber thing over spark plug, kind of a pain getting this out,there are indents to use a wrench for better leverage, not a big deal if the wire comes out as it will go back in.Rig up torque wrench spark wrench. Blow compressed air,maybe solvent to clean area around plug. Remove. Hand thread new plug,tighten but definitly dont over tighten
MookieBlaylock is offline   Reply With Quote
Old 07-19-2012, 07:31 AM   #4568
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,211
Hmmm... Can you ask on how they fitted up?
I would say the side panels are a special design for working with the twin tanks?
When the front of my side panels are mounted up, the rear mounting points a almost 2"off!
I can almost bend them to fit, but not quite.
I can get the side pictured to fit.
The other side is worse & I haven't been able to align to bolt the rear into the top tank mount. Grrr
I should have read between the line on RR stuff 'barely' fitting & sketchy replies to customers.
Maxacceleration is offline   Reply With Quote
Old 07-19-2012, 07:42 AM   #4569
Bill the Bong
Supern00ba
Oddometer: 976
Awesome, thanks Skinny. Wonder why they would send it out without instructions? Did you have to cut the plastic cover to make space?
Old 07-19-2012, 07:51 AM   #4570
SKINNY
SKINNY's Avatar
Oddometer: 648
The plastic covers on each side of the ignition switch don't have to be trimmed, but the rubber grommet gizmo that slips over the ignition switch won't fit quite right since the switch is moved back by the thickness of the Rally Raid mounting pin...My 2008 model didn't have any of that trim over the switch...I'm not sure when it was added.
I had to remove the coolant tank in order to get the ignition switch off.
Old 07-19-2012, 08:00 AM   #4571
Bill the Bong
Supern00ba
Oddometer: 976
Thank you kindly
Old 07-19-2012, 08:02 AM   #4572
beaney
rally racer
beaney's Avatar
Oddometer: 124
I made up this to plug into the loom so to keep all connectors intact.
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 07-19-2012, 09:15 AM   #4573
Astatine
Oddometer: 18
Thanks for the info. Unfortunately, I don't have either the tool kit (so no spark plug wrench) or a torque wrench...
Astatine is offline   Reply With Quote
Old 07-19-2012, 09:35 AM   #4574
Night Crawler
Oddometer: 94
Those two wires have the resistor soldered between them, and that plug connects to the one that used to go into the sensor?
Old 07-19-2012, 09:45 AM   #4575
Night Crawler
Oddometer: 94
Just stick a flat head screwdriver in the notch on the spark plug cap and pop it off. Use a 14mm deep socket and flexible joint in between to 3" extensions and you wont have to remove the air box.
Times are GMT -7.   It's 04:56 AM.
