Old 07-18-2012, 11:25 PM   #4576
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,193
Anyone put on Rally Raid 9.5 twin auxiliary tanks on their '12 690 yet?
Issues of side panels fitting?
I'd like to hear from you.
$223 more for a 2012 690 kit? One that doesn't fit?
Maxacceleration screwed with this post 07-19-2012 at 02:56 AM
Maxacceleration is offline   Reply With Quote
Old 07-19-2012, 12:15 AM   #4577
beaney
rally racer
beaney's Avatar
Oddometer: 124
Originally Posted by Uller View Post
Thanks for that. More questions though.....
Is the shock required? I am guessing that is what LukasM's question would be getting to. Correct me if I am wrong but, if the linkage is made for the Rally bike w/ 300 - 305mm of suspension (change in geometry) it wouldn't probably work with my lowly 250mm '08 shock.
The linkage geometery and ratio hasnt changed ( the extra travel is in the lenght of the shock, but would make you steering geometry change if still using the short front forks), but the standard shock will not work. The rally linkage uses a shock with a fork on the end instead of a bearing. The rally shock would also need to be shortened for the standard bikes. I'm already running factory cone valve forks so I dont have a problem.
Also, with those being rally parts, are they basically unobtanium (Made in such small quantities that the cost is outragous and us mere mortals probably can't even find them) or would they be redily available if I too wanted to upgrade?
All the rally parts are available, but are not cheap, the rally shock will be near $2500.
Their may be other parts that will work, I;ve only used what parts I've had in the workshop.If the ohlins guys can come up with a shock then parts may change.
I've also asked Ohlins to se if they can make a straight replacement shock for the 690 that will work with the standard linkage.
However, if custom suspension is involved I guess I'll just have to live. Suspenders tend to be beyond my price range for upgrades at the moment.
P.S. - If I recall correctly, you once posted on here what the resistance value is for cancelling out the rollover switch. Do you happen to remember what that is? Thanks!
22K resistor but I cant remember which 2 of the 3 wires it goes between.
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 07-19-2012, 12:37 AM   #4578
Uller
Uller's Avatar
Oddometer: 1,674
Awesome, the resistor size is the hard part. I can figure out the rest....
Thanks for the shock/linkage info.
Uller is offline   Reply With Quote
Old 07-19-2012, 01:20 AM   #4579
wino975
wino975's Avatar
Oddometer: 49
mmmmm.... for the rollover switch (EPC) I've simply disconnected the wires in the plug leaving connected only the green wire.
wino975 is offline   Reply With Quote
Old 07-19-2012, 01:29 AM   #4580
beaney
rally racer
beaney's Avatar
Oddometer: 124
Thats fine but you still require a working switch to prevent the fi light from flashing, With the resistor you can completely remove it from the system, thus removing another failure point.
only my thoughts from what we've done to the race bikes.
690 enduro/ rally
350 exc
Old 07-19-2012, 02:24 AM   #4581
wino975
wino975's Avatar
Oddometer: 49
Oh, I misunderstood
so that's cool
how can we find the right couple of wires? simply trying one or the other?
Old 07-19-2012, 04:01 AM   #4582
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,540
Originally Posted by Astatine View Post
I recently bought a used 2008 Enduro and just found out that it needs some work. How hard is it for someone with zero wrenching experience to: (1) change the spark plug, (2) change the spark plug cap, and (3) replace the rear tail light assembly?
Also, since I need to get a new tail light assembly, are there any specific ones that people recommend?
Thanks for the help!
I can't speak to 1&2 but the tail assembly pretty much bolts on. You will need to remove or at least undo the one piece plastic that wraps around the fuel tank input and sides. To do this you need to remove the grab handles if they are mounted and undo some parts around the gas cap. After that you'll need to unplug the lights unbolt the tail and remove. Should take all of 20 minutes your first time through. Can't imagine the spark plug is all that involved either.
CanadianX is offline   Reply With Quote
Old 07-19-2012, 04:56 AM   #4583
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
Rally Raid Steering Damper
Hi All
I received my Rally Raid Products steering damper kit yesterday (RRP 020). No instructions were included to fit the post and pin. They appear to be slow to answer e-mail requests for the instructions. Anybody here got a link to installing their stuff or got original instructions that can be shared?
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 07-19-2012, 05:58 AM   #4584
BATCAVEBUNYIP
Grin Factor
Oddometer: 5
Road tyres
Hi ya,
Can anyone recommend some sticky road tyres to fit on standard wheels?
Cheers
BATCAVEBUNYIP is offline   Reply With Quote
Old 07-19-2012, 06:57 AM   #4585
Pundy
Oddometer: 339
Grab handle bolts spinning in the gas tank
As you can see below, 2 of the bolts that hold my G-iT rack on, have backed out on their own. When I went to tighten them back in I screwed the pooch somehow and they are now spinning the inserts that they are screwed into. I HAVE to get these out. I broke off my tail light assembly which means that I need to remove this rack in order to do so. Has anyone had any experience in drilling these bolts out? I'm at a loss.
Pundy is offline   Reply With Quote
Old 07-19-2012, 07:04 AM   #4586
tertsu
Oddometer: 16
My friend has 2012 tank kit and the kit includes older modell side panels with 2012 decals.
tertsu is online now   Reply With Quote
Old 07-19-2012, 08:24 AM   #4587
Night Crawler
Night Crawler's Avatar
Oddometer: 87
Can we get some more detail on this? Maybe post a mini tutorial, as there are more of us who would like to bypass the rollover sensor.
Night Crawler is offline   Reply With Quote
Old 07-19-2012, 08:26 AM   #4588
SKINNY
SKINNY's Avatar
Oddometer: 645
Originally Posted by Bill the Bong View Post
Hi All
See post #3082...I had the same problem
SKINNY is online now   Reply With Quote
Old 07-19-2012, 08:28 AM   #4589
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
pretty ez if you have the spark plug wrench from the tool kit and a torque wrench,iirc it gets tightened 18 nm. Remove 4 bolts holding airbox, plus the regulator for access to one of those bolts. Loosen rear clamp between airbox and throttle body, lift out airbox. Pull off rubber thing over spark plug, kind of a pain getting this out,there are indents to use a wrench for better leverage, not a big deal if the wire comes out as it will go back in.Rig up torque wrench spark wrench. Blow compressed air,maybe solvent to clean area around plug. Remove. Hand thread new plug,tighten but definitly dont over tighten
MookieBlaylock is offline   Reply With Quote
Old 07-19-2012, 08:31 AM   #4590
Maxacceleration
Awol
Oddometer: 2,193
Hmmm... Can you ask on how they fitted up?
I would say the side panels are a special design for working with the twin tanks?
When the front of my side panels are mounted up, the rear mounting points a almost 2"off!
I can almost bend them to fit, but not quite.
I can get the side pictured to fit.
The other side is worse & I haven't been able to align to bolt the rear into the top tank mount. Grrr
I should have read between the line on RR stuff 'barely' fitting & sketchy replies to customers.
Times are GMT -7.   It's 06:43 AM.
