Old 07-20-2012, 04:18 PM   #4591
rdkyote
rdkyote's Avatar
Oddometer: 72
nevermind... found it.
2012 KTM 690 Enduro R
2007 KTM 250 XC
rdkyote screwed with this post 07-20-2012 at 05:33 PM
rdkyote is offline   Reply With Quote
Old 07-20-2012, 08:06 PM   #4592
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,065
Originally Posted by Seth S View Post
Bike overheated in Australia...turned out water pump seals had failed. Fixed water pump seals back in USA and then Headgasket failed when bike got warm after 60 miles of riding. Have to pull head at least, check for warpage, replace head gasket, go from there etc.
Mine did a head gasket , seems not uncommon . I`d recomend a surface grind also . No probs in the 10,000 km since doing it .
Brute is offline   Reply With Quote
Old 07-21-2012, 04:08 AM   #4593
Czechie
Czechie's Avatar
Oddometer: 75
Originally Posted by Gros Buck View Post
Ok. 2nd shot ...
Paul Jr
Paul, the same just happened to me and you know what my friends told me? You are sitting on this bike too much , stand up on pegs . I even broke that hook ath the front of the seat and it does on hold any longer there and I need to tape it down. Well I will try the higher gel KTM seat and will see.
This is the price for ligher bikes, lighter materials which does not last that long.
Czechie is offline   Reply With Quote
Old 07-21-2012, 04:12 AM   #4594
Leviathan
Tenerider
Leviathan's Avatar
Oddometer: 142
"What'cha doing there buddy?"
"What does it look like? Maintenance!"
Nobody said that pushing the TB back into place is a part of regular maintenance.
From our last ride.
Leviathan screwed with this post 07-21-2012 at 06:08 AM
Leviathan is offline   Reply With Quote
Old 07-21-2012, 07:43 AM   #4595
Frontwheel21
Oddometer: 43
Just out of interest, what do you think caused the TB to get disconnected?
Something related to post #85 in this thread ?
Frontwheel21 is offline   Reply With Quote
Old 07-21-2012, 07:45 AM   #4596
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Yes but ...
There's also the fact that the length of my legs being what it is, there's not much difference whether I stand or I sit ...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 07-21-2012, 10:37 AM   #4597
Beemermcr
Big, Dumb, Happy!
Beemermcr's Avatar
Oddometer: 293
2008 690e stalling help!!
Hi - bought a 2008 690 E from an out of state dealer; during check ride/pickup bike stalled out after 2/3 blocks:
- starts normally
- revs normally
- stalls at 60-90 seconds; blipping throttle will not stop stalling once it starts
- turn off, back on and it starts fine, only to stall again after the 60-90 seconds
Bike has FMF installed, K&N air filter, handlebar mounted 3 position mapping switch, position 2
Dealer is working hard to get the bike fixed:
- checked tank integrity and fixed a small hole by integrated mounting nuts
- replaced fuel filter
- replaced battery
- cleaned dirty fuel injector
After these, bike ran well for 6 miles of a test ride then stalled and is repeating 60-90 second pattern
Ideas to be checked next:
- re-verify tank is venting properly
- verify all fuel hoses are EFI rated
- check EFI regulator
- EFI Reset procedure
- TPS Reset procedure
- check maps for EFI CPU and ept throttle body CPU
- check earth connection to frame
- check electrical connections around the throttle body and coil connections for dust fouling
Above are what I can find as causes for 690s running poorly or stalling; anything we have missed? Any ideas would be appreciated -
Thanks in advance!
Paul
Paul Baird
Sandy, UT
2013 Husky/BMW/KTM Terra
2000 DRZ "Burro"
Beemermcr is offline   Reply With Quote
Old 07-21-2012, 10:42 AM   #4598
Velociraptor
TrackBum
Oddometer: 1,139
- starts normally
- revs normally
- replaced battery
Thanks in advance!
Paul
Check coil connections and of course your fuel pump may be bad.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 07-21-2012, 11:22 AM   #4599
Beemermcr
Big, Dumb, Happy!
Beemermcr's Avatar
Oddometer: 293
Thanks - fuel pump bad is added!
Paul Baird
Sandy, UT
2000 DRZ "Burro"
Old 07-21-2012, 11:35 AM   #4600
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,887
- starts normally
- revs normally
- replaced battery
Thanks in advance!
Paul
Voltage regulator issue can mirror a bad fuel pump according to some reports...
BK.RD.RNR is offline   Reply With Quote
Old 07-21-2012, 11:45 AM   #4601
Leviathan
Tenerider
Leviathan's Avatar
Oddometer: 142
When we had the bike in pieces, I took a look infront of the airbox. I couldn't see any connectors or wires that were pushing on the airbox.
The TB was pushed out by a backfire, though it really did sounded like a loud "pop" rather than a normal backfire.
The bike is dead stock, with about 1000KM. So it might be a lean mixture straight from the factory. I can't really tell.
Luckily I have another friend with a brand new 2012, so I'll probably get another chance to check it.
Old 07-21-2012, 03:16 PM   #4602
rdkyote
rdkyote's Avatar
Oddometer: 72
Check the overflow tubing from the top coolant reservoir. They routed that under my airbox and believe it or not, was pushing it back. Kinda like a big rubber band i guess. I rerouted it over and to the side.
2007 KTM 250 XC
Old 07-21-2012, 03:49 PM   #4603
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,919
HI ALL
can any one give me a link to a set of plug & play blinkers for my 2012
thanks mickd
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is online now   Reply With Quote
Old 07-21-2012, 08:41 PM   #4604
numbutt
john
numbutt's Avatar
Oddometer: 103
Adding a fuel pump to the 690....
For those punters who have considered it, talked about it, I now have the first ?? incarnation of a 690 with TWO fuel pumps [ and that is without the use of a carton of the Yank ''fix all '' JB Weld !! ]...one of which is easily serviceable. The existing pump was belatedly retained [ it was to go ] and a CW one fitted on the exterior. The bike can now be '' switched '' from one pump to the other with a toggle switch even with the engine running .......without even a hint of a dropout.
There are many options to modification but as a first off project a lot of looking, thought and accelerated lifetime tests have slowed things. I personally don't like the suggestion to add a larger car-type pump [ the CW pumps 500ml at 3 bar and 3.52 amp draw ..no load 2 liters per min at 2.5 amps ] as from what i can see the pump is directly switched by a semiconductor in the CPU not through a relay ???....larger pumps have larger draws and larger back EMF's that could damage the semiconductor.
Reliability was my main concern and of course not creating a mobile fire hazard.
for those with interest i will post a number of photos which should be self explanatory not all in one lot as i am still mastering this forum ''photo add thing '''!!!
[IMG][/IMG][IMG][/IMG][IMG][/IMG]
numbutt is offline   Reply With Quote
Old 07-21-2012, 08:55 PM   #4605
numbutt
john
numbutt's Avatar
Oddometer: 103
Extra pump photos continued
[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Times are GMT -7.   It's 04:16 PM.
