Old 07-24-2012, 06:25 PM   #4666
BluePill
AARP Slacker
BluePill's Avatar
Oddometer: 4,859
Check the R&R clutch video at RockyMountainAtv.
2008 WR250R - Tru Blu
"While we live, let's live"
BluePill is offline   Reply With Quote
Old 07-24-2012, 06:29 PM   #4667
jonnykilo
Traveller
Oddometer: 205
Steam Punk
Originally Posted by Seth S View Post
Now now be nice. This guy did a lot of things mentioned...His work has a very steam punk quality to it but it is good to see progress. I have not touched a bike in about a month due to other things in life going on.
I do have to ask why the massive 13th century chain guard?...Looks like an invitation for disaster or accelerated chain wear at the least.
Uhhh, loved the the steam punk comment. But seriously, have we heard a bit more about the chain guard yet?
jak
jonnykilo is offline   Reply With Quote
Old 07-24-2012, 06:39 PM   #4668
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,654
Clutch compression tools...i used my hands when i changed my clutch...no compression tools needed
Thanks Seth. I just did not know if it would fly apart on me. Should I just keep some pressure on the inner basket when disassembling/ reassembling then?
BK.RD.RNR is offline   Reply With Quote
Old 07-24-2012, 06:41 PM   #4669
Subluxator
Oddometer: 7
Originally Posted by motokeith View Post
The install is not difficult, but a little time consuming. You are relocating parts like the coil and regulator/rectifier onto new brackets and rerouting the associated wiring. You have to remove the airbox in order to install the bracket/stud things that hold the tanks. You will be drilling holes into part of the fuel pump assembly. You will need to remove the rear wheel or remove the lower tank bolt and flip-up the tank to get to the fuel pump. The actual installation and the supplied instructions are not exactly a "Tab A into slot B" sort of affair and there's a bit of trial and error fitting needed to get everything to go together nicely. If you would be comfortable to walk out in the garage and remove body panels, wheels, airbox, electrical bits, and various hoses and wires on your bike and put it all back together again then installing this kit is not an issue.
The two tanks come together at a T fitting which then runs into a inlet on a machined plate that is added to the bottom of the fuel pump assembly on the main tank. I've only had the tanks on a few days now, but I don't really notice any drastic ergonomic impact. I don't have any interference when standing on the pegs. Obviously, if you scoot up to the front of the seat your knees will be splayed a bit wider, but not really much of an issue.
great thanks.
Subluxator is offline   Reply With Quote
Old 07-24-2012, 06:52 PM   #4670
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,654
Thanks BP, just saw this post, not sure what you mean by R&R, but watched the clutch replacement video. I'm assume the tools the manual refers to are just to hold things together, not that they are neccessarilly "under pressure" per se.
Old 07-24-2012, 08:02 PM   #4671
kenny61
Crazy Idiot
kenny61's Avatar
Oddometer: 24,641
R&R in mechanic speak means something like repair or replace. or remove and replace or gouge the fuck out of the owner...
On the plains of hesitation lie the blackened bones of countless millions who at the dawn of victory lay down to rest, and in resting died.
Go forth and be a force of the awesome!
kenny61 is offline   Reply With Quote
Old 07-24-2012, 09:08 PM   #4672
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,605
The clutch comes apart just fine without, but I lost patience for trying to assemble it without the tools.
My suggestion, get some allen-head cap screws & some washers. IIRC the thread is 4mm x .8, and you need about 1.5" of threads to compress the slipper springs.
Or, I could drop my shop-made tools in the mail to you. They aren't pretty to look at, but they work.
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 07-25-2012, 03:36 AM   #4673
Falcon Rust
Oddometer: 96
Question.
Hi,
i am currently looking at upgrading my bike. one question i have is if anyone uses Rotopax, instead of buying the expensive tanks? would it be possible to just add one 2 gallons on each side of the rear rack?
thanks for your time,
Daniel
Falcon Rust is offline   Reply With Quote
Old 07-25-2012, 03:45 AM   #4674
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,654
Thanks Al. I have to get it apart, put together a parts list for ordering, etc. first.
I'll give it a go without them, but if I get into a bind, I'll pm you. Thanks for the offer.
Old 07-25-2012, 04:41 AM   #4675
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,048
Originally Posted by Bill the Bong View Post
Did aliens abduct all the 690 jockeys?
Yer !!! I liked the anal probe the best .
Brute is offline   Reply With Quote
Old 07-25-2012, 04:47 AM   #4676
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
Originally Posted by Falcon Rust View Post
Hi,
Daniel
Sure can. Take a look at the Rally Raid Products soft luggage rack. Already sorted for attaching Rotopax.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 07-25-2012, 06:23 AM   #4677
ramjet
ramjet's Avatar
Oddometer: 2,204
Or the Kriega system:
http://www.ktmtwins.com/ktm-690-part...latform-system
Fundamentally transforming a KTM..
ramjet is offline   Reply With Quote
Old 07-25-2012, 11:01 AM   #4678
Roadracer_Al
Oddometer: 1,605
That's pretty slick. And, I like the RotoPax system -- the mounting hardware is robust, the rotomolded tanks are very thick and durable, and it's all made in USA.
Old 07-25-2012, 11:34 AM   #4679
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,202
My rotopax have failed (two, both of them). The nozzles expanded within the container.
There was no pulling then out of the container. To do so the nozzles broke apart leaving broken pieces in the containers.
The last time the nozzles did slide out it was just barely with an extremely tight rocking back & forth to pull them out.
I hope their system has changed - I am not a fan of rotopax.
Probably a blame the DOT for ALL THE CRAPPY GAS CANS THAT ARE OUT THERE.
What are they thinking. They all leak, dribble or are uncontrollable.
Therefore the reason I went to RR for a mounted gas tanks system.
Grrr, Bad on rotopax.
They fill up my lawn mower now.
Maxacceleration is offline   Reply With Quote
Old 07-25-2012, 12:17 PM   #4680
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Maxacceleration View Post
My rotopax have failed (two, both of them). .....
Rotopax system is more expensive than RR or Safari tanks......and complicate your packing system.....
Overpriced system I think.....while I am happy with my Safari (aside from crappy fuel petcocks [bad design])....I would even go with RR tanks before Rotorooter packs....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Times are GMT -7.   It's 01:16 AM.
