Old 07-29-2012, 02:06 PM   #4771
Uller
Uller's Avatar
Oddometer: 1,681
Originally Posted by rickypanecatyl View Post
I really like the look of this however, wonder how you would protect the headlights from rock damage with them sticking out past the fairing like that?
Uller is offline   Reply With Quote
Old 07-29-2012, 02:09 PM   #4772
alongat
alongat's Avatar
Oddometer: 1,217
Originally Posted by Garp View Post
The 690 SMC and 690 Enduro are the bikes you're thinking of. That tank is off a 690SM, which is a completely different beast.
Bloody hell...and I suppose the two bikes that are similar both use the rear mounted fuel tank, right? Back to the drawing board...
Toronto, Canada
KTM 1190 ADV, KTM 530 EXC
Gone: Ducati 999R, KTM 530EXC, KTM 990ADV-R, KTM 950ADV, KTM 690, KTM 640ADV, kTM RC8R, Ducati 996S, Yamaha R1
And how can this be? For he is the Kwisatz Haderach!
alongat is offline   Reply With Quote
Old 07-29-2012, 02:24 PM   #4773
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
I'm thinking a stainless mesh cage over them might do the job. Been looking for a way to get some HIDs mounted up front of mine and think this may at least provide the platform. Alternatively, I need to go see Colebatch's guru to get something fabricated to mount them.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 07-29-2012, 02:58 PM   #4774
mickd
crash test dummie
mickd's Avatar
Oddometer: 1,914
HI ALL
I've got a 2012 690 with just over 1000k's on her,been brill so far,put a fmf on all good,but when she had her 1st service they did the akro mapping,now she stalls every now and again,i had a ride in the bush and it happened
around 6 to 7 times all in a different way,so hard to place what and how it does it,any help here b4 i go into the dealers again today??
thanks mick
You suck. And your mother dresses you funny.
I've just been to my first muslim birthday party. Musical chairs was a bit slow but F**k me, pass the parcel was bloody quick.
mickd is online now   Reply With Quote
Old 07-29-2012, 02:59 PM   #4775
Uller
Uller's Avatar
Oddometer: 1,681
That makes sense....Thanks.
Old 07-29-2012, 09:07 PM   #4776
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,608
Originally Posted by motoged View Post
Seth,
For a minute there I thought you were still drunk and had fingers full of peanut butter
Glad it was "the phone's fault"
Cant have peanut butter...severe allergy
Seth S
Seth S is offline   Reply With Quote
Old 07-29-2012, 09:28 PM   #4777
FriedDuck
Why die all tensed up?
FriedDuck's Avatar
Oddometer: 429
Parachute math question:
2 guys jump out of an airplane. 1 guy has a quality chute that deploys 99.9% with no back up. The other guy has a cheaper chute that only opens correctly 80% of the time BUT he has 2 back ups for a total of 3. Whose got the better odds for survival?
So...20% chance of failure of each means .20 x .20 x .20 = 0.008, or .8% chance that all 3 fail. So the guy with the chute that only fails .1% of the time has a better chance of living to argue with his dealer
Whaddo I win?
BTW I have about 12k miles on mine with no issues. Single track, jumps within reason, sport-commuting and FS roads. Most fun ever!
FriedDuck is offline   Reply With Quote
Old 07-29-2012, 11:40 PM   #4778
beaney
rally racer
beaney's Avatar
Oddometer: 124
Thats the proto type, the screen will be redesigned to have a perspex cover over the lights. Until they get the first evo 2 tanks the fairing design is not set in stone and will change.
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 07-30-2012, 05:24 AM   #4779
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
Somebody had a rectifier failure on here that they said at first seemed like a pump failure. Could you please tell me the symtoms
Bike dies when running at speed but switching the kill switch off and on will start the bike again WTF is it now?
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 07-30-2012, 05:44 AM   #4780
DirtJack
DirtJack's Avatar
Oddometer: 1,598
I'm no expert, but if the clutch switch is disabled, the bike thinks the clutch is pulled in, hence the fact it will start in gear. So, when the bike is on the over-run, it thinks the clutch is pulled and will continue to provide fuel to keep the engine running, not cut the fuel as you say.
I'm not saying the dealer was right to do what they did, but i can see some logic to it.
I may be totally wrong and I would be inclined to agree with your analysis, but I think the situation is more complex than we imagine. The ECU uses an analog to digital converter to convert the various sensor inputs to a digital value. In the case of switch inputs, the converted input is compared against a threshold value to determine the state of the switch. This means that most switches need to have a resistance in series with the switch. We don't know how the dealer rigged the switch bypass or what the threshold value is or what the ECU software does when the sensor value is on the the unexpected side of the threshold. The behavior described seemed to agree with the analysis that the problem was caused by the clutch switch bypass.
Seth observed performance degradation when he had to bypass his clutch switch in a rally. His bike was likely trying to run off the idle map.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 07-30-2012, 05:56 AM   #4781
Seth S
Seth S's Avatar
Oddometer: 4,608
We simply cut the wires and spliced them together because I had bought a cheaper aftermarket spare clutch lever...my stock one has the end broken off and I couldn't pass tech. So we rigged the clutch switch. When I ran the 26km prologue on the first day of the event the bike ran poorly, stalled a lot more than normal, and acclerated like crap. I was in contact with various forum members like Beany and Mudguts and we surmised that the clutch switch was to blame. i reinstalled my stock clutch lever and we reconnected the switch and the bike was back to normal. I do not know how the switch reacts when the Vortex computer is used.
When I compared the stock lever to the aftermarket lever we noticed that the "bump" on the top of the lever which hits the clutch switch was not on the aftermarket one...or was significantly smaller.
Seth S
Old 07-30-2012, 05:58 AM   #4782
Seth S
Seth S's Avatar
Oddometer: 4,608
are you running the CA pump now Bob? Not sure about the rectifier...but there have been problems with the master/starter relay which can cause the problems you describe. There have also been some issues with the ignition switch that can cause a similar issue.
Seth S
Old 07-30-2012, 06:07 AM   #4783
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,695
Originally Posted by nippybit View Post
bingo
thats why I think Ill build a xr 600 with good legs. I typically ride where its a two day walk to the truck and you dont see too many other humans[/QUOTE from Bobzilla]
Ricky, good points about the bike's problems. I am lucky so far as the bike has not left me 1,000 km's from Timbuktu. I did or had done every known fix up front so that I can hopefully have a dependable 690 but I do not ride outback and as hard as you, Bob, and others do. Albie would say my bike is lightly used. Probably right. Bob you are right about the known dependability of most Jap bikes. If Honda, Suzuki, or Kawasaki would make a thoroughly new and lightweight big bore-dual sport I would sell my 690 and maybe even buy the first year of their new model(s).
I have come to this conclusion after an overwhelming amount of evidence presented here on the 690's problems. I never said I was smart! It is now very hard for me to defend the bike's reliability even though mine is still running just fine. Somewhere Albie is screaming, "I told you so"!
Now drinking fruit punch koolaid (read Orange, mixed with Green, mixed with Red, mixed with Yellow).
LOL, Just got back from an 8 day ride through CO,UT, and WY. The 690 stayed at home, the DR did the ride without a single problem other then crash damage. Ricky is right, the 690 is a great bike so long as you have other bikes to ride.
Old 07-30-2012, 06:30 AM   #4784
goosecreek
a desk prop
Oddometer: 2,483
Well living on the east coast I love my bike 08 690e it has only died once ,fuel pump and that was in the driveway. I am never more than 30 miles from something and most always have cell coverage so I am comfortable in my travels.
I replaced the fuel pump with the ca cycleworks pump and as suggested put the napa filter in place of the quick disconnect and all is fine now.
I am not sure what I would do without this thread thanks guys! Maybe one day I can add something new and helpful.
goosecreek is offline   Reply With Quote
Old 07-30-2012, 07:32 AM   #4785
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
Yes I have the CA pump
Very intermitent problem but it is often enough that it is hard to ride the bike. Rode 200 miles home yesterday with it dieing about 12 times. Most times I could hit the kill switch and cycle it off and on and the bike would start running again. A few times it would take a few minutes and cycles to start again.I was never cycling the key switch only the kill switch.
Love/Hate/Love/Hate
Ride the DEZ
76 CB750
Times are GMT -7.   It's 12:02 AM.
