Old 08-09-2012, 08:25 AM   #4951
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,734
Originally Posted by Biped View Post
'08 Model, has been running great for 11k miles. While rding along the FI light comes on solid and the engine tone gets louder, lots of popping on decel. Cycle key/kill on/off and back to running great again. Happens itermittantly. No other FI warning lights. Will connect to TuneECU tonight to check for codes. Any suggestions....
I'm thinking could be SAS signal related, did the SAS'ectomy 3 years ago, resistor may have corrosion causing ECU to blunder.
You have to put it into neutral for the FI light to flash your code for you, then compare with the manual for code. Remember to count both long, and short flashes, ie; 4 long, 3 short = (x) code.
BK.RD.RNR is offline   Reply With Quote
Old 08-09-2012, 08:53 AM   #4952
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,210
Blink Code
Mine is flashing one long & three short.
Intake air temperature sensor - input signal too low
Intake air temperature sensor - input signal too high
Maxacceleration is offline   Reply With Quote
Old 08-09-2012, 09:29 AM   #4953
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,651
Wiring to the sensor is either broken or the sensors gone bad due to the wiring pulling on the sensor. This happens a lot on 690's.
Old 08-09-2012, 09:49 AM   #4954
Biped
NooB Again
Biped's Avatar
Oddometer: 338
I did that, and no codes. I have picked up codes on TuneECU before that were not displayed on the bike. Will report back tonight..
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 08-09-2012, 10:51 AM   #4955
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,573
Originally Posted by SKINNY View Post
I have a 2012 with an FMF and it doesn't stall....
it backfires like a pack mule farting sometimes...
but it did that with the stock muffler...
It seems that the 690 has been wildly inconsistent since the first model...
every new year model has had some reports of stalling
The 2012's have warm start issues...
my 2008 has never had even a minor hiccup in 11,000 miles
Tell you dealer to call KTM...when I complained about the backfires on my 2012, they told my dealer to install the Akro map...
You can thank California for this. I suspect it takes a lot of funky stuff to make some of these bikes compliant with emmissions. So they run like crap with no power and lots of issues but they pass the emmissions test. Bravo
Seth S
Seth S is offline   Reply With Quote
Old 08-09-2012, 12:23 PM   #4956
SKINNY
SKINNY's Avatar
Oddometer: 645
I think we were all happier with the 49 state models...when the factories started building 50 state legal stuff, we all got cursed with the California drizzling shits...
SKINNY is online now   Reply With Quote
Old 08-09-2012, 02:15 PM   #4957
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,734
I did that, and no codes. ..
Before cycling the key? If so, that's kind of strange indeed.
Old 08-09-2012, 03:38 PM   #4958
rdkyote
rdkyote's Avatar
Oddometer: 70
2012 here too-- stock exhaust, map 1 or 2 and never stalls. sometimes a lean misfire but not blowing the throttle body off... do have a warm (hot) start issue. If you shut her down completely with the key and letting everything reset she fires right up. i've had warm start issues trying to restart after a stall in the rocks and not turning the key off. just my 2c. probably doesn't help anyone.
2012 KTM 690 Enduro R
2007 KTM 250 XC
rdkyote is offline   Reply With Quote
Old 08-09-2012, 03:50 PM   #4959
ramjet
ramjet's Avatar
Oddometer: 2,266
It seems the 2012 are finicky also. Mine has Akra header and exhaust + Akra map. It has never stalled. However, on occasion, it has on start up run for about 10 seconds then quit. Upon restart, it runs fine. Maybe a cold start thing or something. No backfires. When I took the silencer out of the Akra it would crank, fire, but would not run at all. Put it back in, runs fine. Just thought I'd throw in my statistics here. Interesting situations with this machine.
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 08-09-2012, 03:53 PM   #4960
rdkyote
rdkyote's Avatar
Oddometer: 70
all this has to be because it's ready to race.
2007 KTM 250 XC
Old 08-09-2012, 05:20 PM   #4961
motoged
motoged's Avatar
Oddometer: 908
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 08-09-2012, 05:29 PM   #4962
Maxacceleration
Awol
Oddometer: 2,210
Thanks Albie. My sensor has come off the bottom of my airbox once already.
I don't know if the dealer maybe left it off. One of the two screws were stripped out. Silly that it just screws into plastic.
Cheap spindly wiring on this bike too, IMO.
I should have time to go through my bike, waiting for a radiator.
A custom radiator may be in order.
Old 08-09-2012, 08:56 PM   #4963
ramjet
ramjet's Avatar
Oddometer: 2,266
all this has to be because it's ready to be replaced
It may come to this.
Old 08-09-2012, 09:08 PM   #4964
kingoftwins
kingoftwins's Avatar
Oddometer: 98
Battery Voltage Display
Great mod. Love how small it is and how it can be positioned in your peripheral. Not too big which is not as professional as this one.
Originally Posted by numbutt View Post
Not for everybody but on all bikes and on my beach fourby i have installed a small cheap battery voltage display. It sort of gives you an early warning of impending doom...that is an alternator that is not charging or even over charging. Simple to construct and about $9 on internet from FUTURLEC ( ship from Thailand ) ... supposed to be constructed flat but on some i put the LED's side on and encase in epoxy making it waterproof slim and durable...sorry about the focus... one pic of KTM couple of BMW 1150GS adv..also beach fourby ......on the KTM if the charging stops and you pull the blue fuse you are likely to get an hour of riding...[IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
kingoftwins is offline   Reply With Quote
Old 08-10-2012, 01:50 PM   #4965
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,048
LED indicator
I've been using this one for a few years with good success:
http://signaldynamics.com/index.php?...hk=1&Itemid=77
Its nice because it is light, sleek, and can be mounted just about anywhere with just a small single hole.
Roostre is offline   Reply With Quote
Times are GMT -7.   It's 11:01 AM.
