Old 08-11-2012, 02:35 PM   #4981
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
Originally Posted by Uller View Post
That looks tits! I've got to go check the mail box......
Your swing arm is dirty.
Heh,the swingarm is clean compared to some of the other parts.
Old 08-11-2012, 03:17 PM   #4982
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,210
Originally Posted by Albie View Post
Got my BPD chain guide guard installed. Took about 10 minutes, I didn't even bother to take off the rear wheel like they recommend in the instructions.
...that sprocket looks worn.
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 08-11-2012, 05:54 PM   #4983
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
Uhhh right, it's got maybe 1K miles on it.
Old 08-11-2012, 07:58 PM   #4984
Night Falcon
Adventure NZL
Oddometer: 2,210
1k on ktm same as 10k due to the extra ponies....and ktm owners heavy right hand
My EXC530 Adventure
My KTM690 Adventure
Old 08-11-2012, 08:50 PM   #4985
ramjet
ramjet's Avatar
Oddometer: 2,268
2012 690 accessory plug??
I see the acc1, acc2 behind the headlight but could someone tell me where to get the corresponding male spade connector and silicone(or vinyl) boot on which to attach my gps cable to put into these outlets?
"Moral courage is the most valuable and usually the most absent characteristic in men." Gen. George S. Patton
ramjet is offline   Reply With Quote
Old 08-12-2012, 03:33 AM   #4986
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
any store that just about sells anything that has to do with electrics.
From mind you just need the 5,3mm flat male plug. boot not needed as its on the loom side, just slide it over.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 08-12-2012, 06:00 AM   #4987
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Mine came yesterday
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 08-12-2012, 10:17 AM   #4988
daveknievel
daveknievel's Avatar
Oddometer: 738
Out on the road, using tapatalk and it wont search the thread, but does anyone know what resistor works to bypass the clutch switch on the 690? Its bad and wont let the bike run disconnected or the wires twisted together.
daveknievel is offline   Reply With Quote
Old 08-12-2012, 12:52 PM   #4989
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
Resistor is not a fix. From memory, it is a make or break switch and tied into ECU logic. i.e. has an effect based on gear, revs, etc. Seth had issues where the bike ran like shite when simply connected. Think you really need to fix it instead. Did you change to a different lever?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 08-12-2012, 01:33 PM   #4990
scholz
bush league
scholz's Avatar
Oddometer: 55
squadron LED light
Anybody use the squadron LED light from baja designs?
scholz is offline   Reply With Quote
Old 08-12-2012, 02:20 PM   #4991
daveknievel
Oddometer: 738
No new lever. Small crash, wires pulled out. Trying to get home. Thanks anyway.
Old 08-13-2012, 12:56 PM   #4992
motoged
motoged's Avatar
Oddometer: 908
Tires ???
Riders,
I have gone through:
1) two sets of Pirelli MT 21's (won't buy again)
2) One front MotoZ HT Desert Tractionator (good on hard surface more than loose stuff)
3) Three Motoz Desert HT Tractionator rears (LOVE them on all surfaces...will continue to buy them....long life)
4) Two Pirelli Scorpion XCMH fronts (like them in loose stuff...good on pavement. too)
What is a good front tire (DOT) for mostly gravel and paved riding (No Dunlop 606's) ???
Yes to Heidenaus as a given....but saving those for Mexico
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 08-13-2012, 01:13 PM   #4993
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,622
TKC 80s if they have them in 21" (?)
Originally Posted by motoged View Post
Riders,
CanadianX is offline   Reply With Quote
Old 08-13-2012, 01:22 PM   #4994
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,652
Riders,
I spit on DOT front tires. Luckily I can get away without using the things here,
Old 08-13-2012, 01:55 PM   #4995
Canyon Rider
Oddometer: 143
My first mod needs to be a bash plate. Are they all the same, or are some better than others?
Thanks.
10 GSA 30th, 14 HP4 Comp, 13 690 Enduro R
Canyon Rider is offline   Reply With Quote
Times are GMT -7.   It's 01:51 AM.
