Old 08-22-2012, 08:36 PM   #5161
dunefreak
dunefreak's Avatar
Oddometer: 93
Originally Posted by smoothmove View Post
While we're on the canister topic again, is anyone experiencing carbon/charcoal spewing from the canister? This crap ends up on my pant leg and the right side of the bike/frame. Is this normal?
BTW, Dunefreak, how pissed are you that Champion closed their doors? Seemed like you picked up your bike right before they shutdown.
Sounds like you could have fuel in your canister. Do you keep it about an inch below the neck when you fill it?
Yeah that kinda bummed me out about Champion, but it wasn't their fault. Greg, the owner, did everything he could to try and save it. I'm just glad I got the bike before they closed, otherwise I would have had to drive to UT or CA. I got a good deal so I'm happy. Carter picked up the KTM franchise so I have local support again.
Sent from my DROID RAZR MAXX using Tapatalk 2
2012 KTM 690 Enduro R
dunefreak is offline   Reply With Quote
Old 08-22-2012, 08:38 PM   #5162
Velociraptor
TrackBum
Oddometer: 1,139
Originally Posted by crankshaft View Post
Anyone here that has a Vortex ECu ever noticed how touchy the throttle is without the stepper motor connected? I'm hoping to add some extra resistance to the throttle tension, anyone have any BTDT? It's really touchy when I'm riding over rough terrain, likes to buck and surge and I get arm pump trying to hold the throttle super steady.
Do you already have a smaller throttle cam? No big problems for me with Vortex in rough terrain and I do have a smaller cam.
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-22-2012, 09:39 PM   #5163
smoothmove
Oddometer: 18
Wow, I bet that's it. And no, I don't keep it an inch below the neck. I fill that b-i-t-c-h up. Not anymore. Now what?... (1)canister just needs to dry out or (2) do I drain it or (3) use this as an opportunity to yank that sucker off the bike. Thanks for the feedback.
2006 Honda CRF250X
smoothmove is offline   Reply With Quote
Old 08-22-2012, 10:06 PM   #5164
dunefreak
dunefreak's Avatar
Oddometer: 93
You can try to let it dry out, but I'd just yank it off at this point. They take a while to dry out. Sometimes they deteriorate once they become saturated. All the tank pressure that builds will keep pushing out whatever fuel that's in there. If you look at the vent whole just below the fill neck, you want to keep your fuel below that point even without the canister otherwise it will just puke out and your wasting fuel. You need to allow some space for expansion of the fuel when it warms up.
Old 08-23-2012, 02:13 AM   #5165
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Does anyone know of a paint to use to touch up the grey on the engine cases. Thanks.
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 08-23-2012, 04:06 AM   #5166
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
I have the 400 cam installed already, but the throttle pull is really light still.
I might try to find another spring to fit on the bell crank on the t-body.
Thanks Dirt Jack, if all else fails I'll look into the friction lock.
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-23-2012, 04:30 AM   #5167
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Mine is also very touchy with the throttle. Let me know what you come up with.
Old 08-23-2012, 04:41 AM   #5168
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,137
Do you have the latest maps ? I know there has been some updates
Mudguts is offline   Reply With Quote
Old 08-23-2012, 04:47 AM   #5169
striped tomato
striped tomato's Avatar
Oddometer: 139
Ditto. Fine on the black top but real twitchy offroad.
Sent from my iPad using Tapatalk
'13 KTM 1190R
'15 Husqvarna TE300
striped tomato is offline   Reply With Quote
Old 08-23-2012, 07:19 AM   #5170
Night Crawler
Night Crawler's Avatar
Oddometer: 105
There has not been any recent updates on the Vortex unit. Are you guys still happy with your purchase? Is it worth the money? Where are you getting the most gains? I have been looking at getting one, though my bike runs great I would like to smooth out the bottom end. Where does the handlebar selector plug into?
Night Crawler is offline   Reply With Quote
Old 08-23-2012, 07:34 AM   #5171
dunefreak
dunefreak's Avatar
Oddometer: 93
Just throw a set of these on there. http://www.adventure-spec.com/defaul...m-690-e-r.html
Old 08-23-2012, 07:49 AM   #5172
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
I pulled the housing off and had a look inside the bell crank area of the t-body.
Looks like I can drill a small hole here and there and add a small spring.
I think the ride by wire stepper motor added resistance with the old ECU system.
An ECU flash won't help this problem as far as I can tell.
Just say'IN
Old 08-23-2012, 08:24 AM   #5173
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Have you changed maps? There's one on the Vortex with a "softer" initial throttle that works well.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-23-2012, 10:34 AM   #5174
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Map changes don't really make a difference, it's a lot like a touchy has pedal
Just say'IN
Old 08-23-2012, 11:40 AM   #5175
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Maybe it's the newer updated ecu but the softer initial throttle map definitely made a difference. Doesn't cure everything but the power was more manageable on trails.
Times are GMT -7.   It's 01:51 AM.
