Old 08-23-2012, 04:30 AM   #5191
Xmoto
Keep On Keeping On!
Xmoto's Avatar
Oddometer: 1,856
Originally Posted by crankshaft View Post
Anyone here that has a Vortex ECu ever noticed how touchy the throttle is without the stepper motor connected? I'm hoping to add some extra resistance to the throttle tension, anyone have any BTDT? It's really touchy when I'm riding over rough terrain, likes to buck and surge and I get arm pump trying to hold the throttle super steady.
Mine is also very touchy with the throttle. Let me know what you come up with.
“Do not be afraid; only believe.”
Xmoto is online now   Reply With Quote
Old 08-23-2012, 04:41 AM   #5192
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,662
Do you have the latest maps ? I know there has been some updates
Mudguts is offline   Reply With Quote
Old 08-23-2012, 04:47 AM   #5193
striped tomato
striped tomato's Avatar
Oddometer: 42
Ditto. Fine on the black top but real twitchy offroad.
Sent from my iPad using Tapatalk
'11 KTM 990 Adventure Dakar 30th Edition
'13 Husaberg FE 350
striped tomato is offline   Reply With Quote
Old 08-23-2012, 07:19 AM   #5194
Night Crawler
Night Crawler's Avatar
Oddometer: 52
There has not been any recent updates on the Vortex unit. Are you guys still happy with your purchase? Is it worth the money? Where are you getting the most gains? I have been looking at getting one, though my bike runs great I would like to smooth out the bottom end. Where does the handlebar selector plug into?
Night Crawler is offline   Reply With Quote
Old 08-23-2012, 07:34 AM   #5195
dunefreak
dunefreak's Avatar
Oddometer: 85
Does anyone know of a paint to use to touch up the grey on the engine cases. Thanks.
Just throw a set of these on there. http://www.adventure-spec.com/defaul...m-690-e-r.html
2012 KTM 690 Enduro R
dunefreak is online now   Reply With Quote
Old 08-23-2012, 07:49 AM   #5196
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
I pulled the housing off and had a look inside the bell crank area of the t-body.
Looks like I can drill a small hole here and there and add a small spring.
I think the ride by wire stepper motor added resistance with the old ECU system.
An ECU flash won't help this problem as far as I can tell.
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-23-2012, 08:24 AM   #5197
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
Have you changed maps? There's one on the Vortex with a "softer" initial throttle that works well.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 08-23-2012, 10:34 AM   #5198
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
Map changes don't really make a difference, it's a lot like a touchy has pedal
Just say'IN
Old 08-23-2012, 11:40 AM   #5199
Barman
Way Offline
Barman's Avatar
Oddometer: 1,162
Maybe it's the newer updated ecu but the softer initial throttle map definitely made a difference. Doesn't cure everything but the power was more manageable on trails.
Old 08-23-2012, 12:07 PM   #5200
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 172
Now had two occasions of the FI light showing up, not blinking any pattern, but glowing solid. Only when bike is in gear. If I put it in neutral it goes away. Turned off and restarted and both times it didn't come back. Anyone know what impending doom I might be facing?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 08-23-2012, 12:12 PM   #5201
dunefreak
dunefreak's Avatar
Oddometer: 85
You need to turn the key on/ engine off for it to blink for codes. Then go from there.
Old 08-23-2012, 12:26 PM   #5202
blakrj
Need to ride
Oddometer: 172
Therein lies a problem. Solid when engine running, nothing when ignition on and engine off
Old 08-23-2012, 12:40 PM   #5203
Uller
Uller's Avatar
Oddometer: 558
Just a little follow up....
I thought I would report back on my airbox mod after a thourough testing. I've put about 3,000 miles on the 690 since I made this change and all is well. No movement of the airbox is noticable (no rub marks).
I'm calling it a big success and recommend that KTM take notice and add it to the 2013.
http://advrider.com/forums/showpost....postcount=4348
Uller is offline   Reply With Quote
Old 08-23-2012, 01:41 PM   #5204
crankshaft OP
crankshaft's Avatar
Oddometer: 13,783
No offense but go ride 100 miles of single track and tell me if the map change works. Yes, it helped a little but the problem is the spring tension on the t-body
Just say'IN
Old 08-23-2012, 01:46 PM   #5205
Xmoto
Keep On Keeping On!
Xmoto's Avatar
Oddometer: 1,856
I have set the map select switch to soft but have not messed with the Vortex settings. The bike just gets a little jumpy in rough sections.
Times are GMT -7.   It's 03:36 PM.
