Old 08-28-2012, 02:34 PM   #5281
Bruno T .
N8YQ
Bruno T .'s Avatar
Oddometer: 1,932
You have good taste, Seth.
Bruno T . is offline   Reply With Quote
Old 08-28-2012, 02:52 PM   #5282
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Beer budget though
Just say'IN
crankshaft is offline   Reply With Quote
Old 08-28-2012, 10:09 PM   #5283
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,107
Pre load adjuster
OK all I have worked out a way of using an Xtrig preload adjuster just need some one to machine up a new lock ring with modifications.
The xtrig adjuster for the 950SE will fit as the shock body is 52mm x 1.5 thread pitch. the lock ring will need a block with two rods attached to be used as guides for the adjuster to move up and down .
I will try to mock some thing up as a reference so y'all can see what I'm doing .
Mudguts is offline   Reply With Quote
Old 08-28-2012, 11:57 PM   #5284
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 187
I'm assuming a modified Xtrig? Thought the standard Xtrig preload adjuster did not need a locking ring?
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 08-29-2012, 12:17 AM   #5285
Mudguts
Mudguts's Avatar
Oddometer: 2,107
No it does not need a lock ring but it does need a guide , On other model bikes the xtrig uses the gas canister as a guide
The 690 has a horizontal canister so it can't be used , that were a new lock ring with a built in guide come in to play,
The next herdle is room it is very very tight in there , I have not check even if the xtrig will fit if it does the will only be 1mm
To spare ,
I have also contacted me Wilber's dealer he has a hydraulic adjusted that may fit ,
And I have also contacted merge racing they had an adjuster I'm tring to find out if they had a 52.mm x1.5 adjuster
I believe there in still stock at bto sports .
Old 08-29-2012, 12:42 AM   #5286
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,584
When my wife & I lived in Mongolia, I tried to convince her that we *really* needed a $2500 GAZ 66 -- although I wouldn't have been shocked if it was stolen. I figured I could send it home in a shipping container. Those things make me weak in the knees.
I drive over your seeessy leeetle Hummer, da?
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 08-29-2012, 02:08 AM   #5287
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,046
Originally Posted by Bill the Bong View Post
I got 16 km/l yesterday over a 350 off-road loop using Vortex's economy map. I was the only bike that had severe range issues.
Was this the new economy map from June 2012?
Brute is offline   Reply With Quote
Old 08-29-2012, 02:11 AM   #5288
Brute
Brute's Avatar
Oddometer: 1,046
Give me a call if you`re looking for someone for the machining .
Sounds like a good upgrade , I`ll be after one if its a reasonable cost .
Old 08-29-2012, 02:40 AM   #5289
Mudguts
Mudguts's Avatar
Oddometer: 2,107
I,m talking to you on phone right now
Old 08-29-2012, 03:01 AM   #5290
Brute
Brute's Avatar
Oddometer: 1,046
What , speak up
Old 08-29-2012, 03:29 AM   #5291
Mudguts
Mudguts's Avatar
Oddometer: 2,107
forgive my bluetac engineering
Old 08-29-2012, 03:51 AM   #5292
Mudguts
Mudguts's Avatar
Oddometer: 2,107
this is exactly what we need I have just email xtrig , asking for them to make these to suit the 690
Mudguts screwed with this post 08-29-2012 at 04:01 AM
Old 08-29-2012, 05:19 AM   #5293
wino975
wino975's Avatar
Oddometer: 49
it's fantastic
is what i'm searching for
wino975 is offline   Reply With Quote
Old 08-29-2012, 05:19 AM   #5294
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
very cool guts, would make adjustments super fast!
Just say'IN
Old 08-29-2012, 05:23 AM   #5295
Mudguts
Mudguts's Avatar
Oddometer: 2,107
Not there's any thing wrong with taking an hour to do one full rotation , and have to replace the lock ring every time you make an adjustment
Times are GMT -7.   It's 10:04 PM.
