Old 08-29-2012, 04:15 PM   #5311
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Originally Posted by Mini Trail View Post
Anyone have an intake rocker 75036060044? Apparently there is a backorder and mine is destroyed.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 08-29-2012, 04:41 PM   #5312
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,046
Thumb
Originally Posted by crankshaft View Post
Going with a Shorai battery for less weight.
I was going to try a Shorai until i ran into this thread:
http://www.advrider.com/forums/showthread.php?t=770364
Good reading. I now have 2 bikes running the Antigravity batteries. Hasn't been long enough to say for sure how well they will last, but they have been flawless in both bikes so far. The cranking power is unbelievable. I had an Odyssey PC545 in my street bike, which was a big improvement over stock, but the AG is half the size and 7 lbs lighter and STILL outcranks the Odyssey.
The AG in the 690 turns the bike over a bit faster than the stock battery, but it also only weighs 2.5 lbs. Its truly hard to believe that it will work when you pull it out of the shipping box and its so light.
My only regret is that I could have used one of their small format cells instead and used the extra room in the battery tray to carry a spare tube or something.
Roostre is offline   Reply With Quote
Old 08-29-2012, 04:52 PM   #5313
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
I just did that exact same thing. Dropped it off in my R&D department and let the EE's play with it some (We do a lot of DC stuff) and they all gave it a
I read that too, but figured screw it. If the EE's didn't like it I'd just expense it and leave it there
My bad
Old 08-29-2012, 04:59 PM   #5314
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,201
690 rider down here had his Shorai fail at 12 months. I'm 'running' a couple of them but they've spent the better part of the last year on a charger while my leg healed.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 08-29-2012, 06:44 PM   #5315
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Originally Posted by Night Crawler View Post
I noticed a small amount of fine dust inside of throttle body when I took my air box off. Is this un-avoidable? Or am I missing something? I have The Uni filter trimmed to fit with a nice bead of grease around the edge. Also the clamp for the boot seems to slide off the back edge every time I tighten it.
The air box is made out of three main parts. Left, right (which is essentially a mirror of the right) and the air filter support. All parts are thermo glue together.
I had an air box changed under warranty because the air filter support was not air tight. And it was very hard to see.
I do not use grease, but zipp-seal the hold the filter in place ...
Same here. I will not install that sh... again. It's cheaper and better to loose weight on a stationary bike.
Well, we plan on making a jig to be able to spit out a wiring harness. I suppose Matt could sell them to anyone that is interested and I could share my maps for a small donation.
I know for sure the wiring harness is different for 2008, 2011, and 2012 models ...
Paul Jr 8
KTM690r 2011
Gros Buck screwed with this post 08-29-2012 at 07:02 PM
Gros Buck is offline   Reply With Quote
Old 08-29-2012, 09:05 PM   #5316
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,046
I didn't have that safety net. The big reason I think the AG batteries may last longer is that they are watertight- the Shorai is not and lithium and water don't get along. Much of what I read on failed Shorais pointed to water ingress issues. They may have fixed this now, but I don't know.
Old 08-30-2012, 05:40 AM   #5317
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
most don't, but I figured if it shits the bed on me I'm only out a couple hundred bucks, and needed to save some weight up top after adding that corbin
We do a lot of testing batteries, and I figure if this one rolls over. I'll just give them the dims and tell them to source me one so I can assist them in "testing"
My bad
Old 08-30-2012, 07:30 AM   #5318
Pundy
Oddometer: 339
Can you tell me which battery # from AG that you got for the 690?
Pundy is offline   Reply With Quote
Old 08-30-2012, 08:06 AM   #5319
Roostre
Discombobulated
Roostre's Avatar
Oddometer: 1,046
Thumb
Old 08-30-2012, 08:29 AM   #5320
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
Mine was warrenteed because of a crack. Let some dust in.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 08-30-2012, 08:39 AM   #5321
Pundy
Oddometer: 339
Merci!
Old 08-30-2012, 09:58 AM   #5322
Velociraptor
TrackBum
Oddometer: 1,107
The clamp for the boot connecting the air box to the throttle body? That should not be sliding off. After a week of desert riding my uni filter was caked with dust on the outside but inside was totally dust free, so sounds like there is a problem somewhere. Just to ask the obvious, the filter has been oil treated right? They come already oiled so I am guessing yes. And those two tabs in the front of the airbox cover are sliding properly into the slots at the front of the air box. Hope you figure it out!
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor is offline   Reply With Quote
Old 08-30-2012, 04:56 PM   #5323
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Not a hint of dust in mine since the change over to the RR. Loud as piss though.
My bad
Old 08-30-2012, 05:03 PM   #5324
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,106
there a problem with the box cracking on the bottom welded jointhat runs down the centre
Mudguts is offline   Reply With Quote
Old 08-30-2012, 05:49 PM   #5325
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,617
I have a new in the bag air box I'll sell if someone needs it. PM me.
Originally Posted by metaljockey View Post
None of us are exceptionally skilled riders (excepting when I'm drunk, then I'm fcking quick).
BK.RD.RNR is offline   Reply With Quote
Times are GMT -7.   It's 04:24 AM.
