09-01-2012, 07:07 AM
#5371 | |
Guns are for pussies
Oddometer: 13,783
Maybe I should start a thread on it
Just say'IN |
09-01-2012, 08:09 AM
#5372 | |
Beef = Packed Vegetables
I should have taken picture last week ... Something that's little known is what is happening when coolant reaches the boiling point. Pockets of vapors accumulates left and right. The temperature of gas is not limited like liquids. Water will remain at 100 celcius, up until it's evaporated. But vapor will increase in temp as long as you heat it. So when your coolant reach the boiling point, the temp in your motor surges because of vapor pockets. That vapor is pretty good at rusting your motor at a very accelerated pace too. Two solutions: You get rid of the heat. Or you get rid of vapor. Propylene glycol is more efficient and transporting heat. Rougly 20% better. Still have the boiling point issue. Which is around 10 degrees higher then Prestone. It helps getting rid of temperature. Evans coolant approach is waterless coolant. It allows you to run your motor at much higher temperature without the adverse effect of water evaporating. Essentialy, you keep the heat, but get rid of vapor. Drawback is its not compatible with water. In case of trouble, you have to flush it and swap with water temporarily. I'll give it at try next year. Paul Jr 8
KTM690r 2011 Gros Buck screwed with this post 09-01-2012 at 05:01 PM |
09-01-2012, 08:17 AM
#5373 |
Oddometer: 13,783
Just say'IN |
09-01-2012, 08:58 AM
#5374 |
Oddometer: 1,949
This is only true at sea level atmospheric pressure.
At higher or lower pressures, the boiling point of liquids changes. In a closed, and then pressurized by steam, system - the boiling point can be much higher, up to the point allowed by a blowoff valve or some other weakness in the system. |
09-01-2012, 03:44 PM
#5375 | |
Kool Aid poisoner
Oddometer: 4,809
I've run my rad at less then half full in 95* heat and never overheated or "come close" either. it never went passed the NORMAL operating temp i.e. 2 bars from the top.
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
09-01-2012, 04:19 PM
#5376 | |
when in doubt GAS IT
Oddometer: 1,658
09-01-2012, 04:23 PM
#5377 | |
Oddometer: 1,658
09-01-2012, 04:35 PM
#5378 | |
Oddometer: 13,783
Just say'IN |
09-01-2012, 07:45 PM
#5379 | |
Adventure NZL
Oddometer: 858
09-01-2012, 08:53 PM
#5380 |
Oddometer: 1,949
Close. More accurately, a radiator is sealed and allows pressure to build up to a certain level. The boiling point of the coolant directly varies with the pressure. Once the pressure is lost, due to a valve opening or something similar, the boiling point drops accordingly.
09-01-2012, 09:23 PM
#5381 | |
By the way, when one reaches 8 bars (somebody here have written 12), it blinks. I say that for those who wonder what's happening the coolant is about to boil ... That said, I just cannot imagine that having a second fan could not be an interesting option at least for some ... I'm not sure I would go into the jungle with a coolant that I could not add water in case of emergency. In those cases, a second fan is a better safety then a better coolant ... Paul Jr 8
KTM690r 2011 |
09-02-2012, 12:34 AM
#5382 |
Oddometer: 192
![]() We have been looking into the possibility of an aftermarket alloy radiator for some time,using our library of 690 CAD drawings. Some of the features that would be incorporated into a new design would be: 1.Replace M6 threaded inserts on top front of rad with welded on tabs,with M6 clips,so if the rad screen screws were overtightened,it would not put stress into rad. 2.Replace plastic rad cap with EXC type cap,so that a 1,8 bar cap could be fitted. 3.Seperate overflow outlet,a la EXC,instead of the plastic elbow on top of OEM cap. 4.Replace welded-on lower tabs for side panels with a seperate mounting tab connected to a wrap round frame,completely disconnected from the cooling cores. As you can see from the diagram,it would be possible to add a mount for an extra fan on the right hand side,but it would need the following mods. 1.Reposition stock coil further back,only up to 2011 models. 2.Alter angle of inlet pipe on new radiator. 3.New,longer rad hose for above. 4.Re-position fan sensor t/stat lower to clear hose. Whilst it would,in theory,add more cooling capacity having 2 fans running,when the fans are not running,they add an obstruction to airflow through the radiator under forward motion.So the effect of adding an extra fan may not be a straightforward plus point. www.rally-raidproducts.co.uk |
09-02-2012, 02:13 AM
#5383 |
Adventure NZL
Oddometer: 858
Still need some help with my starter problem; if anyone can offer some wisdom It would be appriciated. There is power to the starter button and the kill switch works fine...bridged the terminals on the starter solanoid and it started right up so there is either a break somewhere or something is telling the starter not to work....which i still suspect is the sidestand safety switch but as I don't know how to test/check it i have no way of telling. Can any of you fine fellows point me in the right direction on this?
09-02-2012, 02:33 AM
#5384 | |
Oddometer: 192
starter problems
The only definite way to eradicate the problem is to replace the large cluster switch with an EXC waterproof push-button starter switch & a separate on-off rocker for the stop. |
09-02-2012, 03:04 AM
#5385 |
SE Asia adventure tours
Oddometer: 567
John just wanted you to know if you could make a version with just 1 more powerful fan (maybe throw in a high, medium and low) that could be quickly removed, plugged into some extension wires and hung nicely from the ridgeline of a hammock I for one (and who knows how many others there might be) would be interested!!
