Old 09-02-2012, 06:11 AM   #5386
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,355
Originally Posted by Gros Buck View Post
Exactly. But the point I wanted to underline previously is what's the effect when it boils. Or get close to it. The most damageable thing is vapor. Because it corrodes the motor rapidly, and it has a much higher temp then surrounding liquid. So if your coolant do not turn into vapor, you can run your motor at higher temperatures. That's the main selling point of waterless coolants.
By the way, when one reaches 8 bars (somebody here have written 12), it blinks. I say that for those who wonder what's happening the coolant is about to boil ...
That said, I just cannot imagine that having a second fan could not be an interesting option at least for some ... I'm not sure I would go into the jungle with a coolant that I could not add water in case of emergency. In those cases, a second fan is a better safety then a better coolant ...
Paul Jr 8
I don't even use coolant in my 690. Just water and water wetter. Works just fine in the hot as hell these days south.
Old 09-02-2012, 07:20 AM   #5387
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,003
Originally Posted by Night Falcon View Post
Still need some help with my starter problem; if anyone can offer some wisdom It would be appriciated. There is power to the starter button and the kill switch works fine...bridged the terminals on the starter solanoid and it started right up so there is either a break somewhere or something is telling the starter not to work....which i still suspect is the sidestand safety switch but as I don't know how to test/check it i have no way of telling. Can any of you fine fellows point me in the right direction on this?
I've been running the EXC starter button for a few years and I replaced my funny acting ignition switch with a push button on/off.
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-02-2012, 08:37 AM   #5388
ramjet
ramjet's Avatar
Oddometer: 2,132
Originally Posted by ktmmitch View Post
We have been looking into the possibility of an aftermarket alloy radiator for some time,using our library of 690 CAD drawings...
I'd buy it.
Whilst it would,in theory,add more cooling capacity having 2 fans running,when the fans are not running,they add an obstruction to airflow through the radiator under forward motion.So the effect of adding an extra fan may not be a straightforward plus point.
www.rally-raidproducts.co.uk
Well thought out. Likely 2nd fan unnecessary.
How is the new fuel tank production coming along?
Coffee first. Then your mundane socialist bullshit.. Lenny Bruce
ramjet is offline   Reply With Quote
Old 09-02-2012, 11:20 AM   #5389
ktmmitch
Oddometer: 578
EVO 2 Tank Kit
We hope to sample the mould end of next week
Also,we are finalising design on new twin headlight screen & fairing to suit new tanks
ktmmitch is offline   Reply With Quote
Old 09-02-2012, 11:21 AM   #5390
Maxacceleration
Awol
Maxacceleration's Avatar
Oddometer: 2,190
A three speed fan is an interesting idea. Manual or thermostat controlled.
Maxacceleration is offline   Reply With Quote
Old 09-02-2012, 02:09 PM   #5391
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
(1) We have been looking into the possibility of an aftermarket alloy radiator for some time,using our library of 690 CAD drawings.
Some of the features that would be incorporated into a new design would be:
1.Replace M6 threaded inserts on top front of rad with welded on tabs,with M6 clips,so if the rad screen screws were overtightened,it would not put stress into rad.
(2) 2.Replace plastic rad cap with EXC type cap,so that a 1,8 bar cap could be fitted.
3.Seperate overflow outlet,a la EXC,instead of the plastic elbow on top of OEM cap.
(3) 4.Replace welded-on lower tabs for side panels with a seperate mounting tab connected to a wrap round frame,completely disconnected from the cooling cores.
As you can see from the diagram,it would be possible to add a mount for an extra fan on the right hand side,but it would need the following mods.
1.Reposition stock coil further back,only up to 2011 models.
2.Alter angle of inlet pipe on new radiator.
3.New,longer rad hose for above.
(4) 4.Re-position fan sensor t/stat lower to clear hose.
Hello Mitch
(1) When you say alloy, you mean Aluminium alloy ???
(2) Replacing the cap to 1.8 bar is the logical next, step however, the pump below is an impeller pump if I remember well. That means constant pressure and not constant flow. Increasing the coolant circuit pressure will innevitably reduce the flow. The capacity to transport heat is mostly influenced by flow, and almost not by pressure. You have the OEM pump curve, or you have made basic tests to verify this ? There's also the issue the pump's seal being notoriously weak and prone to failure. There's always to posibilty to swap the OEM seal to something much stronger. Finaly there's also the head gasket that seams to be more and more of an issue. Again, maybe it's possible to find something stronger there.
(3) KTM crash guard is not rugged enough. While you are designing some form of braket to hold your RRaid tanks and plastic covers, it would be nice all those things be integrated with a bottom crash guard. I imagine it's what you mean with "wrap around frame" ?
(4) Don't need to reposition the temp sensor. Just weld an 80 degres elbow instead of a 90 degrees elbow. It would be more natural too. The coolant hose is an obstruction behind the rad anyway. Re routing it around the rad would increase the flow.
I see four of your bolt-on clamps. Why ? By the way, I had two 8 mm rods fatigue-failed that broke completely. I made a 20 mm thick spacers instead of the nuts supplied in your kit. I.e. It's like if you had machined your clamps 20 mm longer.
I suspect these http://www.spalusa.com to be one of KTM suppliers for fans. More precisely here: http://www.spalusa.com/store/main.as...oryBody&c=FAMO and here: http://www.spalusa.com/store/main.as...oryBody&c=FAAC
Paul jr 8
KTM690r 2011
Gros Buck screwed with this post 09-03-2012 at 06:40 AM
Gros Buck is offline   Reply With Quote
Old 09-02-2012, 02:27 PM   #5392
kojen
Oddometer: 5
Modified to fit 2012 model
Just wanted to post a picture of my bike. Made some adjustments to the RR-UK fairing to fit my 2012 model.
Changed the angle of the fairing a bit forward and made some adjustments to fit the 2012 sidepanels...
Made some extra space for RB, GPS276c and IMO. Pretty happy with the result...
kojen is offline   Reply With Quote
Old 09-02-2012, 07:15 PM   #5393
DirtWarrior
Oddometer: 77
Very nice. Can you post more pics?
Nick
2014 KTM 500 EXC
2009 KTM 690 Adventure
2008 KTM 250 XCF-W ---Sold
DirtWarrior is offline   Reply With Quote
Old 09-02-2012, 07:46 PM   #5394
crankshaft OP
crankshaft's Avatar
Oddometer: 14,003
will the old tanks be available for a bit longer for spares and/ or replacement parts?
Just say'IN
Old 09-02-2012, 11:05 PM   #5395
kojen
Oddometer: 5
One more...
kojen screwed with this post 09-02-2012 at 11:11 PM
Old 09-02-2012, 11:06 PM   #5396
kojen
Oddometer: 5
[QUOTE=kojen;19506736]
One more...
Old 09-03-2012, 12:05 AM   #5397
ktmmitch
Oddometer: 578
Yes,we will run them also for those that still want them
Old 09-03-2012, 04:11 AM   #5398
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,747
Hey fellas
The spring went in my gear lever today so looking at the hammerhead anyone know where to buy from .
thanks and the oem number if possible
p.s getting the stalling issues know as well
Beer'o'clock Baz is online now   Reply With Quote
Old 09-03-2012, 04:24 AM   #5399
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,105
Should be able to order a HH lever at any bike shop , but they are not an exact fit for the 690 I took mine off after one day,
I ordered the 10+ which was to long for my size 13 and it ended up that I changed gear right on the cutical of my big toe
The pain was unbearable . I spose if I change it to the std length it should be fine .
Soooo be careful which one you order try to stick to the stock length
Mudguts is offline   Reply With Quote
Old 09-03-2012, 04:59 AM   #5400
Beer'o'clock Baz
Oddometer: 1,747
Thanks mate -will have a look at the original lever tomorow and see if i can doctor something up
Times are GMT -7.   It's 12:45 AM.
