Old 09-07-2012, 01:28 AM   #5431
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,758
Originally Posted by Mudguts View Post
this tell me that is a preload issue , have you played with the fork preloads ?
Answer these for me please
.? Is it still tucking under or pushing out wide ?
How much do you weigh with gear ,
What springs do you have
what psi
Mate i play with all the clickers non stop trying to sort out a solution but come back to the comfort setting everytime.
Now that i have dropped the forks and adjusted the offset she's riding nice no tucking under now.
Im 83kg dry plus riding gear
springs and shock all stock
18 front D952 - 22 rear D606 { this is for general adventure riding i do drop more for knarlier } with uhd tubes rimlocks and ballanced
Beer'o'clock Baz is offline   Reply With Quote
Old 09-07-2012, 02:56 AM   #5432
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,113
are they still using the .52 fork springs in the 11/12 bike there too hard for you drop down to.48 or .49 you can do this two ways buy a pair of springs or get your hand on one .46 or 48 .46 + .52 =.49 Or .48+.52 = .50
So if you have a friend with same bike you can go half each
Mudguts is offline   Reply With Quote
Old 09-07-2012, 03:17 AM   #5433
DirtJack
DirtJack's Avatar
Oddometer: 1,580
Originally Posted by toniton View Post
I found the manuals for actual models, but I can't find for older models. Where can I donwload this manuals?
A Google search produced the link:
http://www.ktm.com/dealer-service/se...documents.html
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is online now   Reply With Quote
Old 09-07-2012, 03:40 AM   #5434
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
What MudGuts said. I'm about the same weight and have changed my rear spring to a 94Nm spring (stiffer than stock) and it has certainly improved things. Also, if you want to drop some cash, a set of SXS closed chamber forks will improve things. The stock fork springs are too hard and I'd go for a pair of the .48 (4.8Nm)
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 09-07-2012, 03:40 AM   #5435
Beer'o'clock Baz
Oddometer: 1,758
Thanks mate will reaearch and see what i come up with - gives me something to work on
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Old 09-07-2012, 04:00 AM   #5436
Tootega
Tootega's Avatar
Oddometer: 8
Dunlop 908rr front
Originally Posted by Velociraptor View Post
Similar experience for me although I usually run 22 psi. Never ever felt like the bike was gonna spit me off at speed.
I changed the standard 2012 Continental Twinduro TKC 80 front for a Dunlop 908rr result lots of headshake. I have a Kuba link and the forks dropped with TK80 flat out no shake.
The Dunlop shakes at 63mph So i raised the forks and ran 26psi + 2 clicks of compression it now shakes at 75mph.
Would anyone recomend a tyre that will work on pavment but is better that the Dunlop 908. I just wanted more grip on the dirt.
Tootega is offline   Reply With Quote
Old 09-07-2012, 05:18 AM   #5437
690Emaf10
Oddometer: 67
Tank bolts spinning
I'm trying to remove my rear fender and can't get the one bolt out because the nut is just spinning in the plastic. What have others done when this is happening?
690Emaf10 is offline   Reply With Quote
Old 09-07-2012, 06:26 AM   #5438
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,674
Not that it will help you now, but pre-emptively, I put a bunch of anti-sieze in the threads on the nuts.
BK.RD.RNR is offline   Reply With Quote
Old 09-07-2012, 06:33 AM   #5439
690Emaf10
Oddometer: 67
I plan to do that when I put everything back together.....
Old 09-07-2012, 06:33 AM   #5440
OhBoy
Got Out
OhBoy's Avatar
Oddometer: 1,153
If you are talking about the bolt I think your talking about. Put a wrench on the bolt on the other side and keep it from spinning. The nut on the inside is threaded all the way through to hold the bolts on both sides.
I was trying to get that bolt out to lift the tank to adjust the spring and ran into the same problem. Did the spring another way. So never ended up taking it out. But the local KTM dealer had to figure it out as they did not know the solution at first either.
Link to CycleHutFicheFinder http://cyclehuttktm.com/FicheFinderNew/FicheFinder.aspx
Start off slow then easy off
OhBoy screwed with this post 09-07-2012 at 06:38 AM Reason: Fiching
OhBoy is offline   Reply With Quote
Old 09-07-2012, 06:41 AM   #5441
Mudguts
Mudguts's Avatar
Oddometer: 2,113
That what I'm using 9.4 shock spring SX, TC forks 50. Fork springs ( got all that rally crap hanging off the front )
Ran at 163.8kph for a couple minutes no head shake but vibe or two with unblanced wheels
Old 09-07-2012, 06:41 AM   #5442
690Emaf10
Oddometer: 67
I don't think there is a nut visible on the other side. This is on the side of the plastic rear fender. There are 4 of them. Two under the seat and two on either side of the fender. From the diagram, it is #11 on the left side.
Old 09-07-2012, 06:49 AM   #5443
Mudguts
Mudguts's Avatar
Oddometer: 2,113
Soak with WD over night when try to loosen put sideways pressure ( if possible ) to try to get the jam nut to grip on the plastic
Old 09-07-2012, 07:06 AM   #5444
690Emaf10
Oddometer: 67
Thanks, I sprayed some WD40 on it before I left for work. I'll see what i can do with it when I get home.
Old 09-07-2012, 07:15 AM   #5445
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Try side pressure with an impact driver. Anti sieze all your bolts for this reason.
Just say'IN
crankshaft is offline   Reply With Quote
Times are GMT -7.   It's 08:40 PM.
