Old 09-07-2012, 06:41 AM   #5446
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,114
Originally Posted by blakrj View Post
What MudGuts said. I'm about the same weight and have changed my rear spring to a 94Nm spring (stiffer than stock) and it has certainly improved things. Also, if you want to drop some cash, a set of SXS closed chamber forks will improve things. The stock fork springs are too hard and I'd go for a pair of the .48 (4.8Nm)
That what I'm using 9.4 shock spring SX, TC forks 50. Fork springs ( got all that rally crap hanging off the front )
Ran at 163.8kph for a couple minutes no head shake but vibe or two with unblanced wheels
Mudguts is offline   Reply With Quote
Old 09-07-2012, 06:41 AM   #5447
690Emaf10
Oddometer: 68
Originally Posted by OhBoy View Post
If you are talking about the bolt I think your talking about. Put a wrench on the bolt on the other side and keep it from spinning. The nut on the inside is threaded all the way through to hold the bolts on both sides.
I was trying to get that bolt out to lift the tank to adjust the spring and ran into the same problem. Did the spring another way. So never ended up taking it out. But the local KTM dealer had to figure it out as they did not know the solution at first either.
I don't think there is a nut visible on the other side. This is on the side of the plastic rear fender. There are 4 of them. Two under the seat and two on either side of the fender. From the diagram, it is #11 on the left side.
690Emaf10 is offline   Reply With Quote
Old 09-07-2012, 06:49 AM   #5448
Mudguts
Mudguts's Avatar
Oddometer: 2,114
Soak with WD over night when try to loosen put sideways pressure ( if possible ) to try to get the jam nut to grip on the plastic
Old 09-07-2012, 07:06 AM   #5449
690Emaf10
Oddometer: 68
Thanks, I sprayed some WD40 on it before I left for work. I'll see what i can do with it when I get home.
Old 09-07-2012, 07:15 AM   #5450
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Try side pressure with an impact driver. Anti sieze all your bolts for this reason.
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-07-2012, 04:33 PM   #5451
Night Crawler
Night Crawler's Avatar
Oddometer: 93
while were on the topic. I am trying to do the throttle stop adjustment for the Vortex install and was wondering how you get the threaded aluminum cover off the top of the adjustment screw.
Night Crawler is offline   Reply With Quote
Old 09-07-2012, 05:00 PM   #5452
690Emaf10
Oddometer: 68
I was able to work around my bolt without taking it out. It was just a bit of a PITA to get the exhaust hanger bolts off. All this to change the fuel pump. It really isn't a bad job except for the gas that runs out when you pull the pump.
Now my problem is the bike won't fire..... Fuel pump primes but it doesn't fire. The other thing I notices was that all of my instrament panel goes off each time the bike cranks. I'll have to pull the pump again and make sure there are no kinks in the lines and everything looks good.
Old 09-07-2012, 05:14 PM   #5453
Mudguts
Mudguts's Avatar
Oddometer: 2,114
I just undo the the exhuast pipe clamp leave the muffler on .
not starting maybe an air pocket ???
Old 09-07-2012, 05:16 PM   #5454
690Emaf10
Oddometer: 68
That is possible but how would I try to diagnose that one? Pull the fuel line up stream from everything and see if it is spitting fuel?
Old 09-07-2012, 05:24 PM   #5455
Mudguts
Mudguts's Avatar
Oddometer: 2,114
krank with throttle wide open and or Pull the fuel line up stream from everything and see if it is spitting fuel?
Old 09-07-2012, 06:30 PM   #5456
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Anybody clean one of these injectors in an ultrasonic?
Spray pattern was sketchy after a CA Cycleworks fuel pump, but I didn't see what it looked like before. 5k miles on the bike. Runs, but cuts out and dies at speed like it's not fueling. Pump runs, lots of fuel upstream all the way to the injector. Replaced QD with the NAPA filter. I'll reinstall it in the AM and see what the pattern looks like. Is it worth carrying a spare on the bike? What's the rate of failure for the injectors?
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 09-07-2012, 06:35 PM   #5457
Ryman
Oddometer: 472
That's how I do mine. I've changed the injector 3 times in 11k miles. They work like new after the ultrasonic bath.
Ryman is offline   Reply With Quote
Old 09-07-2012, 07:01 PM   #5458
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
What is the best interchange to a KTM Injector ??? OEM is awfully expensive here.... $400
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 09-07-2012, 07:13 PM   #5459
Ryman
Oddometer: 472
Paul Jr
Good question.....? So far I just have two OEM units that I switch up and keep clean with the jewelry cleaner.
A better question might be. How is cranks conversion going....????
I like his Ideas. Simple system. Readily available parts. Bomber wiring harness. I'd pay for this setup.
Old 09-08-2012, 12:54 AM   #5460
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,758
Another problem fellas sorry I changed my fuel filter and screen today and i still have the stalling issue it actually blew the boot off for the first time does this leave me with a fuel pump issue under warranty ?
thanks
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz is offline   Reply With Quote
Times are GMT -7.   It's 04:22 PM.
