Old 09-07-2012, 05:24 PM   #5461
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,659
krank with throttle wide open and or Pull the fuel line up stream from everything and see if it is spitting fuel?
Mudguts is offline   Reply With Quote
Old 09-07-2012, 06:30 PM   #5462
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,152
Anybody clean one of these injectors in an ultrasonic?
Spray pattern was sketchy after a CA Cycleworks fuel pump, but I didn't see what it looked like before. 5k miles on the bike. Runs, but cuts out and dies at speed like it's not fueling. Pump runs, lots of fuel upstream all the way to the injector. Replaced QD with the NAPA filter. I'll reinstall it in the AM and see what the pattern looks like. Is it worth carrying a spare on the bike? What's the rate of failure for the injectors?
When there is no way out - Find a way further in.
690 DL650 XL1200C Past bikes
Originally Posted by Mugwest View Post
Stay half-assed, my friends.
Buzztail is offline   Reply With Quote
Old 09-07-2012, 06:35 PM   #5463
Ryman
Oddometer: 591
That's how I do mine. I've changed the injector 3 times in 11k miles. They work like new after the ultrasonic bath.
Utards in Baja
http://www.advrider.com/forums/showthread.php?t=674444
Ryman is offline   Reply With Quote
Old 09-07-2012, 07:01 PM   #5464
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
What is the best interchange to a KTM Injector ??? OEM is awfully expensive here.... $400
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 09-07-2012, 07:13 PM   #5465
Ryman
Oddometer: 591
Paul Jr
Good question.....? So far I just have two OEM units that I switch up and keep clean with the jewelry cleaner.
A better question might be. How is cranks conversion going....????
I like his Ideas. Simple system. Readily available parts. Bomber wiring harness. I'd pay for this setup.
Utards in Baja
Old 09-08-2012, 12:54 AM   #5466
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
Another problem fellas sorry I changed my fuel filter and screen today and i still have the stalling issue it actually blew the boot off for the first time does this leave me with a fuel pump issue under warranty ?
thanks
B2 is offline   Reply With Quote
Old 09-08-2012, 01:15 AM   #5467
.chris
690 Advenduro
.chris's Avatar
Oddometer: 51
Trying to remove my rear shock, not had much luck with the top mount.
Any tips for removing that bolt? only has torx45 inside, not a nice convenient bolt I could get a good trip on.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 09-08-2012, 01:18 AM   #5468
beaney
rally racer
beaney's Avatar
Oddometer: 124
Buy a decent torx socket set
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 09-08-2012, 02:03 AM   #5469
Mudguts
Mudguts's Avatar
Oddometer: 1,659
Bit of heat and WD will help and yeah good tools worth there weight in gold
Old 09-08-2012, 02:23 AM   #5470
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 913
Originally Posted by Night Crawler View Post
while were on the topic. I am trying to do the throttle stop adjustment for the Vortex install and was wondering how you get the threaded aluminum cover off the top of the adjustment screw.
With a good pair of pliers . Mine had a lot of loctite.
Brute is offline   Reply With Quote
Old 09-08-2012, 04:04 AM   #5471
Xmoto
Keep On Keeping On!
Xmoto's Avatar
Oddometer: 1,856
What fluid to you use in the cleaner.
“Do not be afraid; only believe.”
Xmoto is offline   Reply With Quote
Old 09-08-2012, 04:16 AM   #5472
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,152
Just warm water and a bit of mild detergent (pine sol, or Mr. Clean) I clean all kinds of shit in them (brass when reloading, etc.)
Last night I used straight water the first run and it still smelled like fuel inside so I added a cap full of Mr. Clean you could see the crap coming out and off of it.
A little vinegar works well too
Old 09-08-2012, 04:48 AM   #5473
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 808
You want to put an electric pulse to the injector to get it to open and close. Just sitting there in the cleaner will not clean it completely. A 9 volt pulse of some sort would be ideal.
Noah 08 KTM 690 ADV. 52,000 km. 25 countries. 4 continents and counting.
Open-Exporers----->A collection of travel blogs
Old 09-08-2012, 05:06 AM   #5474
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,152
Yeah, that's my next step. I feel like the bike should run as it is, but it just will not start. Once I get that figured out (no codes showing) I'm going to build a small 9v power supply to cycle the injector on and off while in the ultrasonic.
Old 09-08-2012, 05:09 AM   #5475
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 808
Once you make the power supply, just connect a hose with a jug of desired solvent and have it gravity feed through the injector as it is cycling. It will be slow/nonexistent at first but should become a stream when it is clean.
Times are GMT -7.   It's 12:32 AM.
