Old 09-08-2012, 06:18 AM   #5476
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 3,856
Originally Posted by 690Emaf10 View Post
Now my problem is the bike won't fire..... Fuel pump primes but it doesn't fire. The other thing I notices was that all of my instrament panel goes off each time the bike cranks. I'll have to pull the pump again and make sure there are no kinks in the lines and everything looks good.
Stupid question but, you did remember to reconnect the quick realease for the fuel line right?
BK.RD.RNR is offline   Reply With Quote
Old 09-08-2012, 07:55 AM   #5477
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,172
Originally Posted by RoninMoto View Post
Once you make the power supply, just connect a hose with a jug of desired solvent and have it gravity feed through the injector as it is cycling. It will be slow/nonexistent at first but should become a stream when it is clean.
Was thinking I'd build something along the lines of a pressurized flush or a back flush set up even. Would pulsing it be better than simply holding it open?
When there is no way out - Find a way further in.
690 DL650 XL1200C Past bikes
Originally Posted by Mugwest View Post
Stay half-assed, my friends.
Buzztail is online now   Reply With Quote
Old 09-08-2012, 12:01 PM   #5478
Uller
Uller's Avatar
Oddometer: 558
pulsing it would allow pressure to build behind the solenoid for a more forceful blast of cleaner each time it was cycled. I did backflush it first then the normal direction.
I don't have an ultrasonic cleaner and used the syringe method shown on youtube. seemed to work fine. I've got about 10,500 mi. on my original injector and carry a spare with me.
I believe they are in the ballpark of $150 here in the states.
Uller is online now   Reply With Quote
Old 09-08-2012, 03:13 PM   #5479
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
From what I understand, the injector in itself IS a pump. When the coil is activated, it triggers a hammer that pushes the fuel inside the motor.
That said, your local Diesel Engine Tune Up shop will clean these injectors better then you will ever do for few bucks ...
I know that just trying to dip that think into some "liquid mechanics" wont work 100%
Paul Jr.
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 09-08-2012, 03:37 PM   #5480
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,172
Got it back together and not I'm getting no fuel. I can pull the injector out and get a clean spray pattern, but with my finger in the back of the throttle body I get nothing from the injector. Pull it out and it's not consistently pulsing now
Injector? electrical?
Connections look good, new spark plug, good fuel pressure (though I don't have a pressure gauge that'll read that high) drop a little fuel in the TB and it fires right up- No fuel through the injector though. It there a way to test the electrical? Something like a noid light? I doubt my DVM would read quickly enough to see the pulsing.
Old 09-08-2012, 07:02 PM   #5481
B2
"Racin Mason"# 4
B2's Avatar
Oddometer: 1,392
After a gear lever any ideas ? the hammerhead is outa stock for another month
B2 is offline   Reply With Quote
Old 09-08-2012, 07:17 PM   #5482
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
You might be better off without the Hammerhead I had a problem with the splines on mine and they never called me back, been waiting 8 months! No big deal, it's only $80.
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-08-2012, 10:51 PM   #5483
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,661
I had a look at my 500 exc they are closer 690 then hammerhead and cheaper then a 690 lever
Mudguts is offline   Reply With Quote
Old 09-08-2012, 11:48 PM   #5484
.chris
690 Advenduro
.chris's Avatar
Oddometer: 51
Originally Posted by beaney View Post
Buy a decent torx socket set
Tried your idea, and now I have managed to strip the torx bolt.
Who the hell uses torx for such tight bolts, will be replacing it with a proper bolt if I ever get it out.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 09-09-2012, 01:46 AM   #5485
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 858
why ya taken off ya shock for?
"You cannot harm me...my wings are like shields of steel" - Batfink
My KTM 690
Night Falcon is offline   Reply With Quote
Old 09-09-2012, 03:52 AM   #5486
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 915
Take the fuel hose off the injector , turn ignition on & see if you get a surge of fuel . If so block the hose with your thumb & turn ignition on again & see if it has pressure ( it should be very hard to stop it spraying ) keep your thumb on it a while to see if it holds pressure in the line.
Disclaimer ,,, if you set your bike or shed on fire don`t blame me ,
Brute is offline   Reply With Quote
Old 09-09-2012, 04:12 AM   #5487
LOZ
Oddometer: 1,121
Thanks, I sprayed some WD40 on it before I left for work. I'll see what i can do with it when I get home.
if its anything like mine ....... ..cut it off..start looking on e-bay for a secondhand tank,when trying to get it out the nut in the plastic gouged a hole in the tank and i had to fit a new tank
£950
loz
LOZ is offline   Reply With Quote
Old 09-09-2012, 04:15 AM   #5488
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,172
Done, and done. I don't see it being a supply issue. I have the back flush fixture for the injector set up. I'll get on that this morning and see what happens.
Old 09-09-2012, 06:13 AM   #5489
daveknievel
daveknievel's Avatar
Oddometer: 31
I have a shifter on my 690 that is from my 05 450 SMR. Same thing. They only offer 4 different shifter for ktm's. And the hammerheads aren't out of stock. Tucker rocky has 5 in ILL, 9 in cailf. None in the PA . Warehouse.
daveknievel is offline   Reply With Quote
Old 09-09-2012, 07:22 AM   #5490
Buzztail
8 lug oil burner
Buzztail's Avatar
Oddometer: 9,172
Update
Looks like the fuel volume is there, but the pressure is not all that great. Looks like I'm going back into the tank for round three
http://s2.photobucket.com/albums/y35...t=IMG_0345.mp4
Times are GMT -7.   It's 11:29 AM.
