Old 09-14-2012, 11:12 AM   #5536
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 973
Originally Posted by ktmmitch View Post
We took the first pre-production tank mouldings today from our CNC machined aluminium rotational moulds today.
Once cooled,we fitted them to the 2012 690 Enduro test bike,and they were perfect!!
Now we can finalise fairing and screen tooling,ready for production.
Will these tanks be exclusive for the 2012s or will it work for the previous generations as well?
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 09-14-2012, 11:13 AM   #5537
DirtJack
DirtJack's Avatar
Oddometer: 1,597
Originally Posted by crankshaft View Post
Yea, I'm with you. I've had it wag in the deep sand at 100mph but thats normal to me, part of the experience.
Hey Crankshaft, you just need to wik it up a bit when that happens. What's the worst that can happen?
I never had head shake on my 690, but on other bikes it was always badly worn or improperly inflated/balanced front knobby. Sand is always a problem because the trail measurement always goes to zip unless you keep the front light.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-14-2012, 11:17 AM   #5538
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,176
Originally Posted by tattewell View Post
Clearly we don't all know it, I have never experienced headshake on my 690... interesting though.
I think Barman is referring to the steering wobble that happens at high speeds. I think it is a shape-of-the-tire thing, combined with freeway turbulence grabbing the rider's shoulders.
My old 950 had that wobble above 95mph when I used TKC80 front tires. They have a round cross section, as opposed to the more triangular front tires like the Scorpions or Mefo's.
My 12 690R can also have that wobble above 75mph so I added a damper that works well enough up to about 90mph. I still have my MT21 front, but I am pretty sure if I replaced it with a more triangula tire, it would be more stable at higher speeds. I like the tire, though, and I don't cruise any faster than about 80mph anyway.
In my experience a 'headshake' is a suspension or geometry issue generated by bottoming the forks through ruts, or an improper set-up on a road race bike. It usually surfaces under power on corner exit or an esses where the racer flipflops the bike. They can degenerate to a full blown tank slapper in a flash. I'm not sure the 690 wobble will turn into a tankslapper, but I will admit that it feels like I am loosing directional control if I don't stop it somehow.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 09-14-2012, 11:18 AM   #5539
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Nice progress guys!
Maybe silly question ~ will this type of material (speaking of the tanks) allow graphics to be applied without bubbling?
www.rally-raidproducts.co.uk
Photobucket
modeselector is offline   Reply With Quote
Old 09-14-2012, 11:41 AM   #5540
mtntrails
Oddometer: 462
Nippybit & Modeselector
Thanks for the kudos.
The bike resides in Las Vegas and was built to ride / tour out west. Yes, the Scotts Damper is a must for faster desert riding - particularly for Mojave riding with all of the boulders buried in the soft sand.
mtntrails is offline   Reply With Quote
Old 09-14-2012, 11:47 AM   #5541
ktmmitch
Oddometer: 662
They have been designed to fit all years
ktmmitch is offline   Reply With Quote
Old 09-14-2012, 12:16 PM   #5542
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
that and grooved pavement and it wasnt scary compared to say a 90's cr500
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 09-14-2012, 12:27 PM   #5543
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
the head shake Ive experienced it gets worse when the throttle is chopped . a trick i used on the 90's honda 5hunnys is to drag the rear brake. never figgured out the cause of the shake but i had some see Jesus moments on the big bore smokers. kawi was not as bad as the hondas
I have had it aslo on some street bikes but on the honda 500 it was life changing
my 690? nothing to even think about even on grooved pavement it wanders but no slappers
i do set my sag and use correct spring rates but run very dirt oriented tires always and usually at 17 psi and many times worn completely out...........im cheap ...what can i say?
Ride the DEZ
76 CB750
Old 09-14-2012, 12:35 PM   #5544
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Just A Theory On This
Originally Posted by mtntrails View Post
My 2010 690 Enduro has a Scotts Damper, but my 2008 690 SMC does not - and the SMC has much steeper rake / trail geometry. I have never experienced even a hint of headshake on either bike.
I just mounted a new set of tires (Metzeler Karoo T Front and Mefo Explorer Rear) on the 690 Enduro. The KTM Shop in Las Vegas who installed them is just off of the freeway. This particular freeway is grooved - man, the bike felt like it was waggin' / wanderin' around pretty good. It didn't seem to do that so much with the worn set of tires (same tires).
Maybe the new tires (with much deeper tread depth than your old ones) grab the rain groves more causing the wiggling as the tires try to follow the grooving. I have the same issue with my 2010 which also has a Scotts and relatively new tires. I ride on these highways just trying to trust the front end and tolerating the wiggling. It is annoying.
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 09-14-2012, 01:38 PM   #5545
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,759
Don't ya hate it when theres an issue with a bike and all the " my bike is the greatest people " talk ya down
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz is offline   Reply With Quote
Old 09-14-2012, 01:58 PM   #5546
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 2,215
not so much of the "all my bike is greatest people" there B2... my bike IS the greatest and I love banana's in PJ's
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 09-14-2012, 02:41 PM   #5547
Beer'o'clock Baz
Oddometer: 1,759
Yeah your right my bike is the greatest aswell but i do respect and if possible try and help people with an issue not call them a liar- beautiful weather here in brissy night falcon you must be lonely over there
Carl Sagan
Old 09-14-2012, 02:56 PM   #5548
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
it's odd to complain about a problem and then get bitchy when you don't get the answer you want to hear...
pick one...
Tires, air pressure, sag, suspension set up, steering head bearings and in some cases....the rider
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-14-2012, 03:01 PM   #5549
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
I trail brake in the loose stuff, it's amazing how a little bit of rear brake settles things down.
Just say'IN
Old 09-14-2012, 03:18 PM   #5550
Beer'o'clock Baz
Oddometer: 1,759
pick one...
I think the latter is more likely the only thing i havn't checked
Carl Sagan
Times are GMT -7.   It's 04:46 PM.
