Old 09-20-2012, 12:44 PM   #5626
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,133
Originally Posted by Xmoto View Post
I want to find a spare to cut down in case I want to put the bike back to stock. I like it being lowered but the rear tire has touched the tank a few times with the sag set to 110mm. Thanks for the supermoto tip.
I installed a 1 inch Kouba link on my 2012. I had a half inch cut from the stand. I probably should have taken 3/4 inch, but it works well enough. Maybe cut yours and keep looking for a new one just in case you want it back stock.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 09-20-2012, 03:59 PM   #5627
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
I think that's what am going to do
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 09-20-2012, 04:43 PM   #5628
690Emaf10
Oddometer: 68
Originally Posted by 690Emaf10 View Post
I remember seeing some of your posts. How did you eventually get the lines in the tank to no kink? The lines are so fragile and bendy it seems like they wouldn't kink at all....
I pulled everything apart this evening and it seemed to pump just fine. Put it back in the tank and nothing..... Did you guys shorten the hose that was provided with the ca-cycleworks pump?
690Emaf10 is offline   Reply With Quote
Old 09-20-2012, 05:09 PM   #5629
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by The Letter J View Post
While I had my shock off a couple days ago I found that every single linkage bearing had excessive play in it, I was hoping it would be just one or two of them. Surprisingly both shock bearings are still nice and snug. For those that have replaced their rear suspension linkage bearings, did you use OEM (~$200 just for bearings/seals, no sleeves or hardware) or have you found a source for a kit?
Riders,
Me too......I wanna know as I think my linkage is what is squeaking.....
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 09-20-2012, 05:11 PM   #5630
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Bigbugberg View Post
Wish I could say the same for my 2010 Husky TE250... Seven weeks without parts. Never a Husky again.
I like Huskies, but those orphans are hard to keep in clothes
Ged Schwartz
Kamloops , BC
Old 09-20-2012, 05:17 PM   #5631
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 954
Originally Posted by motoged View Post
Riders,
I'd put money on it! It was the squeaking that was driving me nuts that prompted me to perform the initial inspection... a couple shots of penetrating oil down there quieted things down for a couple days but the loose bearings remain! With my bike on the stand, I can lift the back wheel up more than 1/2" before the shock starts to move.
The Letter J is offline   Reply With Quote
Old 09-20-2012, 05:24 PM   #5632
690Emaf10
Oddometer: 68
Well, the fourth time was the charm..... Pulled it apart and cut about 3 inches off the hose provided by ca-cycleworks. Put it back together and immediately had fuel. reconnected everything and it fired up. I'm on call this weekend so I don't know if I'll get to take it for a ride or not but I'm excited to give it a try with the new pump.
Old 09-20-2012, 06:48 PM   #5633
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 09-20-2012, 08:33 PM   #5634
Pundy
Oddometer: 339
Anybody here running the Leo Vince exhaust on their 690? Anyone know how it compares to the FMF Q4?
Pundy is offline   Reply With Quote
Old 09-20-2012, 08:34 PM   #5635
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Exhaust comes out the end of both of them, they go Vrooommmmm, vroooooooomm blub,blub,blub, vvrooooooooommmmm!!!!
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-20-2012, 09:28 PM   #5636
dirtbikeslob
Oddometer: 300
dirtbikeslob is offline   Reply With Quote
Old 09-20-2012, 11:10 PM   #5637
Uller
Uller's Avatar
Oddometer: 1,674
Riders,
Well.... that sucks!
Mine just started squeeking too (just after I got back from BC Ged, maybe it is your dirt up there )
Didn't Beaney mention wearing out the yoke to the point that the hole was oval, or something along those lines..... (I'll search)
Found it...Post #4560 http://www.advrider.com/forums/showp...postcount=4560
If you read the next few pages, I asked what components he used to "remedy" the situation and if I recall correctly, the solution involved expensive rally parts.
Uller screwed with this post 09-20-2012 at 11:50 PM
Uller is offline   Reply With Quote
Old 09-21-2012, 01:06 AM   #5638
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
You're a freaking prophet.
I am at one with my duality.
Barman is offline   Reply With Quote
Old 09-21-2012, 05:13 AM   #5639
rdkyote
rdkyote's Avatar
Oddometer: 67
I've heard the FMF is obnoxious and the LV and Akra are a bit more subdued, FWIW.
Here's a inmate with the LV... maybe he'll respond if he heard the FMF.
http://www.youtube.com/watch?v=EyHEu...3&feature=plcp
2012 KTM 690 Enduro R
2007 KTM 250 XC
rdkyote screwed with this post 09-21-2012 at 05:19 AM
rdkyote is offline   Reply With Quote
Old 09-21-2012, 05:43 AM   #5640
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
My LV is pretty loud. I wouldn't want a pipe any louder, and I have the insert in.
My bad
Times are GMT -7.   It's 09:57 AM.
