09-27-2012, 09:33 AM
#5716 | |
Oddometer: 1,671
Qui Desiderant Pacem Preparate Bellum |
09-27-2012, 09:44 AM
#5717 |
Beef = Packed Vegetables
Ok. Not really a list, but an attempt to structure infos ...
I found it ... http://advrider.com/forums/showthread.php?t=723338 I also found Vector Leto: http://www.advrider.com/forums/showt...php?p=16802212 Paul Jr
KTM690r 2011 Gros Buck screwed with this post 09-27-2012 at 10:01 AM |
09-27-2012, 10:24 AM
#5718 | |
Oddometer: 4,909
Go for the 1.6" A60 if you are after max. strength. It will still handle ok on road.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
09-27-2012, 12:11 PM
#5720 |
Supern00ba
Oddometer: 518
Multi-national 690r
In a moment of boredom I decided to check where my accessories came from:
Australia Pro-fill fuel filter Uni air filter Vortex ECU Motoz tires Seat Concepts tyres UK Rally Raid Products Tank bolts Steering damper mount Bar raisers Billet fuel filler cap conversion USA Scott Steering damper Flatland skidplate Superplush Rear spring Dirt Bike Gear fender bag Trail Tech TTO hour/tach meter Ziptie Racing front axel pull Rocky Mountain LED relay South Africa Hyde hand guards Hyde Carcon fibre Case guard Japan Suzuki LTZ 400 fan switch Italy Pirelli UHD tubes Germany Touratech Shark fin China No name brand headlight bulbs (numerous) LED indicators A real mongrel, for sure. Some stuff like the fold away mirrors and foam grips I have no clue where it came from. Of course, most of these would be made somewhere completely different. Thanks for letting me waste 3 minutes of your life
KTM 690 R - "Its just a little crush..." |
09-27-2012, 01:06 PM
#5721 |
Dirty_Sanchez
Oddometer: 2,096
Team-I just tried fitting the correct part number UNI pod filter for these bikes and it is the absolute worst fitting part I've ever attempted to fit.
It should be a drop in, shouldn't it? The fit is so bad the airbox cover won't even close. The durometer of the sealing rubber is WAY higher than the sealing rubber on the stock pleated filter. The sealing rubber is black, and the pods themselves are grey. Sure wished they were green, or white. Have any of you had to trim the ID of the airbox filter hole in order to make this thing drop in correctly? Hey Mr. UNI !! Don't they make straight edges and tape measurement devices south of the equator? There's no way on earth I'd ride that bike around the neighborhood with a fit this poor. Dirty
No, really, the mustache means I love you. '09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167 |
09-27-2012, 01:07 PM
#5722 | |
Kool Aid poisoner
Oddometer: 4,827
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
09-27-2012, 01:39 PM
#5723 | |
lost in the 690 mega
Oddometer: 316
09-27-2012, 02:53 PM
#5724 | |
Dirty_Sanchez
Oddometer: 2,096
Quick work with a utility knife, and that overmold is gone. The fit is 75% there now. I'll trim the forward most overmold lip when I remove the airbox. Stock Can and this UNI, with no remap, and I should be fine, eh? Dirty
09-27-2012, 03:40 PM
#5725 |
Oddometer: 2,293
09-27-2012, 05:45 PM
#5726 |
Difficult but Useful
Oddometer: 507
Twin Air part number
"He said he didn't want to shine, but he looked mighty shiny to me" Silky Johnson |
09-27-2012, 09:35 PM
#5727 |
Old Adventurer
Oddometer: 458
Giant Loop Coyote
Does anyone know if this luggage makes it hard to get to the gas cap? I tried it at the dealers, but it was hard to tell as I couldn't really install it, and of course the bag was empty.
It would be annoying to have to loosen the bag every time you gassed up. Thanks.
Warped by the rain, driven by the snow I'm drunk and dirty, but don't ya' know I'm still Willin' |
09-27-2012, 10:06 PM
#5728 | |
Oddometer: 116
But overall, no a major task as is fairly quick to loosen and tighten - no need to take off completely. Hope this helps. Gaz
![]() Adventurised '09 KTM 690R "Not all who wander are lost" - JRR Tolkien |
09-27-2012, 10:46 PM
#5729 |
Mad Poser
Oddometer: 585
My current state of disrepair :/
![]() ![]() Intake rocker arm needle bearing let go. Thankfully all needle's recovered without having to split the case. Unfortunatelly though, the rocker arm took out the cam shaft. ![]() Little blurry, but you can see the damage beside the cam, the lobe looks fairly similar, like it got hammered. Swapping the timing chain just in case.. KTM has the timing chain back ordered until Manuary, but my parts guy knows a guy who knows a guy thats not Dutch, so the part will be in tomorow.
09-28-2012, 04:48 AM
#5730 | |
on the mend
Oddometer: 976
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding. All posted pics < 6/30/12 deleted courtesy of Apple
