Old 09-28-2012, 05:14 AM   #5731
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 585
I hope somebody as super smart as LukasM can help me out here.
KTM Part # 75038050044 Oil cooler set. Will it work on my Enduro (I dont see why not) more importantly, anybody know the heat loss involved and the extra oil capacity it would deliver?
Linky
tattewell is offline   Reply With Quote
Old 09-28-2012, 07:17 AM   #5732
Woundflatout
Woundflatout's Avatar
Oddometer: 330
Originally Posted by tattewell View Post
My current state of disrepair :/
Intake rocker arm needle bearing let go. Thankfully all needle's recovered without having to split the case. Unfortunatelly though, the rocker arm took out the cam shaft.
How many miles were on your bike when the bearing let go?
Sorry to see, but I guess it could have been worse...
Cheers,
Jason
Jason Slutsky
PROUD TO BE RIFF RAFF
'03 XR650R
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 09-28-2012, 09:44 AM   #5733
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Giant Loop Mojavi Fitment
Originally Posted by Sutherngintelmen View Post
This pic is with Mojave but I have Coyote too. Mounted on SW Mototech rack I am able to remove gas cap without loosening bag straps.
Here are several photos of how I fitted mine allowing refueling without removing the Mojavi.
DSCN1094
You may not be able to mount yours as I did if you do not have an anchor point like my rear hand rails.
Here is another photo of how it fits ready to ride with the tail bag installed.
DSCN0478
If you have the grab handles you can use the rear anchor strap as I did securing it through the front mounting point for the handles. I cut off the large buckle (on the rear mounting strap) and retained the feed through loop so that I could tighten the strap and get it to run through the recess for the gas cap while staying out of the way of removing or installing the cap. I see that you also have an Acerbis cap which creates a better recess for burying the strap out of the way of the cap. In my case I simply have to use the quick release on my KTM tail bag and I have access to the gas cap. I also cut down my no slop cap venting valve to clear the top of the tail bag.
Absent the grab handles maybe you can lengthen the rear strap and still mount it the same as mine by securing the longer strap to your rear rack.
If this will work for you then you will use up a bit of the rear seat where the tool bag portion of the Mojavi sits. I have not found this to be a problem in riding as I seldom get that far back on the seat and do not carry passengers.
One other view of my setup.
DSCN0474
A final point. In order to keep the bag from abrading the side panels use some Moleskin on the side of the pockets facing the panels. Works great and costs very little. You can also use Moleskin under the tool bag where it rides on your seat if you mount it like mine.
Hope this helps.
Cheers
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 09-28-2012, 10:04 AM   #5734
Biped
NooB Again
Biped's Avatar
Oddometer: 113
Giant Loop tank bag with RR tanks
Anyone have a pic of a GL tank bag fitted with the RR tanks.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 09-28-2012, 11:02 AM   #5735
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Whoops
Southerngintlemen,
My post should have been addressed to Folkinride's question as you have solved the problem.
Cheers,
Old 09-28-2012, 11:11 AM   #5736
Xico
Oddometer: 11
Here it goes:
Xico is offline   Reply With Quote
Old 09-28-2012, 11:17 AM   #5737
Biped
NooB Again
Biped's Avatar
Oddometer: 113
Thanks Xico, as I suspected, looks a little tricky to get to the gas caps. i assume you just push the bag to the side to fuel up.
Old 09-28-2012, 11:49 AM   #5738
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 585
Cheers,
Jason
What are these "miles" you speak of?
Old 09-28-2012, 01:59 PM   #5739
RoteEddie
Oddometer: 467
He probably wants to know how many kilometres you have on that motor :-)
12' Triumph Speed Triple R
12' Aprilia Tuono V4R APRC
12' KTM 690 Enduro R Evo2
RoteEddie is offline   Reply With Quote
Old 09-28-2012, 07:55 PM   #5740
Woundflatout
Oddometer: 330
Km exactly...;)
Jason Slutsky
'03 XR650R
Rallymoto #159
Old 09-28-2012, 11:49 PM   #5741
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 170
Not a problem at all. Quick and easy, unless you are racing against the clock. If at the pump, just make sure you point the nozzle forward, or it'll splash back out the tank.
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 09-29-2012, 01:57 AM   #5742
LukasM
Oddometer: 4,909
Linky
Cheers mate, but I'm not smart, I just read a lot of stuff on the internet.
Unfortunately I don't know anybody that has tried that cooler on the E / R. I do know that it won't fit properly on the SM with a bash plate installed, and that the E/R/SMC frame is a bit different than the SM/Duke frame. Have a look at installation instructions (I can email them to you) and compare it with your current setup with bash plate installed, then you should be able to tell if the hard lines fit around the engine block in their supposed position. Attachment to the bottom of the radiator might also be slightly different, I don't think those are the same either.
All in all it's very unlikely that it will be a straight bolt-on but with some skills and time could probably made to fit. And we'll never know how much is needed until somebody tries. Will it be you?
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 09-29-2012, 03:35 AM   #5743
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 585
Km exactly...;)
17 and change here... just bad luck me thinks.
Old 09-29-2012, 03:37 AM   #5744
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 585
I think for 250 bones its worth a try. As soon as I pay off my busted bike bill, i'll order this and give it a shot. You dont know what the added capacity in oil is do you?
Old 09-29-2012, 05:53 AM   #5745
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Me thinks? Is that a German word?
Just say'IN
crankshaft is offline   Reply With Quote
Times are GMT -7.   It's 12:54 AM.
