Old 10-01-2012, 09:05 AM   #5746
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,730
Originally Posted by Olleg View Post
I have to make my mind soon. Rally raid tank or Safari tank (have to order rally raid adventure fairing)? Any advice?
I suggest the rally raid tanks. Though they hold slightly smaller volume they are a lot easier to take on and off for repairs and maintenance. I have run both and the Safari tank worked fine and offered plenty of range but it was a PITA to install and take off and complicated seat fitment. The RR tanks are a little confusing to install the first time but once on its reasonably easy.
Seth S
Seth S is offline   Reply With Quote
Old 10-01-2012, 10:02 AM   #5747
Olleg
Olleg's Avatar
Oddometer: 22
How about handling, did you notice difference between them (safari vs rally raid)?
Comparing to the stock, is it a big difference?
KTM 690 ENDURO
Olleg is offline   Reply With Quote
Old 10-01-2012, 12:57 PM   #5748
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Big difference from stock, of course. Do you notice the difference between 0 and 40#'s in a backpack?
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-01-2012, 01:22 PM   #5749
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 190
I'd go with the RR tanks. Service is top notch and kit all fits together nicely. I'd be tempted to hold on for the new version of the tanks, or perhaps mine if I bite the bullet and swap out my kit (would love to)
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 10-01-2012, 02:21 PM   #5750
NovaMoto
Oddometer: 133
+500 for RR parts & service!
NovaMoto is offline   Reply With Quote
Old 10-01-2012, 02:21 PM   #5751
Seth S
Seth S's Avatar
Oddometer: 4,730
RR is 9 liters I think while Safari is 12 iirc. thats about 15 lbs vs 22 lbs (fuel weight) pluss a few more for the weight of the tanks and hardware. i did not notice a lot of handling difference between the two ore even over stock. The safari tank makes its presence known as it is a bit wider where the RR's feel a little more stream lined.
Seth S
Old 10-01-2012, 02:50 PM   #5752
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Splitting hairs... The existing RR tanks are morel like 9.5l. Go with the new RR tanks. it will be worth the wait. I got to sit on the prototype and it is noticeably narrower then the originals because it doesn't use the side covers. Also, i hear they hold more fuel then the originals.
When they are empty, i find the RR tanks don't add noticeable weight.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 10-01-2012, 03:06 PM   #5753
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,026
Are those the ones that are currently on their web-site and have an availability in 4-6 weeks?
Gordy is offline   Reply With Quote
Old 10-01-2012, 03:33 PM   #5754
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by The Letter J View Post
Did you use an EXC front sprocket? They fit over the countershaft splines but are narrower which could take pressure off the seal? Next guess would be that your chain is just too tight? How many miles are on the bike? It may just be time to replace the seal anyway, they are cheap and easy to change anyway.
When mine started leaking it just needed the $1 o-ring behind the sprocket spacer replaced, the seal itself is only ~$7.
Riders,
Aftermarket sprockets that are not KTM-specific will often set up a leak for a few reasons:
1) The backside of the aftermarket sprocket ( which is the point of contact on the spacer collar) does not have an "extruded collar" (for lack of a better description) that puts pressure on the spacer and subsequently the o-ring, thus not making a seal at the o-ring point of contact;
2) The seal is leaking and might require a replacement....;
3) the sprocket doesn't have to make contact with the seal....just the metal collar that holds the o-ring;
4) You are not supposed to re-use the cupped washer, as one use renders it flatter and less efficient in that pressure function on the spacer and o-ring (if you must use a used cupped washer, place it over a large socket, place another smaller socket against the washer and give it a couple or more whacks so as to "re-cup" the washer.
I learned all this on my 450 EXC.....and suspect it is true for the 690 countershaft setup.
If I am mistaken, I am sure one of you kind souls will make the mistake evident
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 10-01-2012, 03:47 PM   #5755
crankshaft OP
crankshaft's Avatar
Oddometer: 14,005
Really? I did, especially in the woods. The front end felt heavier when turning in but it's acceptable for a long distance bike.
Just say'IN
Old 10-01-2012, 04:49 PM   #5756
Hooked
Hooked's Avatar
Oddometer: 8
Hard starting when sitting awhile
I don't know where to turn to figure the hard starting on my 08. If I take it to the dealer they will charge me $100 plus an hour to tell me they can't find a problem. I have read of this problem but have not found what the cure is. With 21K Kms it should still have lots of life left. Any help from the group? It doesn't happen all the time but often enough it starting to concern me.
Hooked is offline   Reply With Quote
Old 10-01-2012, 08:20 PM   #5757
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Not too sure on reliable delivery date with RR but I'm hoping they take the time to really get the fitment and installation documentation right. Looks promising.
modeselector is offline   Reply With Quote
Old 10-01-2012, 08:26 PM   #5758
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,763
Originally Posted by motoged View Post
Riders,
Hey mate
- mine was # 1 on your list I grabbed the old sprocket outa the bin and the new one is a couple mm thinner :-{
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz screwed with this post 10-02-2012 at 12:55 AM
Beer'o'clock Baz is offline   Reply With Quote
Old 10-01-2012, 10:57 PM   #5759
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 786
Originally Posted by beaney View Post
Yeah whatever, carry on, I've never raced a 690 and know nothing about them!!!!!!!!!!!!!!
OH by the way you have to change the oil pressure rgeultor in the back of the engine for a temp regulator plus add the pipes, I prefer the more robust cooler from the 690rr mounted behind the fairing. I personally dont bother with an oil cooler any more because i change the oil after every 10 hours of racing like on the Tuareg and Maroc rallies, the 690 holds more than enough oil for a days racing.
If you want a cheap kit then I've got one in my scrap pile of stuff that was no good for racing.
That's not what I mean. My point is I wasn't going to mount it in the location KTM want's it mounted. I realize it will probably need custom oil lines. My initial question is more about how it plumbs into the oil system on the bike.
If possible I would like to mount it underneath a baja designs 8 inch round headlight, or some close facsimile there of.
tattewell is offline   Reply With Quote
Old 10-01-2012, 11:34 PM   #5760
blakrj
Need to ride
Oddometer: 190
Take a look at page 63 of the RR spare parts manual here. Shows where it plumbs in. The KTM lines and cooler are not cheap if you go this route.
Times are GMT -7.   It's 07:32 PM.
