Old 09-30-2012, 01:15 PM   #5761
Mini Trail
nb
Oddometer: 2,268
Originally Posted by tattewell View Post
My current state of disrepair :/
Intake rocker arm needle bearing let go. Thankfully all needle's recovered without having to split the case. Unfortunatelly though, the rocker arm took out the cam shaft.
Little blurry, but you can see the damage beside the cam, the lobe looks fairly similar, like it got hammered. Swapping the timing chain just in case.. KTM has the timing chain back ordered until Manuary, but my parts guy knows a guy who knows a guy thats not Dutch, so the part will be in tomorow.
Small world.
The intake rocker is bakordered until God knows when. I didn't get any serious damage but that roller did dick up the cam lobe alittle. You can see the scoring in the picture. I think it will polish out. The pin that the roller rolls on was also loose in the exhaust rocker. The replacement had a different design.
Your cycle had a bell on it.
Mini Trail is online now   Reply With Quote
Old 10-01-2012, 04:57 AM   #5762
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Originally Posted by NJXR75 View Post
Have you tried McMaster-Carr or perhaps Grainger? Another alternative would be to buy nylon rod from McMaster and fabricate them yourself using a drill press.
McMaster-Carr - thanks!!
Was headed down fabricate them path - I've got some left over marine nylon paneling, thought I'd run a 1" round over bit through it then hole saw to pieces.
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 10-01-2012, 05:09 AM   #5763
NovaMoto
Oddometer: 133
I lost the exhaust rocker bearing on my 11 a month back. It didn't drop the needles into the case but I figure it was very close.
How long did you guys run those engines with noise before it went catastrophic? Just curious.
Originally Posted by Mini Trail View Post
Small world.
NovaMoto is offline   Reply With Quote
Old 10-01-2012, 08:18 AM   #5764
Olleg
Olleg's Avatar
Oddometer: 18
Rally raid tank or Safari tank
I have to make my mind soon. Rally raid tank or Safari tank (have to order rally raid adventure fairing)? Any advice?
KTM 690 ENDURO
Olleg is offline   Reply With Quote
Old 10-01-2012, 08:30 AM   #5765
Hosebag
Difficult but Useful
Hosebag's Avatar
Oddometer: 1,011
Originally Posted by Hosebag View Post
Anyone have the Twin Air part number handy for this filter?
Found it- 154519
"Reality is peeking through a keyhole and getting a swift kick in the nuts"
Hosebag is offline   Reply With Quote
Old 10-01-2012, 09:05 AM   #5766
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
I suggest the rally raid tanks. Though they hold slightly smaller volume they are a lot easier to take on and off for repairs and maintenance. I have run both and the Safari tank worked fine and offered plenty of range but it was a PITA to install and take off and complicated seat fitment. The RR tanks are a little confusing to install the first time but once on its reasonably easy.
Seth S
Seth S is offline   Reply With Quote
Old 10-01-2012, 10:02 AM   #5767
Olleg
Olleg's Avatar
Oddometer: 18
How about handling, did you notice difference between them (safari vs rally raid)?
Comparing to the stock, is it a big difference?
KTM 690 ENDURO
Old 10-01-2012, 12:57 PM   #5768
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Big difference from stock, of course. Do you notice the difference between 0 and 40#'s in a backpack?
Just say'IN
crankshaft is offline   Reply With Quote
Old 10-01-2012, 01:22 PM   #5769
blakrj
Need to ride
Location: Cloggland via Borneo, TX, UK, Oz and S.Africa
Oddometer: 189
I'd go with the RR tanks. Service is top notch and kit all fits together nicely. I'd be tempted to hold on for the new version of the tanks, or perhaps mine if I bite the bullet and swap out my kit (would love to)
2011 KTM 690 Enduro R, 2010 KTM 690 Enduro R (stolen)
2008 Yamaha YZ450, 2002 Yamaha YZ426
www.bruneibikers.com
www.airborneriders.com
blakrj is offline   Reply With Quote
Old 10-01-2012, 02:21 PM   #5770
NovaMoto
Oddometer: 133
+500 for RR parts & service!
Old 10-01-2012, 02:21 PM   #5771
Seth S
Seth S's Avatar
Oddometer: 4,545
RR is 9 liters I think while Safari is 12 iirc. thats about 15 lbs vs 22 lbs (fuel weight) pluss a few more for the weight of the tanks and hardware. i did not notice a lot of handling difference between the two ore even over stock. The safari tank makes its presence known as it is a bit wider where the RR's feel a little more stream lined.
Seth S
Old 10-01-2012, 02:50 PM   #5772
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Splitting hairs... The existing RR tanks are morel like 9.5l. Go with the new RR tanks. it will be worth the wait. I got to sit on the prototype and it is noticeably narrower then the originals because it doesn't use the side covers. Also, i hear they hold more fuel then the originals.
When they are empty, i find the RR tanks don't add noticeable weight.
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 10-01-2012, 03:06 PM   #5773
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,746
Are those the ones that are currently on their web-site and have an availability in 4-6 weeks?
Gordy is online now   Reply With Quote
Old 10-01-2012, 03:33 PM   #5774
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by The Letter J View Post
Did you use an EXC front sprocket? They fit over the countershaft splines but are narrower which could take pressure off the seal? Next guess would be that your chain is just too tight? How many miles are on the bike? It may just be time to replace the seal anyway, they are cheap and easy to change anyway.
When mine started leaking it just needed the $1 o-ring behind the sprocket spacer replaced, the seal itself is only ~$7.
Riders,
Aftermarket sprockets that are not KTM-specific will often set up a leak for a few reasons:
1) The backside of the aftermarket sprocket ( which is the point of contact on the spacer collar) does not have an "extruded collar" (for lack of a better description) that puts pressure on the spacer and subsequently the o-ring, thus not making a seal at the o-ring point of contact;
2) The seal is leaking and might require a replacement....;
3) the sprocket doesn't have to make contact with the seal....just the metal collar that holds the o-ring;
4) You are not supposed to re-use the cupped washer, as one use renders it flatter and less efficient in that pressure function on the spacer and o-ring (if you must use a used cupped washer, place it over a large socket, place another smaller socket against the washer and give it a couple or more whacks so as to "re-cup" the washer.
I learned all this on my 450 EXC.....and suspect it is true for the 690 countershaft setup.
If I am mistaken, I am sure one of you kind souls will make the mistake evident
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 10-01-2012, 03:47 PM   #5775
crankshaft OP
crankshaft's Avatar
Oddometer: 14,004
Really? I did, especially in the woods. The front end felt heavier when turning in but it's acceptable for a long distance bike.
Just say'IN
Times are GMT -7.   It's 07:48 PM.
